Author Topic: Keyboard for a friend - need help finding  (Read 3177 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Thu, 17 May 2012, 03:41:58 »
So I have this friend, he's looking for a keyboard.  I'd like to convert him to the mech. side.
In order of importance:
Backlit
Black switches
Full sized
All that with a budget under $100USD. I can't think of any off the top of my head so I'll ask you guys. Thanks in advance
Offline MMB
« Last Edit: Thu, 17 May 2012, 04:39:51 by MagicMeatball »
Offline mr626
« Reply #2 on: Thu, 17 May 2012, 05:45:28 »
Hmm, backlit and fullsize for that price may be tricky. Ducky Shine comes to mind, but that is closer to $150USD from memory.
Offline cactux
  • Topre Knight
« Reply #3 on: Thu, 17 May 2012, 05:47:29 »
^ +1
[FS]☠ The temple lol ->HERE<-
Offline Djuzuh
« Reply #4 on: Thu, 17 May 2012, 05:48:10 »
Deck is also more pricey, and ugly too xD.
Offline Wolf3188
« Reply #5 on: Thu, 17 May 2012, 06:15:00 »
What about the Cooler Master Storm Trigger? Fullsize, MX Blacks, Red backlighting, seems solid enough. About $120.
http://www.cmstorm.com/en/products/keyboards/Trigger/
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Thu, 17 May 2012, 11:45:50 »
I've seen Noppoo Pro closer to their budget, but will need to still add a little, around $110. I haven't seen much about it, so I am unsure if it would be a good choice. But it is one of the lower priced boards that fit backlight and blacks, otherwise you might get lucky on a lower price on the Mionix Zibal, I have seen some go for under $100 on ebay. But once again, they don't seem to be regarded very well overall.
« Last Edit: Thu, 17 May 2012, 11:50:56 by lysol »
Offline laffindude
« Reply #7 on: Thu, 17 May 2012, 12:04:47 »
Well, there is the CM Storm Quickfire Pro...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Thu, 17 May 2012, 14:29:17 »
Quote from: laffindude;594685
This about the only one that comes close, I'll try to find one with black switches. BTW if I can't, what is the best backlit rubber domed (ewww, I know but deal with it)?
Offline MMB
« Reply #9 on: Thu, 17 May 2012, 15:55:26 »
Forget the full-sized. And definitely forget the rubber dome. Go with this dude.
http://www.ebay.com/itm/TG3-Electronics-BL82-Series-82-key-LED-Backlit-KeyboaRD-/230718950737?pt=PCA_Mice_Trackballs&hash=item35b7ebcd51#ht_1510wt_1163
Best bet for the money.
EDIT: Also, why would you want someone new to mechanical switches to use MX blacks? Someone who isn't used to them, would have some pretty sore fingers using blacks for the first time. I would suggest reds or browns, imo.
Offline whiteduck
« Reply #10 on: Thu, 17 May 2012, 16:01:52 »
I will sell you said above keyboard for 55$ shipped.  I am not a fan of the layout and you get the added bonus of me already removing the pesky plastic between the switches and the keys.  Keep in mind you will have to add some sort of pad on the bottom of the board as the screws stick out from the plate on the bottom.
Edit: I only have used the keyboard for like an hour after removing the plastic and realized I was not a fan.  So it shouldn't have any wear at all.
« Last Edit: Thu, 17 May 2012, 16:08:18 by whiteduck »
-wd
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Thu, 17 May 2012, 16:25:04 »
Quote from: MagicMeatball;594867
I'll show it to him, but he might not like it
Thanks for the help :) (BTW I told him to start with browns but he wants blacks {I'm sure he'd go for reds too tho})
Offline smknjoe
« Reply #12 on: Thu, 17 May 2012, 16:53:15 »
Is that a Deck for 1/3 the price?
SSKs for everyone!
Offline foEs
« Reply #13 on: Thu, 17 May 2012, 17:13:58 »
That is what I was gonna ask looks like a cheap deck 82? What kind of switches does it have?
Offline MMB
« Reply #14 on: Thu, 17 May 2012, 17:18:55 »
Yes, it is a Deck 82. TG3 is the manufacturer of the boards. Deck re-brands/re-sells them.
Offline urbanus
« Reply #15 on: Thu, 17 May 2012, 19:58:13 »
Quote from: The_Beast;594466
Ah, I understand now.
When I read the title, I thought you needed help finding a friend.
