Author Topic: Price Check- What's it Worth?  (Read 4321097 times)
0 Members and 6 Guests are viewing this topic.
Offline Fii
  • Trade Count: (0)
Re: Price Check- What's it Worth?
« Reply #7450 on: Tue, 21 March 2017, 18:21:37 »
I have an open but unused GMK 3Run + Standard extras kit (put on keyboard, but then decided to sell that keyboard so took it back off). I've only seen like 2 or 3 listings for 3Run around so far, and I'm not sure how much opening the kit devalued it. What could I list it for?
Offline Wingklip
  • Trade Count: (0)
  • I am the one the one the one the one the one
« Reply #7451 on: Tue, 21 March 2017, 23:55:59 »
163645-0
Topre ML0100 IBM Model M layout variforce?
I heard it was from 2003 and quite rare being the first series ever made by topre
If you 1v1 me in a cage fight I will use an AK-74 for ranged and an IBM model F 122 for melee
  • Trade Count: (0)
« Reply #7452 on: Wed, 22 March 2017, 12:01:26 »
Dude, you gotta fix your monitor or camera. Like,
c'mon.
  • Trade Count: (0)
« Reply #7453 on: Wed, 22 March 2017, 12:05:24 »
I think it's worth ~$95 and the left shift looks a little crooked.
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #7454 on: Wed, 22 March 2017, 13:31:48 »
c'mon.
Hard pink Topre: Awesome.
White balance so bad it looks pink... Not so much.
|||My other keyboards :
x
Offline _Tobias
  • Trade Count: (0)
« Reply #7455 on: Wed, 22 March 2017, 16:20:40 »
I bought a dead CM Storm Novatouch TKL with Topre switches from another geekhack member. I believe the microcontroller or another chip is defective. I've tested the basic stuff: no broken wires, voltage all across the board, no loose components or dried soldering. I've tried starting it in BSL mode, but no luck there. I've tried connecting it to my Linux Mint desktop and Windows laptop, both through a hub and directly. The device simply does not show up. The microcontroller heats up though. TL;DR not a trivial problem. It has original caps on it.
I would like to try to rewire the keys using a Teensy, however, before I attempt this, I'd also like to know what I could get for the keyboard if it were functional AND programmable. There is quite some information available on this keyboard: http://vekkt0r.github.io/articles/novatouch-tkl-reverse-engineering-part-1/ Writing or modifying software shouldn't be an issue since I'm quite familiar with programming.
So my questions are:
- How much could I still get for the keyboard in this state?
- How much could I get for it if it were functional and programmable?
Thank you in advance!
Offline cribbit
  • Trade Count: (0)
« Reply #7456 on: Wed, 22 March 2017, 19:36:01 »
If you do this do it for the fun and experience, don't expect to make any money. You're not going to be able to get more than retail price and will spend a ton of time on it.
The value of it as-is will be just about 30% less than the price of selling the switches in it on their own, desoldered. Shipping cost eats into this greatly, especially being a TKL and thus fewer switches.
Programming the teensy won't be your issue, getting the wiring working will be. You'll need to figure out how the PCB routes the rows and col and then figure out a way to intercept these paths to wire to your teensy instead. Fun as a project, but it'll be a lot of work. There's also no guarantee it will work. If this fails the only way to get it working will be to desolder the PCB and either put your own on or handwire it. Extensive use of a multimeter to verify the integrity of the PCB is going to be required.
In terms of creating a working board, you'll find it more time efficient to mow lawns, buy a plate, switches, PCB and case and build one from scratch.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
  • Trade Count: (0)
« Reply #7457 on: Wed, 22 March 2017, 21:19:31 »
The novatouch is a topre board so no desoldering just disassembly to part it out and the topre mechanism is more a sandwiched assembly and not a discrete switch like mx.
That being said some people might still be interested in buying just the MX compatible topre stems. Not sure what they go for price wise though.
