Author Topic: Filco and coffee, good combination? You decide...  (Read 3728 times)
Offline ironcoder
« on: Tue, 29 May 2012, 09:33:08 »
Well I never did this before...today.
Cup of coffee all over one of my Filcos. Into the shower until the water ran mostly clear but now 6 hours later it's dead when I plug it in.
How do I remove the back from this keyboard? I already unscrewed the one screw under the "Do not remove" label and that seems to have done nothing. Thanks.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Tue, 29 May 2012, 09:41:15 »
Also, plugging it in 6hrs after a cold shower is likely to have killed it even if the coffee didn't. If you give electronics a bath you need to make sure they are thoroughly dried before applying power.
Filco w/ Imsto thick PBT
Offline ironcoder
« Reply #3 on: Tue, 29 May 2012, 09:43:13 »
Thank you.
Offline ironcoder
Offline ironcoder
« Reply #5 on: Tue, 29 May 2012, 09:45:09 »
Quote from: alaricljs;602760
"But it seemed like a good idea at the time."
Offline ironcoder
« Reply #6 on: Tue, 29 May 2012, 09:45:28 »
Quote from: ripster;602762
Link added to Ripster Repair Guide.
http://geekhack.org/showthread.php?31198-Ripster-s-Switch-Repair-Guide-For-Cherry-MX-Topre-and-Buckling-Spring&highlight=open+filco
Ripster, you're still here! Thanks for the help.
Offline ironcoder
« Reply #7 on: Sun, 10 June 2012, 06:28:23 »
This is fixed! Thanks guys. Two thumbs up to the Filco team. You are very flood resistant.
Offline ironcoder
« Reply #8 on: Sun, 10 June 2012, 12:08:15 »
Oh well, spoke too soon. Not fixed. Does some very wierd things. Works then doesn't work.
How much is a flaky Filco Tenkeyless with coffee damage worth on the geekhack market today?
