Author Topic: qpad mk-50  (Read 4833 times)
Offline makkesk8
qpad mk-50
« on: Thu, 17 May 2012, 19:02:12 »
I currently have a qpad mk-50 with red switches. and i want to change the switches to blues. So I wonder if Ican do that without soldering? aka just removing the keycap and remove the switch with a screwdriver?
EDIT: (mk-50 has the same structure as the XArmor keyboards)
Thanks in advance
« Last Edit: Thu, 17 May 2012, 20:47:45 by makkesk8 »
Offline perragnar
qpad mk-50
« Reply #1 on: Thu, 17 May 2012, 19:44:36 »
I think the mk-50 is plate mounted so, no.
qpad mk-50
« Reply #2 on: Thu, 17 May 2012, 22:43:22 »
If it's plate mounted, you'll have to desolder the switches to change the stems. As far as I know, the only KB that breaks this rule is the upcoming phantom.
Your best bet would probably be to sell it and buy one with blues.
Offline makkesk8
qpad mk-50
« Reply #3 on: Sun, 03 June 2012, 17:20:38 »
http://i.imgur.com/nOscm.jpg
Heres a picture of the switches, I heard you could tell by a picture if it is or not. So is it?
Offline tukkez
qpad mk-50
« Reply #4 on: Mon, 04 June 2012, 03:44:24 »
it is plate mounted, aka. you can't remove the switches without desoldering.
qpad mk-50
« Reply #5 on: Mon, 04 June 2012, 05:05:56 »
And there's no room to detach the switch top from the housing like on the phantom plates. Tukkez is right: You'll need to break out the hot air gun (Or other desoldering method of choice).
Good picture, though.
Offline makkesk8
qpad mk-50
« Reply #6 on: Mon, 04 June 2012, 08:56:49 »
Quote from: tukkez;607099
How can you see that?
Offline alaricljs
  • I be WOT'ing all day...
qpad mk-50
« Reply #7 on: Mon, 04 June 2012, 09:28:09 »
That black thing surrounding the switches is the metal plate.  If you saw a PCB (similar to a motherboard for instance) and could see the entire switch, that's PCB mounted.
Filco w/ Imsto thick PBT
