Author Topic: Price Check- What's it Worth?  (Read 4239084 times)
Offline physicsmajor
  • Trade Count: (0)
Re: Price Check- What's it Worth?
« Reply #1600 on: Sat, 31 August 2013, 18:37:51 »
Rosewill 104 key board w/MX Blues (never used, decided I much preferred Reds and missed NewEgg RMA window)
ErgoDox w/Ergo Clears (55g Korean springs, will include original springs), assembled personally with professional solder joints, SMD diodes, tested, very clean build. The problem is, I just need Reds. So I'd either like to sell the assembled kit and start over, or I'm going to have to de-solder every last switch and swap them out for Reds.
Offline Thimplum
  • Trade Count: (0)
  • Master of all Ponies
« Reply #1601 on: Sat, 31 August 2013, 18:43:25 »
Rosewill: $80-$90
ErgoDox: ~$250?
TP4 FOR ADMIN 2013
Offline Neo.X
  • Trade Count: (0)
« Reply #1602 on: Sat, 31 August 2013, 19:19:13 »
How much is worth for
1. DAS Retro set
2. tanslucent green brobot
3. black CC
4. Olivetti set
Thanks
Any idea?
All those keyboards will be lost in time....
  • Trade Count: (0)
« Reply #1603 on: Sat, 31 August 2013, 19:24:04 »
I thought the ergodox had removable switch tops?
Offline Thimplum
  • Trade Count: (0)
« Reply #1604 on: Sat, 31 August 2013, 19:38:35 »
I does, but that's tedious and it's easy to break a switch.
TP4 FOR ADMIN 2013
  • Trade Count: (0)
« Reply #1605 on: Sat, 31 August 2013, 19:50:11 »
Tedious maybe but I've never heard anything about breaking switches.
Offline Amble
  • Trade Count: (0)
« Reply #1606 on: Sat, 31 August 2013, 19:58:31 »
1. DAS Retro set
3. black CC
4. Olivetti set
Thanks
Any idea?
1. a set recently sold for $110 by mistakemistake
2. around $80 would be fair... maybe a bit more because it is translucent and a desirable color
3. couldn't tell you because I want to buy it if you are selling
4. a set recently sold for $80 + shipping by Hyde
Offline Neo.X
  • Trade Count: (0)
« Reply #1607 on: Sat, 31 August 2013, 20:02:16 »
1. DAS Retro set
3. black CC
4. Olivetti set
Thanks
Any idea?
Thanks.
Offline xredman
  • Trade Count: (0)
« Reply #1608 on: Sun, 01 September 2013, 22:58:35 »
http://item.ultimatelist.com/for-sale/consumer-computer/UL15241.htm
I don't own it, but what is a decent price for this keyboard?
Offline do_Og@n
  • Trade Count: (0)
« Reply #1609 on: Sun, 01 September 2013, 23:06:04 »
I'm not to familiar with these older Apple Keyboards but $80 sounds steep to me. I would stalk around on Ebay for a month or so and you should be able to find a better deal.
Offline AGmurdercore
  • Trade Count: (0)
« Reply #1610 on: Mon, 02 September 2013, 09:47:59 »
What is the cheapest i can get an ergodox without switches (PCB+plate+case). Thanks in advance!
What the hell am I even doing
  • Trade Count: (0)
« Reply #1611 on: Mon, 02 September 2013, 10:05:56 »
I switched one without removing it, but didn't like the process. If there's a guide for that around here somewhere I'd love to see it - either I did it wrong, or I'm not confident it can be done on all of them safely.
« Last Edit: Mon, 02 September 2013, 10:30:23 by physicsmajor »
Offline mauri
  • Trade Count: (0)
« Reply #1612 on: Mon, 02 September 2013, 10:09:34 »
There are pcbs for 38$ at mechanicalkeyboards.com
I AM BABAR KING OF THE ELEPHANTS
Offline pixel5
  • Trade Count: (0)
    • pixel5
« Reply #1613 on: Mon, 02 September 2013, 10:11:32 »
Like new G84-4100? (used less than 2 hours)
I see them selling for ~$45 on ebay, and $75 on mk.com. Just wanted to double check here.
Also, black alps switches? 104 of them to be exact.
« Last Edit: Mon, 02 September 2013, 10:36:58 by pixel5 »
Poker II
Quickfire Rapid
BUY MY CRAP
Offline remdell
  • Trade Count: (0)
« Reply #1614 on: Tue, 03 September 2013, 00:27:34 »
To be honest, the G84-4100 (ML4100) shouldn't cost so much.  You can find it for $20 retail on pacificgeek.  The shipping is only $10 to San Francisco:
http://www.pacificgeek.com/product.asp?c=206&s=1689&ID=21450&P=F
As for the price of black alp switches, I'm not sure.  The switches may cost more or less than that of a used Dell AT101W (~$30 shipped)
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline MTManiac
  • Trade Count: (0)
« Reply #1615 on: Tue, 03 September 2013, 10:43:21 »
How much can I get for a set like this? There's no tenkeypad or arrow keys. Fits on MX, material looks like thick ABS doubleshot.
are you positive it 'fits' on cherry mx and isn't just a tiny bit too big and loose (insert ex gf joke BAM!)
if it's a Sears EC2 then you can mod them to work with mx pretty easily but they won't fit by default
Offline hashish
  • Trade Count: (0)
« Reply #1616 on: Tue, 03 September 2013, 11:43:50 »
How much is a Leopold with MX Blacks worth? TIA.
