Author Topic: KBTalking Pro - Wireless Bluetooth/wired mechanical keyboard.  (Read 9580 times)
Offline laffindude
This is inexact and incomplete translation: http://kbtalking.cool3c.com/article/59511
One keyboard to rule them all. (He did write something like this in Chinese)
Wireless Bluetooth supports Windows, Mac, Android devices (Android 3.0 needed), iOS devices, and yes even PS3. This is an one to many device meaning you can pair to with bunch of devices and switch to outputting to any device you want.
It is also wired, so you can plug it into a desktop to power it, and still use it's bluetooth features. Wired mode doesn't charge the battery, but supposedly it can last up to a year given ~3hour usage daily.
Short cut keys:
There are OS specific shortcut keys. In different keyboard profile, the shortcut keys change to ones recognized by the intended OS.
Squirrels strikes again. Instant noodle and "health" mode returns. Both of these mode turns off the keyboard after a set interval to remind you that your ramen is done or time to take a break (it is 1-15min programmable and 60min respectively).
  • Keycaps are UV coated. They're also available in BIG MOFO. I mean big BOPOMOFO printed caps. Google if you don't know what it is.
  • Keyboard will be released in August in China, Taiwan, and US. Not sure who the retailer will be State side.  MSRP is ~159 USD... Save yer *****ing.
  • Bluetooth pairs up to 10 devices.
  • Wired USB (no PS2 I think).
I am probably forgetting some stuff. I BELIEVE Zippy is manufacturing these in house. Pretty sure these are plate mounted and uses Cherry stabilizers.
_______________original post below_______________
[ Attachment Invalid Or Does Not Exist ] 50701[/ATTACH]
It is based on a new Zippy mechanical keyboard. It has both wired and wireless mode operation, which can be used concurrently. Meaning, you can keep the keyboard plugged into your computer, and use hotkey to switch between the outputs to connect to your iDevice or Android wirelessly (you can pair with with multiple devices at the same time). It takes 2 AA batteries, and can operate without batteries provided it's plugged into USB.
It's a bit on the homely side, but there aren't many choices in mechanical wireless boards. I'll hold the pricing for now. It is a niche product, so expect accordingly. I'll post more when more stuff pops up.
Extended reading in Chinese Traditional:
http://kbtalking.cool3c.com/article/58489
http://kbtalking.cool3c.com/article/57722
« Last Edit: Wed, 13 June 2012, 05:07:30 by laffindude »
Offline REVENGE
« Reply #1 on: Fri, 18 May 2012, 02:11:29 »
In for one when they make it in Poker size.
Also: http://blog.computex.biz/post/Computex-2011-Mechanical-Keyboard-From-Zippy.aspx
Helvetica on backlit keys? I'm sold.
« Last Edit: Fri, 18 May 2012, 02:15:52 by REVENGE »
Offline laffindude
« Reply #2 on: Fri, 18 May 2012, 02:32:08 »
Poker size is unlikely though. I am also pretty sure it is not backlit. Computex pictures are from an earlier prototype. The current prototype looks padprinted.
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #3 on: Fri, 18 May 2012, 06:58:42 »
Quote from: laffindude;595194
I would settle for a TenKeyLess version.
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline fauxy
« Reply #4 on: Fri, 18 May 2012, 09:18:13 »
If someone is looking for a wireless keyboard, they are likely also looking for something that saves space. How is that still not understood by manufacturers?
« Reply #5 on: Fri, 18 May 2012, 12:02:24 »
Didn't kl buy a wireless  tenkeyless that was a total piece of crap?
I remember the wireless adapter never worked or something like that.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Fri, 18 May 2012, 12:06:50 »
Yeah, the Neo Zelia. I would still take one of those to use wired though, it is a nice board otherwise I thought. There was some talk somewhere else of them fixing the wireless on a later revision but I have no idea if that happened.
Bluetooth Filco would probably be best bet, if you can live with JIS.
Offline jamin3131
« Reply #7 on: Fri, 18 May 2012, 12:15:13 »
I'd love a TKL bluetooth Mech Keyboard. I personally loathe any kind of dongle that ties up USB ports and uglifies my pc/laptop
Offline laffindude
« Reply #8 on: Mon, 11 June 2012, 10:07:15 »
http://kbtalking.cool3c.com/article/59511 Will be released in the states.
Offline Reptile
« Reply #9 on: Mon, 11 June 2012, 10:12:20 »
someone needs to make a GOOD mechanical HTPC keyboard. The neo looks cool but the wireless needs to at least work lol
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline laffindude
« Reply #10 on: Wed, 13 June 2012, 05:06:38 »
^Updated original post with latest info.
Offline laffindude
« Reply #11 on: Sat, 16 June 2012, 21:29:54 »
Offline laffindude
Re: KBTalking Pro - Wireless Bluetooth/wired mechanical keyboard.
« Reply #12 on: Wed, 25 July 2012, 02:37:54 »
So ya. These went on for pre-ordering on KBT for the past month, and the first round closes today.
The finalish spec is that lasered caps. They're available in grooved and laser foamed legend. Grooved version has a separate piece of plastic showing the alternate functions, which are not lasered onto the caps. Only thing really changed from the first post is the merged iOS and MAC mode key.
Offline Tenkey
« Reply #13 on: Wed, 25 July 2012, 03:25:16 »
finally a wireless mechanical keyboard :D
« Reply #14 on: Wed, 25 July 2012, 09:44:03 »
They've had them before, but this is the best I've seen thus far. I really like the "noodles" key and break-taking.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #15 on: Wed, 25 July 2012, 10:36:00 »
If I remember anything the person that he sold it to got it to work...
Filco w/ Imsto thick PBT
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #16 on: Wed, 25 July 2012, 11:42:16 »
Like the sideprinted legends :)
-Enzo Ferrari
Offline kbfreak
  • * Commercial Vendor
« Reply #17 on: Sun, 12 August 2012, 05:40:49 »
USA website and pre-order information now available:
http://kbtalkingusa.com/kbtalking-pro-basic-info/
