Author Topic: Realistic assessment of prototyping an aluminum case for 87U?  (Read 2577 times)
Offline swi7z3r
Assuming I'm willing and capable of getting all the measurements into a vetted CAD file to take down to my local metal sliceary.  What sort of cost should I expect to have them sell me, and then cut and bend two halves of suitable sheet aluminum?
I figured the cheapest design would be just a CNC cutout on two flat sheets, then roll the top and bottom edges to meet.  The east and west openings would then be fitted with two 'plugs' after final fit (also a great place to add some external USBs).  For mounting i'd shim up lower internal supports for the board from scraps, then fuse them with some type of chemical bonder.  A bit of countersinking, some fine machine screws, and some rubber grometing and we're in business.
Anyone have experience doing this? Any pitfalls you'd like to re-state?  Thanks in advance.
EDIT: sorry, i locked the thread like a chump. All better now.
for an idea of what I'm after check out this video:
[video=youtube;hb7P4JDn7Es]http://www.youtube.com/watch?v=hb7P4JDn7Es[/video]
« Last Edit: Sun, 03 June 2012, 03:57:00 by swi7z3r »
Offline tsangan
  • 1000/600
« Reply #1 on: Sun, 03 June 2012, 11:39:38 »
So you're after this case?
Keyboardless
« Reply #2 on: Sun, 03 June 2012, 13:27:55 »
If you're cutting all the way through the sheet, it might be cheaper to get it water-cut instead of CNC.
Offline swi7z3r
« Reply #3 on: Sun, 03 June 2012, 17:01:51 »
Quote from: tsangan;606698
GAH!!!!!  /WANT!!
How, Where?
Offline funxion
« Reply #4 on: Sun, 03 June 2012, 17:11:30 »
Ew...that looks gross. I can't stand the extended wrist platform and the extra space at the top and sides...
Crush80
Filco MJ2 TKL
Offline Gawkbasher
« Reply #5 on: Sun, 03 June 2012, 17:14:47 »
Group buy version plox.
Top face MUST have a Laser-cut Realforce logo in the metal. ;)  (Realizing that's probably not legal. :()
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Sun, 03 June 2012, 23:14:43 »
Quote from: swi7z3r;606847
GAH!!!!!  /WANT!!
How, Where?
taobao. ping our girl lin of en-taobao or qtan apparently.
« Last Edit: Mon, 04 June 2012, 19:31:32 by mkawa »
Offline keyboardlover
« Reply #7 on: Mon, 04 June 2012, 12:43:52 »
I hate that taobao case. Would def be interested in a normal size case though.
Offline Enki
« Reply #8 on: Mon, 04 June 2012, 13:25:33 »
I'm curious, how much does this sort of one-off thing tend to cost?
Filco TKL | Noppoo Choc Mini | KBC Poker (ghetto)