Offline pixel5
  • Trade Count: (0)
    • pixel5
« Reply #1617 on: Tue, 03 September 2013, 11:45:52 »
What model?
Poker II
Quickfire Rapid
BUY MY CRAP
Offline AuRinBei
  • Trade Count: (0)
« Reply #1618 on: Tue, 03 September 2013, 12:35:09 »
Does anyone know what a year old Ducky Shine 1 would be worth? It isn't damaged in any way, and the caps are in good condition. I'm having a hard time determining a value though, since the Shine 2 and 3 are now out. I would like to offer it to a friend at a low price, but not for less than half of what I could get for it. I never see any used ones floating around, so I don't know where to start.
87u || Poker 2
Offline IvanIvanovich
  • Mr. Silk Underwear
  • Trade Count: (0)
« Reply #1619 on: Tue, 03 September 2013, 12:45:35 »
Only big difference on the Shine1 reset the backlight brightness on each boot, probably worth at least 75% of the original cost still.
Offline AuRinBei
  • Trade Count: (0)
« Reply #1620 on: Tue, 03 September 2013, 13:23:37 »
Shine 1 doesn't have reactive lighting or programable lighting though. Do you think $60 would be too low?
87u || Poker 2
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
« Reply #1621 on: Tue, 03 September 2013, 13:26:49 »
I've seen full E-Dox kits w/o switches sell for about $150, which included, Case, PCB's, Teensy, Cables, Connectors, Diodes, etc.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline MTManiac
  • Trade Count: (0)
« Reply #1622 on: Tue, 03 September 2013, 17:31:06 »
If I could get a full e-dox kit w/o switches for ~$150 I believe my wallet would be hacked for $150-$450 pretty quick after
If you have a link for something like this, please PM me! I would be forever grateful
  • Trade Count: (0)
« Reply #1623 on: Tue, 03 September 2013, 18:08:32 »
What's a fair price for an IBM Model F AT (5170)?  I haven't tested it yet since I'm waiting on an AT to PS/2 Adapter, but what would be a fair price for it once I confirm it's working?  Overall, it's in good shape.  Not perfect shape, but definitely good shape.
It seems like the prices fluctuate wildly on these, so I'm having a hard time pricing it.
« Last Edit: Tue, 03 September 2013, 19:57:17 by nubbinator »
  • Trade Count: (1)
« Reply #1624 on: Tue, 03 September 2013, 21:19:13 »
$120-150 would not be at all out of line. You are right, they sell at random prices.
If it were mine, everything tested A-OK, and I had cleaned it up nicely, I would start at about $180 and drop the price about $20 about every 3 days until it sold.
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
  • Trade Count: (0)
« Reply #1625 on: Tue, 03 September 2013, 21:48:24 »
Welp, just tested it an it works 100% a-ok.  Had three caps seated wrong that had me worried, but once I seated them right, it seems to be all good.
In fact, I'm typing out this response on it right now.  I can see why people like them so much better than Model Ms. They're much heftier and better to type on.
Offline lilky
  • Trade Count: (0)
« Reply #1626 on: Wed, 04 September 2013, 18:38:23 »
I have someone offering me a white HHKB as shown here: http://i.imgur.com/jpSDt8p.jpg for $240. Is this a good deal?
Offline Ultratude
  • Trade Count: (0)
    • Ultratude's Blog
« Reply #1627 on: Wed, 04 September 2013, 18:49:58 »
You can buy a new one for $260 on EK if you can wait.
  • Trade Count: (0)
« Reply #1628 on: Wed, 04 September 2013, 19:13:42 »
+ tax + shipping, making it $290-300.  If it's $240 shipped and in good condition, it's a decent price.  Not amazing, but not horrible.
Offline Tennobanzai
  • Trade Count: (0)
« Reply #1629 on: Thu, 05 September 2013, 11:36:19 »
I believe the color is Octoberfest. I basically got this about 1 year ago.
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #1630 on: Thu, 05 September 2013, 11:41:38 »
That's a buckling spring Hack Orange.
Offline lcs
  • Lover of Grape Drank
  • Trade Count: (0)
  • はやく
« Reply #1631 on: Thu, 05 September 2013, 11:42:25 »
moose your new avatar confused me!
