Author Topic: Model M bolt mod disapointment  (Read 128116 times)
Offline SidusNare
  • Do, or do not; there is no try.
« on: Thu, 17 May 2012, 16:04:17 »
I pulled my model M apart. I was pretty careful, used an exacto chisel blade for the rivets.
http://picpaste.com/2012-05-17_15-36-37_299-WLQoVBNc.jpg
This is what I found when I got it apart.
Any thoughts on what to do about it or if its usable?
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
« Reply #1 on: Thu, 17 May 2012, 16:16:21 »
There are several posts regarding fixing cracks in the barrel plate (I think it is called a "frame" by Unicomp) using various techniques involving epoxy.
Unicomp will sell you a new one pretty cheap, too.
Not the end of the world. Cheer up
- D Trump 2026-10-24
Offline rknize
    • metaruss
« Reply #2 on: Thu, 17 May 2012, 19:42:13 »
Russ
