Author Topic: Filco TKL MX Blues to Amazon?  (Read 7409 times)
Offline vurt
  • achiever
    • j-beck.net
« on: Tue, 05 June 2012, 20:03:00 »
Hello. I am just wondering when/if there will be more stock of the TKL models of Filcos on the Amazon store in the foreseeable future. This would include the standard MJ2 and/or the Ninja models. Thanks in advance for any info you can provide!
Filco MJ2 Ninja | IBM Model M 1391401
Offline Bruce
  • * Moderator
    • http://www.keyboardco.com
« Reply #1 on: Fri, 08 June 2012, 08:55:11 »
Hi Vurt
Yes, we're keeping Amazon stocked up as well as we can. There was a delay (or two) with this latest shipment but I posted the details here.
http://geekhack.org/showthread.php?30747-USA-Amazon-Shipment-May-2012
Let me know if I can help.
Offline itznfb
« Reply #2 on: Fri, 08 June 2012, 10:26:04 »
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #3 on: Fri, 08 June 2012, 11:02:04 »
Quote from: itznfb;609752
There are Camo ones available on Amazon: http://www.amazon.com/Filco-Majestouch-2-Keyboard-FKBN104MC-EMU2/dp/B005J93AGI/ref=sr_1_13?s=electronics&ie=UTF8&qid=1339168928&sr=1-13
I wish there was a White MX Red available.
Good news for you itz! White MX Red is in the shipment on its way to amazon. Expect it to show up on June 15th or so.
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline itznfb
« Reply #4 on: Fri, 08 June 2012, 12:34:30 »
I'll be looking for it! Thanks for the heads up :happy:
Offline Bruce
  • * Moderator
« Reply #5 on: Mon, 18 June 2012, 05:08:27 »
Hi asdf
We put in a fair amount of stock but it can be unpredictable. There seems to be a lot of interest in the Blue Switch at present so may be worth getting in early if you can.
Thanks.
Bruce
