Author Topic: Noppoo choc Mini (Cherry Mx Red) Issue PLEASE help.  (Read 1718 times)
Offline Momoh
« on: Fri, 18 May 2012, 13:10:06 »
Basially im a big big fan of compact keyboard with keys very close to each other, so i bought the Noppoo choc mini cherry mx red version and replaced my non mechanical Logitech Ultra Slim Keyboard.
  Got it, plugged it in, 10 minute in no problemo at all, however whilst playing in WoW in arena, some keys stopped registering, and i believe there's something wrong with the way it emulates 3 keyboards or somthing.
iv spent like probably 10 minut trying to typ thi mag an a you an sseee from this line how ****ed up it truly is, plas hlp :/
ps. somtimes it differs between keys, sometimes E and C never ork, then they tart to ork again while W and the F1 key stop instead only way i can get them to work again is to hold it down and press all the time for
sometimes almost 30 seconds or something, im very dissapointed with this.
regards - Momoh
Offline REVENGE
« Reply #1 on: Fri, 18 May 2012, 16:22:00 »
Hi, welcome to GH! Your post is a bit unintelligible, could you specify which operating system you're using? Also, have you tried using the keyboard over PS/2?
Offline Momoh
« Reply #2 on: Sat, 19 May 2012, 03:34:35 »
Quote from: REVENGE;595505
Hi, yes im using a windows 7 home premium service pack 1 64-bit.
i have not tried using ps/2 since its USB (im not really sure how to go about changing it to ps/2 either (isn't ps/2 the purple old socket?, if so i need to buy an adapter i guess?)
regards.
Offline cactux
  • Topre Knight
« Reply #3 on: Sat, 19 May 2012, 05:37:19 »
* Have you try to connect the keyboard to another usb port? maybe windows is using a wrong driver
* Do you have other computer to try this keyboard?
[FS]☠ The temple lol ->HERE<-
Offline Tony
« Reply #4 on: Sat, 19 May 2012, 07:00:41 »
While gaming, USB port buffer may be full sometimes and the result is the missing of some typed keys. I've experienced with my Filco which has not emulated 3 keyboards at all.
