Author Topic: A few questions about Ducky boards on PChome  (Read 1639 times)
Offline mr626
« on: Thu, 17 May 2012, 05:34:02 »
EDIT: thanks to squarebox for pointing out my obvious lack in reading skills. However, I'd still appreciate answers to my other questions as I may end up getting a Ducky with mx blacks- they seem pretty cheap and I've not tried blacks yet:
http://global.pchome.com.tw/english/?mod=item&func=exhibit&IT_NO=DCAH0X-A53592701&SR_NO=SBAE0R&ROWNO=11&tm=e
Hi guys,
I have a few questions about the following Ducky boards- hopefully someone will be able to answer them easily:
http://global.pchome.com.tw/english/?mod=item&func=exhibit&IT_NO=DCAH0X-A58945616&SR_NO=SBAE0Q&ROWNO=4&tm=e
http://global.pchome.com.tw/english/?mod=item&func=exhibit&IT_NO=DCAH0X-A59130761&SR_NO=SBAE0Q&ROWNO=2&tm=e
-Is this a good price for these? Seems really cheap- would work out around $55 shipped for either of them. They are brand new right?
-When they say 'cherry mx green axis' are they actually referring to cherry mx green switches (which from what I understand are like stiffer mx blues) or is it a case of 'lost in translation' and they are simply mx blues?
-What is the build quality like of Ducky boards, compared to Leopold/Filco?
-What stabilisers to Ducky boards use?
-Do Ducky use 'standard' keycaps? One thing I really disliked about my old Leopold board was the non-standard spacebar. I want to make sure that if I buy another cherry mx board, I get one that is compatible with 'standard' cherry keycaps so I can easily order replacement keycaps from groupbys etc.
I was going to buy my wife a pink PLU-87 board, but depending on what answers I get to the above I may end up giving her my white choc mini and buying a Ducky board for myself :-)
Thanks in advance for your help
« Last Edit: Thu, 17 May 2012, 06:27:12 by mr626 »
Offline squarebox
  • In Omnia Paratus
« Reply #1 on: Thu, 17 May 2012, 06:15:54 »
If you read carefully, it says XM green axis mechanical keyboard.
It's not using Cherry MX switches. Ducky XM series are using ALPS switches.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline mr626
« Reply #2 on: Thu, 17 May 2012, 06:18:27 »
Quote from: squarebox;594494
Ah, clearly I did not ready carefully! Thanks for pointing that out, I was wondering why they were so cheap.