Offline Floody
  • Formerly Flood
  • Trade Count: (0)
  • But is it?
« Reply #7458 on: Thu, 23 March 2017, 00:53:40 »
Three Kings Brobot?
Offline foxtrott
  • Trade Count: (0)
« Reply #7459 on: Thu, 23 March 2017, 14:36:39 »
very good conditions; very heavy; but NO working cable  :blank:
What is this Triumph Adler worth?
« Last Edit: Thu, 23 March 2017, 14:38:36 by foxtrott »
Offline alienman82
  • Trade Count: (0)
« Reply #7460 on: Thu, 23 March 2017, 14:50:37 »
removed.
« Last Edit: Thu, 01 March 2018, 13:02:12 by alienman82 »
Offline Venatorious
  • Trade Count: (0)
  • Gotta Start Somewhere
« Reply #7461 on: Thu, 23 March 2017, 17:19:20 »
Price check on my Filco Zero pretty please? Some shine on keys with the manufacturer seal intact
« Last Edit: Thu, 23 March 2017, 17:21:26 by Venatorious »
Offline ghostdeini
  • Trade Count: (0)
« Reply #7462 on: Fri, 24 March 2017, 17:44:51 »
Duck Pie Skullthulu anyone? I like the color, but do I have <0% chance of hunting one down?
Offline iamtootallforthis
  • Something a lot Funnier
  • Trade Count: (0)
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #7463 on: Fri, 24 March 2017, 18:18:05 »
I believe there is only one or two of them.
  • Trade Count: (0)
« Reply #7464 on: Fri, 24 March 2017, 18:22:52 »
Price check on slightly used blue lettered Realforce 104 set they used to sell on EK years ago. Are people still looking for these?
  • Trade Count: (0)
« Reply #7465 on: Fri, 24 March 2017, 18:27:55 »
At least $100 maybe more, topre sets are hard to come by.
Offline ghostdeini
  • Trade Count: (0)
« Reply #7466 on: Fri, 24 March 2017, 19:01:23 »
Ah thank you, I'd heard this but wanted to know if it was really that low. I'll cross my fingers that it winds its way across my desk in its great journey through the cosmos.
Offline KnivesM
  • Trade Count: (0)
« Reply #7467 on: Fri, 24 March 2017, 20:19:30 »
Just the Skullthulus though as they're usually the pretty limited right?
Others
  • Trade Count: (0)
    • WTB/WTTF Thread
« Reply #7468 on: Fri, 24 March 2017, 20:21:37 »
All caps in that colorway are 1 or 2 of IIRC
Offline KnivesM
  • Trade Count: (0)
« Reply #7469 on: Fri, 24 March 2017, 20:24:33 »
Cool, didn't know that colorway was that rare.
Others
  • Trade Count: (0)
    • WTB/WTTF Thread
« Reply #7470 on: Fri, 24 March 2017, 20:25:37 »
Yep it was really limited.
Offline zooksman
  • Trade Count: (0)
« Reply #7471 on: Sat, 25 March 2017, 01:38:26 »
Looking for a price check on a silver logo 88 Model M (1390131). I haven't opened it up to check for any broken rivets, but otherwise everything is in good condition, except a few scratches on the housing. It hasn't been cleaned yet, though :P Also, is it plausible that someone would trade this for a Model F PC/AT (or even the terminal one)? I'd like to try the capacitive buckling springs, and the 2KRO on this one gets to me sometimes.
Offline meiosis
  • Trade Count: (3)
  • Time
« Reply #7472 on: Sun, 26 March 2017, 21:28:05 »
DKSaver with Green Alps?
Keyboards:
Aripeko TKL
Offline ArchDill
  • Trade Count: (0)
« Reply #7473 on: Sun, 26 March 2017, 22:34:01 »
FMJ case with Poker inserts?
Offline Psybin
  • of Rallos Zek
  • Trade Count: (0)
« Reply #7474 on: Mon, 27 March 2017, 07:07:29 »
I dont recall what I paid for it, it wasn't with the original group buy.
