Author Topic: Noppoo Mini vs Choc Mini  (Read 2509 times)
Offline therecorder
« on: Sun, 20 May 2012, 11:49:09 »
qtan has Minis.  Other than the colors, is there any difference in the boards?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Sun, 20 May 2012, 12:44:05 »
Only difference between the colors is keycap material. The white is pbt, the brown is pom.
Offline therecorder
« Reply #2 on: Sun, 20 May 2012, 13:03:23 »
Difficult decission to make.  qtan states:
"There [This] is the new noppoo with improved caps printing (lighter than before) which I try to show with the pictures. But due to light and screen display, might be little different than you get it."
What does, "Noppoo 80% with 84 keys", on qtan's page mean: http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/noppoo-mini-mechanical-gaming-/lid=18974440
vs.
"84 keys 65% of the width of the normal keyboard design", on this ebay page: http://www.ebay.com/itm/Noppoo-Choc-Mini-84-Mechanical-Cherry-MX-Blue-keyboard-/110748744838?pt=PCA_Mice_Trackballs&hash=item19c923bc86
« Last Edit: Sun, 20 May 2012, 13:09:46 by therecorder »
« Reply #3 on: Sun, 20 May 2012, 13:25:29 »
It's the exact same board. They are talking about the legend printing contrast, the older batches were harder to see. qtan has better price, so buy it from them if you want the dark color version. The percent stuff is talking about keys compared to a full size 104key (100%). Choc mini has less keys than fullsize so it's an 80% and a Poker is a 60%...
« Last Edit: Sun, 20 May 2012, 13:27:41 by lysol »
Offline qtan5370
« Reply #4 on: Sun, 20 May 2012, 13:40:59 »
The same keyboard.
The caps are all improved no more old light color caps anymore.
Also, 65% talking about Size , 80% of talking about keys. A little confusing but it is what I quote from official website
Look for Keyboard? Check my offers. I have most major keyboard and some caps for you, if you don\'t see it there, ask me. I am Top rated seller on eBay now, and have retail store in China selling keyboard and other gaming staffs.
My eBay store http://stores.ebay.com/E-sports-Gaming-equipments?_rdc=1
My store(lower price than eBay): http://www.keyboardwow.com
Offline therecorder
« Reply #5 on: Tue, 22 May 2012, 23:53:20 »
Quote from: qtan5370;596516
The same keyboard.
I see that the brown switch board has POM caps.  Does the blue switch board?
« Reply #6 on: Wed, 23 May 2012, 00:18:13 »
I'm pretty sure the Noppoo choc mini comes in either switch type. I believe they use POM (Delrin) as the keycap material for all the black keycaps; PBT for the white.
You can sort by switch type (blue) and then pick out a black one if you want cherry MX blue and POM.
Offline therecorder
« Reply #7 on: Wed, 23 May 2012, 10:08:27 »
Just ordered the Mini with MX Browns.  This is my 13th mechanical keyboard - Hope this brings me some luck with it. :crazy:  Gonna stop with boards, and start with keycaps.
Offline davkol
  •  Post Editing Timeout
« Reply #8 on: Wed, 23 May 2012, 17:31:21 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 14:11:53 by davkol »
