Author Topic: CALLING ALL MODDERS! repairing and modding headphones  (Read 7342 times)
Offline Arexxk
  • Algebraic!
    • Blog mehs
« on: Thu, 31 May 2012, 21:35:02 »
Hey guys,
[ Attachment Invalid Or Does Not Exist ] 51962[/ATTACH]
I recently purchased a pair of Aiaiai Tracks and recently broke them. I love these headphones but the cable design was a disaster waiting to happen. It has this awkward anti-tangle Y-connector where the cables split, and the cable itself was wayy too long (snagging on practically everything). So basically, snags occurred, and the cable and it ripped out from the Y-connector. The company said that all they could offer was a discount on a replacement pair, which I'm not really inclined on doing since I'll be stuck with another pair of headphones with crappy cables. So, I hoping to repair/mod these.
My initial goal was to add headphone jacks on both cans to the headphones much more of a modular design. That way if someone wanted to walk around with no intention to listening to music they could do so without worrying about cables snagging. This is similar to the Grado mod that I guess is pretty popular among modder/audiophile group:
[video=youtube;0JHGJqfM0wE]http://www.youtube.com/watch?v=0JHGJqfM0wE[/video]
http://gilmore2.chem.northwestern.edu/projects/showproj.php?file=grado_add_prj.htm
However, after further investigation, I'm starting to get worried that the Tracks do not have space for a 3.5mm jack, like this: http://www.amazon.com/3-5mm-Stereo-Panel-Mount-Jack/dp/B000ML4A2Q/ref=sr_1_fkmr0_3?s=electronics&ie=UTF8&qid=1338515202&sr=1-3-fkmr0
[ Attachment Invalid Or Does Not Exist ] 51989[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 51990[/ATTACH]
I was hoping to get some opinions on what I should do. Do you think there's room to fit a jack? Or should I ditch this idea and just try to re-solder new cables? The idea of modular cables is kindve neat actually. Think if almost all nodes on your headphone cable could be disconnected, then you could mix and match all these below:
http://www.amazon.com/3-5mm-Stereo-Male-Female-inch/dp/B000I98ZYG/ref=sr_1_17?s=electronics&ie=UTF8&qid=1338242853&sr=1-17
http://www.ebay.com/itm/25ft-braided-stereo-3-5mm-AUX-IN-cable-lead-mp3-mp4-/390330725384#ht_3338wt_922
http://www.amazon.com/Replacement-Audio-Control-Studio-SoloHD/dp/B006NGHN5A/ref=pd_rhf_se_shvl1
http://www.amazon.com/Replacement-Detox-Headphone-Headphones-Monster/dp/B007CZNS0U/ref=sr_1_3?s=electronics&ie=UTF8&qid=1338243038&sr=1-3
« Last Edit: Fri, 01 June 2012, 00:14:06 by Arexxk »
PBC Poker 40% Cherry MX Blues - Stolen in the stupid CS labs
HHKB Pro 2 Topre OBV - Still kickin
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Thu, 31 May 2012, 21:37:45 »
Those things are tiny, you will not fit a panel mount 3.5mm jack in an appropriate position or location on those.
Best bet is to just re-wire them without connectors.
Filco w/ Imsto thick PBT
Offline lorem3k
    • http://twitter.com/#!/lorem3k
« Reply #2 on: Thu, 31 May 2012, 22:45:16 »
You COULD somehow fasten (hot glue, maybe) the 3.5mm jack on the button that holds the earcups to the headband. Something similar to the HD25-1 II.
[ Attachment Invalid Or Does Not Exist ] 51981[/ATTACH]
I'd get this one, since it's flat, it'll be easier to attach.
http://www.radioshack.com/product/index.jsp?productId=2103451
Leopold FC200RT/AWN | Logitech G400 | Sennheiser HD25-1 II | Pounds in the fridge, hundred stacks in the armoire
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Thu, 31 May 2012, 23:19:08 »
You could just have a wire with 2-3" of cable hanging out and put a 3.5 female jack their. Not the best looking but it would work
Offline lorem3k
« Reply #4 on: Thu, 31 May 2012, 23:20:40 »
Quote from: The_Beast;605280
That could still get ripped off and then he'd have to do it over.
Offline Arexxk
  • Algebraic!
    • Blog mehs
« Reply #5 on: Fri, 01 June 2012, 00:17:09 »
I just added more pictures. I want to disassemble them further but I'm not seeing any screws and that sort of worries me. Another thing I was thinking was using a 2.5mm jack and then just use an adapter. However, I'm not sure if that ends up degrading the sound quality. Does it look like a 2.5mm would fit?
Offline lorem3k
« Reply #6 on: Fri, 01 June 2012, 00:28:27 »
I don't think anything would fit in there. Another advantage to putting the plug on the outside like I suggested is that you wouldn't need to drill the hole in the housing out to accommodate the plug.
Offline modulor
« Reply #7 on: Tue, 12 June 2012, 16:10:45 »
Quote from: lorem3k;605252
(Attachment Link) 51981[/ATTACH]
These jacks are cool because they can divert the connection when nothing is plugged in - I used one in my stock car stereo to switch between FM and Auxiliary Input.  However, it's pretty loose, so I'm not sure it would hold very well on headphones.  These are a bit small for a rewire, but it's possible (but will probably be difficult because the wires are likely coated).  If you do end up looking into another pair of similar cans, I'd suggest checking out Koss Portapros :thumb:
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-1000HBU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