GirlDC gold punisher
Offline fknraiden
  • Trade Count: (0)
« Reply #7475 on: Tue, 28 March 2017, 17:16:26 »
Realforce YF110S domeswapped with U55G, like new
Offline digi
  • elite af tbh
  • Trade Count: (0)
  • keyboard game on fleek
« Reply #7476 on: Tue, 28 March 2017, 17:17:52 »
$325
Offline Chronnoisseur
  • Trade Count: (0)
« Reply #7477 on: Wed, 29 March 2017, 12:33:49 »
Bro Power core FPS gamer set?  Anyone know how much I should expect to pay for this?  Just the 6 keys, WASD, Fn & Esc
  • Trade Count: (0)
    • WTB/WTTF Thread
« Reply #7478 on: Wed, 29 March 2017, 12:37:00 »
It was $125 from the sale and that is including the Power Core Bot. Don't know aftermarket pricing though
  • Trade Count: (0)
« Reply #7479 on: Wed, 29 March 2017, 12:48:26 »
Thanks, as usual :)
Offline catawalks
  • Trade Count: (0)
« Reply #7480 on: Wed, 29 March 2017, 19:30:46 »
I've got a BNIB Focus FK-2001 with white ALPS (I have not taken them apart to see if they are clones or SKCM switches, definitely not 4 tabs though), dust cover hinges included but no dust cover. Any idea's what it's worth?
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #7481 on: Thu, 30 March 2017, 05:10:49 »
Ivan's Round 3 Black on Black Dyesub?
x
  • Trade Count: (0)
« Reply #7482 on: Thu, 30 March 2017, 09:50:46 »
NOTHING.
HIS NAME MEANS NOTHING.
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #7483 on: Thu, 30 March 2017, 13:38:14 »
NOTHING.
I got burned in his Miami Nights GB + CMYK v2 too. :(
x
Offline quochung1989
  • Vintage Cherry Collector
  • Trade Count: (0)
  • Frenzy Classic.
« Reply #7484 on: Thu, 30 March 2017, 20:06:16 »
GB price was 75$, so I think it's worth 90-100$.
  • Trade Count: (0)
« Reply #7485 on: Thu, 30 March 2017, 20:15:44 »
Depends on buyers opinion of Ivan, I'd say.
Some would say nothing, but I paid $75 and shipping for a similar set recently. Given that IMSTO is better than Gateron, I'd say $80-90 is fair.
  • Trade Count: (0)
« Reply #7486 on: Thu, 30 March 2017, 20:51:36 »
imsto uses Gateron caps now.
  • Trade Count: (0)
« Reply #7487 on: Thu, 30 March 2017, 21:06:07 »
I don't think he did for Ivan R3.
Offline user 18
  • Trade Count: (0)
« Reply #7488 on: Thu, 30 March 2017, 22:26:48 »
R3 caps came from plum IIRC. But I also seem to recall something about plum caps being the same as gateron.
I know the caps in question are scoop+bar homing, if that helps narrow it down. Don't know of many manufacturers that make that style of homing key.
Avatar by ashdenej
Offline KnivesM
  • Trade Count: (0)
« Reply #7489 on: Thu, 30 March 2017, 23:11:15 »
I thought R3 was the first set he used Gateron on?
Edit:Did some digging and found this (Ignore dates as the thread is locked and I had to put together the quotes)
Oh I know but the wait time would be immense. I will be in the Dark Wave GB for sure regardless.
Ivan is using a different manufacturer for the new round (Gateron) and he said he expects the turnaround time to be much shorter.
It's the same manufacturer actually... just now dealing with them directly instead of through a 'wholesaler' middle company which caused all the dumb delays on this one.
I have AVAILABLE:
3x sets of blanks
So Plum was a wholesaler of Gateron.
