Author Topic: Built My New Rig  (Read 13571 times)
Offline Nadger
Built My New Rig
« on: Mon, 21 May 2012, 23:12:21 »
I recently built my new rig.  Thought i would share it here.
i7 3770k Ivy Bridge Cpu
ASUS Z77 Sabertooth Motherboard
Geforce GTX 680 (Zotac)
16gb Corsair Vengeance LP 1600 RAM
Corsair Force3 GT 60gb SSD (SSD Cache)
Western Digital 1TB Caviar Black HDD (Raided With SSD to Cache)
Corsair H100 Closed Loop Watercooler
Noctua NF F12 FocusFlow Fans on H100
ASUS Xonar DX 7.1 Soundcard
Corsair AX 750 Gold PSU w/ White cables
Corsair 600T SE White Case
LG Lightscribe Bluray Multi Drive
26" Doublesight 263n S-IPS Monitor
Noppoo Choc Mini Mech Keyboard
Razer Naga & Deathadder Mice
Altec Lansing 5.1 Surround Sound System
All fans attached to motherboard, fan controlled through ASUS FanXpert 2/Thermal Radar software, set on temp curve.  Basically this thing is dead quiet while no stress is on the system.  Even under full load you can barely hear it.
Dual Sound card setup with xonar and onboard, front panel audio connected to Xonar, Speakers connected to onboard sound.  FPS games I run virtualized 7.1 surround through the Xonar to echo locate, Vent also through headset, everything else through speaker system.
It all went together perfectly, and fired up without a hitch.  Definitely the best looking rig I've ever built.
Had to share it with other geeks who may appreciate it!  Please let me know what you think, or if you have any suggestions.
« Last Edit: Mon, 06 August 2012, 20:17:22 by Nadger »
● Logitech ♦ G600
● Noppoo ♦ Choc Mini 茶轴
● Plum ♦ 96 White / Red Switch
● Microsoft ♦ Xbox 360 Windows Controller
Offline net2522
  • lollollollol
Built My New Rig
« Reply #1 on: Mon, 21 May 2012, 23:17:44 »
Nice!!
About the Corsair 600T. How big is the case?
Offline Nadger
Built My New Rig
« Reply #2 on: Mon, 21 May 2012, 23:32:33 »
23.30" x 10.40" x 20.00"
Its a fairly large case, bigger than midtower, smaller than supertower, but very wide.  Thing was a dream to build in!
● Logitech ♦ G600
Built My New Rig
« Reply #3 on: Tue, 22 May 2012, 00:03:10 »
this case is AWESOME!
if i wasn't looking to downgrade my case's footprint (currently have a haf 932) i'd get this in a heartbeat.
Offline jonnybastard
Built My New Rig
« Reply #4 on: Tue, 22 May 2012, 00:18:00 »
Nice and clean, good work.  Decent parts list too.
KMAC    -    HHKB Type-S    -    Filco TKL LineaR    -    Poker X    -    KBT Race LE
flickr
Offline PixelVandalism
    • YouTube
Built My New Rig
« Reply #5 on: Tue, 22 May 2012, 01:30:06 »
Very nice build.
I am going for the black and white colour scheme with my next build.
Offline godly_music
Built My New Rig
« Reply #6 on: Tue, 22 May 2012, 02:24:44 »
I'm jealous.
Offline TheProfosist
  • Custom Layouts Only!
Built My New Rig
« Reply #7 on: Tue, 22 May 2012, 03:50:14 »
Looks like a similiar build to mine which ill post once its complete alow with the builds of my secondary pc's
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Built My New Rig
« Reply #8 on: Tue, 22 May 2012, 07:39:50 »
gah, i want individually sleeved cables for my ss x750 :(
Offline audioave10
Built My New Rig
« Reply #9 on: Tue, 22 May 2012, 22:39:01 »
I bought the 600T (white) during the first week it was sold from NewEgg. Its the best air-cooling case I've yet used.
Nice PC build...
