Author Topic: New Cherry MC Switch?  (Read 1664 times)
Offline nar
« on: Tue, 22 May 2012, 03:48:14 »
Over at reddit, someone mentioned that they talked with a cherry sales rep at a convention in Australia and they mentioned that Cherry is making a new key switch for next year with "software controlled torque".
Anyone heard anything about this?
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline Djuzuh
« Reply #1 on: Tue, 22 May 2012, 03:50:15 »
Sounds awesome. And damn pricey.
Offline naranja
« Reply #2 on: Tue, 22 May 2012, 05:04:59 »
also very curious about this! From comments:
Unlike their current switches which all have set torque(pressure needed to push keys) the new ones will be able to be adjusted by software in real time. so you could set your A S W D keys to me much softer then the keys around it to prevent accidental presses then change them to the same torque later when you want type without having to physically remove and change the switches.
How does that work? Are there springs inside the switches still
Honestly have no clue. Sales rep wouldn't tell me anything since they are still in development stage. Expecting magnets and solenoids to provide magnetic resistance. But just a guess.
Any other input on this? I'm really doubting magnets/solenoids because that would seem ridiculously expensive.
Offline Djuzuh
« Reply #3 on: Tue, 22 May 2012, 05:11:16 »
I can't think of any other way to do it. It seems the most plausible explanation
Maybe precompress a spring can do it accurately too ?
Offline godly_music
« Reply #4 on: Tue, 22 May 2012, 05:19:33 »
Sounds extremely gimmicky and prone to breakage. The simpler, the better, in my opinion. Just stick with a resistance you like, etc.
Offline cactux
  • Topre Knight
« Reply #5 on: Tue, 22 May 2012, 05:31:24 »
Quote from: nar;597393
why are you talking about torque?
torque is rotational force, and the switches actuate by an axial force.
IMO what they may try to do is control the actuation force required to activate the switch, as well as the actuation travel. This will make happy everybody
« Last Edit: Tue, 22 May 2012, 05:45:16 by cactux »
[FS]☠ The temple lol ->HERE<-
Offline limmy
« Reply #6 on: Tue, 22 May 2012, 05:50:49 »
http://en.wikipedia.org/wiki/File:4StrokeEngine_Ortho_3D_Small.gif
Maybe upward force is controlled by rotational force like in an combustion engine?
The idea of software controlled force sounds interesting, but sounds very expensive. Moreover, a lot of moving parts in a small switch sounds like trouble to me.
Offline 7bit
  • MX1A-G1DW
« Reply #7 on: Tue, 22 May 2012, 06:09:09 »
I see. By an electric impulse, the switch is switched from blue to brown.
edit: I bet they introduced that on 1 April 2012.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #8 on: Tue, 22 May 2012, 07:17:32 »
there are materials that that change mechanical resistance when current is applied, but they're all very expensive now. this sounds kind of far fetched, or meant for very expensive applications
Offline funxion
« Reply #9 on: Tue, 22 May 2012, 07:22:24 »
I think you guys are thinking too much into it...
I'm pretty sure Cherry wouldn't invest time and money into developing a switch that wouldn't sell...
The cheapest route would be a spring within a chamber that compresses and expands with minor mechanical input via scripted software.
Crush80
Filco MJ2 TKL
Offline Djuzuh
« Reply #10 on: Tue, 22 May 2012, 08:28:36 »
reddit is moderated on a subreddit basis.
And the only moderator of r/keyboards does nothing at all it seems.