« Last Edit: Thu, 30 March 2017, 23:39:45 by KnivesM »
Others
Offline ComradeSniper
  • HHKB Pro
  • Trade Count: (0)
« Reply #7490 on: Fri, 31 March 2017, 00:53:16 »
Topre yellow/orange blank keycap sets?
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #7491 on: Fri, 31 March 2017, 01:57:30 »
I have AVAILABLE:
3x sets of blanks
That's some excellent detective work. I think I'll go for $80 + shipping then.
Thanks everyone. :)
x
Offline NguyenAdam
  • Trade Count: (0)
« Reply #7492 on: Fri, 31 March 2017, 03:19:40 »
Filco Majestouch 2 104 w/ browns. Keys are worn out so they will need new keycaps.
Offline alienman82
  • Trade Count: (0)
« Reply #7493 on: Fri, 31 March 2017, 12:14:15 »
removed.
« Last Edit: Thu, 01 March 2018, 13:01:39 by alienman82 »
Offline Philister
  • Trade Count: (0)
« Reply #7494 on: Fri, 31 March 2017, 13:26:26 »
Ahoi there,
looking to sell this as it is rather disgustingly yellow and reeks of smoke, even though it is the only vintage blues board I have and I would love to keep one around, but it is only really good for the switches. Caps are ABS, partly double-shot but have also turned disgustingly yellow so not really worth much, I suppose. Really it probably boils down to what the 102 vintage blues are worth...
All keys, caps, LEDs, feet and the cable are fully intact, it is a joy to type on, except for having smelly fingers afterward.
Here's how someone else described this board:
From the sticker:
    brand: AUVA
    FCC ID: HWI-A2-KB21012 (manufacturer is A2 Technology Co., Ltd.)
    made in Thailand
Case features tiles between inverted-T arrow cluster and navigation sixkey, just like Chicony KB-5191, but the sides aren't protruded. There's an AT-XT switch under one foot; feet aren't rubberized. The case is held together by three screws on the bottom. Four green indicator diodes are above the tenkey, surrounded by a dark-grey black-framed sticker with two-line labels.
There's no plate. Genuine (vintage) Cherry MX Blue switches are PCB-mounted, and so are Cherry stabilizers. Big-ass/AT Enter is stabilized using one horizontal stab (2x) and an extra stem on the top.
1x keycaps are doubleshot, the rest is printed. Profile is OEM (with number-row profile on the function row), thin/medium thickness ABS.
At last but not least, the PCB is among the cleanest I've ever seen, along with outstanding soldering quality.
The layout is 102-key ISO-DE w/ big-ass/AT Enter and 1x Backspace.
Thanks for any pointers!
Offline PastelSkies
  • Trade Count: (0)
« Reply #7495 on: Fri, 31 March 2017, 13:38:02 »
New DSA Hana base kit?
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #7496 on: Fri, 31 March 2017, 13:56:16 »
Ahoi there,
From the sticker:
    brand: AUVA
    made in Thailand
Sounds like classic Cherry. Are the stabilizers screw-in?
x
  • Trade Count: (0)
« Reply #7497 on: Fri, 31 March 2017, 14:21:12 »
$75?
I'd list it for $120 but I'd take $100 for it. 104s don't go as quickly as TKLs.
I wouldn't sell my pink one with legends for under $250, and I don't even have the numpad to go with it.
So at least $250.
  • Trade Count: (0)
« Reply #7498 on: Fri, 31 March 2017, 14:32:05 »
Booper Lv426 Kosmo in topre?  Any idea on a price?  Think I could trade it for a keywok?
Offline Floody
  • Formerly Flood
  • Trade Count: (0)
  • But is it?
« Reply #7499 on: Fri, 31 March 2017, 14:35:28 »
Someone tried selling it at 500 and no bit it seems. Might have a hard time trading it since people tend to want other Booper stuff for Keywoks plus it being topre.
« Last Edit: Fri, 31 March 2017, 14:38:39 by Floody »