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline mr626
Built My New Rig
« Reply #10 on: Tue, 22 May 2012, 22:58:52 »
Very nice build- looks great
Offline The_Beast
  • I like wood ಠ_๏
Built My New Rig
« Reply #11 on: Tue, 22 May 2012, 23:17:44 »
I just order my new rig yesterday, 3770k, Samsung 830 128Gb SSD, 8Gb G.Skill low voltage RAM, and a MSI Z77A-GD65. I'll be mixing it with existing parts, GTX570, Corsair 750HX, Fractal R3, a whole bunch of hard drives (~8 internals, with matching drives as external backups)
It should be here hopeful on Friday
Offline Reptile
Built My New Rig
« Reply #12 on: Wed, 23 May 2012, 00:17:13 »
Super clean man. Done any overclocking at all yet?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline WhiteFireDragon
    • youtube
Built My New Rig
« Reply #13 on: Tue, 29 May 2012, 23:20:30 »
Very clean build. Did you sleeve those PSU cables yourself? Sleeving cables always looks nice, but last I did it myself it took half a day. Never again...
Offline Desu
Built My New Rig
« Reply #14 on: Wed, 30 May 2012, 01:21:03 »
wow...that is gorgeous O_O
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Built My New Rig
« Reply #15 on: Wed, 30 May 2012, 07:04:32 »
Very nice. I'm looking to dump my 600t and go for a 800d :D
-Enzo Ferrari
Offline Nadger
Built My New Rig
« Reply #16 on: Sun, 03 June 2012, 01:05:38 »
Thank you all for the compliments, I spent 4-5 months researching and planning the parts that would go into this build, and it turned out better than I had hoped.  Guild Wars 2, my body is ready...
Quote from: WhiteFireDragon;603577
No, corsair offer color coded sleeved cables now for their fully modular psus, as seen here: http://www.corsair.com/us/power-supply-units/psu-accessories.html
Quote from: Reptile;598107
Ive done a bit, got a stable 4.5oc, but ive since turned it off troubleshooting a BSOD that ive tracked down to Intel HD4000 drivers when the IGPU is enabled with Virtu MVP to boost framerates.  I will go back to 4.5 ghz OC once I start running a game that can benefit from it.  Ivy bridge hates much over 1.3volts, but 4.5 ghz on an ivy bridge is still about equiv to a 5ghz Sandy Bridge oc which is hard to achieve so imo ivy still comes out ahead especially at a lower TDP, combined with the boost to the IGPU which can still be utilized when you have a DGPU when running Virtu MVP acceleration.
● Logitech ♦ G600
Offline Rafen
Built My New Rig
« Reply #17 on: Sun, 03 June 2012, 14:51:14 »
Nice build. That makes me wanna build a new rig. I would like my next build/upgrade to run eyefinity.
Offline ribbit
Re: Built My New Rig
« Reply #18 on: Sat, 21 July 2012, 13:19:48 »
Very nice rig!
Offline TestostoBoost
« Reply #19 on: Sat, 21 July 2012, 15:57:08 »
Nice!
Offline cr0ben
« Reply #20 on: Sun, 22 July 2012, 15:44:08 »
Nice
Offline Christown
  • MX Blue >
« Reply #21 on: Mon, 23 July 2012, 17:30:32 »
How's the 680 holding up?
I currently run 580's in SLI and don't think it's worth updating to a 680 just yet.
Offline zzAaron
« Reply #22 on: Tue, 24 July 2012, 02:16:25 »
can we get some pics? :D
Ducky 9008G2 Browns, White Filco TKL Reds
Offline mistakemistake
  • Global Loveinator
« Reply #23 on: Mon, 06 August 2012, 09:52:10 »
(Attachment Link) 50951[/ATTACH] (Attachment Link) 50950[/ATTACH] (Attachment Link) 50952[/ATTACH] (Attachment Link) 50949[/ATTACH] (Attachment Link) 50948[/ATTACH]
Awesome! We have a very similar build!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #24 on: Mon, 06 August 2012, 09:54:55 »
Very nice build, can't see the pics :(
S2K :)
-Enzo Ferrari
  • Global Loveinator
« Reply #25 on: Mon, 06 August 2012, 10:00:25 »
S2K :)
I was going to say you post your pics, and I'll post mine since we have such a similar build... but I didn't want to make it seem like I'm thread jacking.
AP2 ftw :) Do you have an S2K as well?
