Author Topic: [IC] Red on white sp double-shots?  (Read 69235 times)
Offline tsangan
  • 1000/600
« Reply #300 on: Sun, 03 June 2012, 17:45:42 »
Quote from: Rafen;606395
I would love to have a set of pbt's that are like the red alert including the red modifiers. If you are doing that count me in.
Quote from: Ragnorock;606409
For the 30th time, you can't dye sub white onto a red PBT key. That won't ever happen...
We're still on that? :rofl:
Legend colour needs to be darker/more vibrant then keycap colour in order for it to show up
Keyboardless
Offline dsjbirch
« Reply #301 on: Sun, 03 June 2012, 17:50:44 »
Quote from: Ragnorock;606853
Also I had an idea this morning for a different than RA red on white set that, while in the early stages of planning, should be enough to make everyone who wasn't satisfied with doubleshot Red Alert, happy as hell when it shows up later this year. It will be PBT dyesubs, which means no white on red mods, and probably no red on grey mods either (though I might toss them in for fun since you guys love them so much) but it will have something else I can't say yet that should have everyone wiggling with excitement for.
/mysterious post
Dave out
Will it be red on PBT WFJ or tie-dye?
'Cause if it's tie dye, I'm totally out.
« Last Edit: Sun, 03 June 2012, 17:55:34 by dsjbirch »
Offline Ragnorock
  • Group Buy Guy
« Reply #302 on: Sun, 03 June 2012, 18:39:21 »
Eew, tie tye, yuck.
No. It won't be on Tie dye, it'll probably be on WFJ to match my other sets.
Offline dsjbirch
« Reply #303 on: Sun, 03 June 2012, 20:29:27 »
+1 for wfj!
How close a match is the abs white in the red alert buy to pbt wfj?
Offline Ragnorock
  • Group Buy Guy
« Reply #304 on: Sun, 03 June 2012, 20:42:33 »
It should be really close. I asked Melissa about it and I think that is what they use for the ABS spacebar that goes with the WFJ keysets. My goal is the closest matct to WFJ as possible in ABS.