Offline Tennobanzai
  • Trade Count: (0)
« Reply #1632 on: Thu, 05 September 2013, 12:12:21 »
I believe you're correct
Offline CloseEnough
  • Trade Count: (0)
  • Poker II - Reds
« Reply #1633 on: Thu, 05 September 2013, 13:08:42 »
I'm new here so bare with me. I was thinking of selling my Ducky Shine 1 (Brown Switches, White LEDs), a leather Ducky wrist rest, and a Ducky keychain (Blue switch with orange Ducky key). Hopefully as one big group. The keyboard is in good shape with only a little over a year of use. I have everything that came in the box with the keyboard, but not the box. What do you guys think would be a reasonable price?
« Last Edit: Thu, 05 September 2013, 13:11:01 by CloseEnough »
Offline dante
  • Trade Count: (0)
« Reply #1634 on: Fri, 06 September 2013, 10:34:11 »
What would a brand new Ducky 9008G2 Pro Dyesub PBT be worth with only the numpad keys?
  • Trade Count: (0)
« Reply #1635 on: Fri, 06 September 2013, 10:39:15 »
What switch type?
Offline Tarzan
  • formerly known as Greystoke
  • Trade Count: (0)
« Reply #1636 on: Fri, 06 September 2013, 10:45:23 »
I think it depends on the switches.  Neither of the Ducky Pro models I have still have their stock keycaps.
Offline dante
  • Trade Count: (0)
« Reply #1637 on: Fri, 06 September 2013, 11:26:31 »
What switch type?
well since I'm going after the blue/gray pbt models - brown is out of it.  Only Blue/Black/Red are in stock.
So let's say red or blue since they are probably worth more by $5 or whatever.
Offline Tarzan
  • Trade Count: (0)
« Reply #1638 on: Fri, 06 September 2013, 11:46:58 »
What switch type?
Given those options, I'd choose the MX Black, but that's just preference.  I think there's been a resurgence of interest in Blues lately, seen several inquiries posted.
I'd think $80-$90 shipped for a naked board is a decent price, considering a PBT dye-sub cap set will start around $40.
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #1639 on: Fri, 06 September 2013, 14:24:17 »
SSK Industrial Shell?
  • Trade Count: (0)
« Reply #1640 on: Sat, 07 September 2013, 11:20:20 »
A brand new QFR (red/black/brown/blue) without the case?
Or more specifically SGK-4000-GKCC1-US model (blacks) with no case.
« Last Edit: Sat, 07 September 2013, 11:32:09 by SpAmRaY »
Offline pixel5
  • Trade Count: (0)
    • pixel5
« Reply #1641 on: Sat, 07 September 2013, 12:41:10 »
QFR's can be had at any given time for about $55 shipped from newegg/amazon/etc. I'd say $40 shipped for one with no case.
Poker II
Quickfire Rapid
BUY MY CRAP
  • Trade Count: (0)
« Reply #1642 on: Sat, 07 September 2013, 12:57:33 »
Hmm I don't know about any given time maybe one a month for a few days and usually only blues after rebates.  ::)
But I'd probably take $40 for it shipped without the case  :thumb:
Although maybe it would be more fun to desolder it.  :o
Offline pixel5
  • Trade Count: (0)
    • pixel5
« Reply #1643 on: Sat, 07 September 2013, 13:45:38 »
Browns and Reds:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823129005
http://www.newegg.com/Product/Product.aspx?Item=N82E16823129006
Poker II
Quickfire Rapid
BUY MY CRAP
  • Trade Count: (0)
« Reply #1644 on: Sat, 07 September 2013, 13:51:29 »
Browns and Reds:
Good to know, btw reds are sold out.
I think they coolermaster is trying to clear stock of the old boards.
And that deal on browns isn't bad since browns can be hard to find lately.
Offline remdell
  • Trade Count: (0)
« Reply #1645 on: Sun, 08 September 2013, 21:27:24 »
How much can I get out of a like-new Ducky Zero Shine with Blue LEDS and Cherry MX Blacks?  I'm getting it tomorrow for $75 just so I could try out MX Blacks for a few days.
Offline jwaz
  • * based mod
  • Trade Count: (0)
  • #geekhack on freenode
« Reply #1646 on: Mon, 09 September 2013, 11:16:20 »
90 clears?
Offline Tarzan
  • Trade Count: (0)
« Reply #1647 on: Mon, 09 September 2013, 11:17:18 »
104 MX Blues?
Edit: used - and PCB mounted.
« Last Edit: Mon, 09 September 2013, 11:46:47 by Greystoke »
  • Trade Count: (0)
« Reply #1648 on: Mon, 09 September 2013, 11:44:22 »
90 clears?
used or new?
plate or pcb mount?
  • Trade Count: (0)
« Reply #1649 on: Mon, 09 September 2013, 11:49:37 »
I generally sell used switch for $.40/ea, or I make breaks for common quantities like 61, 87, 101, 104 taking couple $ off. It seems something around this is general consensus for most sellers.