Offline Nadger
« Reply #26 on: Mon, 06 August 2012, 20:17:02 »
Doh, the switch to the new thing must have broken the links.
Here they are again:
Im also about to purchase a PLUM MX96 white with cherry reds.  It will replace my noppo chic mini in browns:
I am also replacing my razer naga with a g600:
I'll post more pics once i have the keyboard and mouse replaced so you can see the full white/black set.
● Logitech ♦ G600
  • Global Loveinator
« Reply #27 on: Mon, 06 August 2012, 20:33:41 »
Dude! That's bad ass! I love the white, I'm jelly.
Offline Christown
  • MX Blue >
« Reply #28 on: Tue, 07 August 2012, 05:02:43 »
The black and white colour scheme looks very classy. Also good choice on the case, Corsair makes some good stuff.
Offline alixinhzai
« Reply #29 on: Tue, 07 August 2012, 06:48:24 »
nice build :D
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #30 on: Tue, 07 August 2012, 08:39:47 »
Tighten those 6-pin cables up! (pull 'em down behind the mobo tray)
Offline Anynoupy
  • French Fries
« Reply #31 on: Wed, 08 August 2012, 07:59:12 »
Nice Rig !
I guess those cables were already sleeved when bought, or did you do it yourself ? ;)
  • Global Loveinator
« Reply #32 on: Wed, 08 August 2012, 13:01:51 »
^looks like corsairs sleeved modular kit
Offline ACallander
    • Portfolio
Built My New Rig
« Reply #33 on: Wed, 08 August 2012, 13:12:33 »
They are the corsair sleeved cables you can buy, they had a sale for I believe $69 instead of the usual $89.
Sent from ACals iPhone using Tapatalk
Offline ACallander
    • Portfolio
Built My New Rig
« Reply #34 on: Wed, 08 August 2012, 13:14:18 »
I just have a small question. Don't want to hijack or steal the topic. I have a single 580 and I'm debating on should I SLI 580 or go single 670 then duel 670 later?
  • Global Loveinator
« Reply #35 on: Wed, 08 August 2012, 13:15:51 »
Which games do you play (if not games, what are you looking to do with it), and what size/resolution is your monitor and what kind of monitor?
Offline ACallander
    • Portfolio
Built My New Rig
« Reply #36 on: Wed, 08 August 2012, 13:32:26 »
I play a lot of games; add me on steam acallander. I do graphic and web design. My display 27" crossover led with a 24" extra display
  • Global Loveinator
« Reply #37 on: Wed, 08 August 2012, 13:40:55 »
That's hard to say.. to drive games at the highest settings at a monitor resolution for a 27'' monitor, I would say you should try and go SLI. But which card depends on how much you want to spend. I'd say go with a single evga 680 for now and dual later. You can also take advantage of EVGA step up program when new cards come out.
Offline ACallander
    • Portfolio
Built My New Rig
« Reply #38 on: Wed, 08 August 2012, 14:07:12 »
So sell my evga 580 and buy a evga 680 or 670?
  • Global Loveinator
« Reply #39 on: Wed, 08 August 2012, 14:11:02 »
I'd say so, but ultimately up to you. I think the 680 is just a little bit more in price and i believe performs a little better. I saw a review on toms hardware for the 680vs670 a while back.  I currently use a single evga gtx680 on a dell 24'' 1920x1200 and not really having any complaints. 37-41 fps avg on highest possible settings
Offline DaClownie
  • Handsome Devil
« Reply #40 on: Sat, 11 August 2012, 02:10:28 »
If you're running a 680 and an OCed 3770k you should be able to just ignore VirtuMVP. The FPS gains are more so designed for lower end systems, as it skips frames that wouldn't render in time and posts it as complete, therefore moving the queue up and creating smoother gameplay. However, the 680 will outperform your monitors easily in basically every title that Virtu works with.
TL;DR: Your system is fast enough to get rid of VirtuMVP and enjoy a high OC instead. Easier to keep stable.
Nice rig :)
Offline ranviper
  • Nerd.
« Reply #41 on: Thu, 18 October 2012, 13:26:07 »
Wow that looks nice. Sleeved cables make a huge difference.
EC66 | MIYA
