Author Topic: Is this a normal price for this keyboard?  (Read 3034 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Tue, 05 June 2012, 20:10:14 »
I want to get one of my friends a mechanical keyboard. He is a near pro FPS gamer, and prefers slim keys. It was my preference for fps gaming for a while too, until I got my poker.
Anyways, is this a good price for the G84-4110? I usually see them around for like $80ish dollars. same does for the ones with the little space bar.
http://www.ebay.com/itm/Original-Cherry-Slim-POS-PS-2-PC-Keyboard-4100-Series-ML4100-PN-G84-4100PRAUS-/280876930614?pt=PCA_Mice_Trackballs&hash=item416591d636#ht_1500wt_1397
Offline bazemk1979
« Reply #1 on: Tue, 05 June 2012, 22:09:14 »
G84 does not have mechanical switches, I believe the G80's go for $80 ish and you can find them much cheaper, the G80's are the only mechanical ones from cherry made family boards
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #2 on: Tue, 05 June 2012, 22:36:51 »
If your friend likes slim profiles, he might like the Cherry G80-3800. It's around the same price, and mechanical.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
« Reply #3 on: Tue, 05 June 2012, 23:46:16 »
I thought these had Cherry MLs, mechanical, but not a favorite of many geekhackers for various reasons.
Offline MMB
« Reply #4 on: Wed, 06 June 2012, 01:00:35 »
Quote from: Lethal Squirrel;608240
I have one new-in-box, and I paid $40. So I dunno how used that one is, but I think it's an ok price judging from the photo. It takes a bit to get used to typing on the low profile keys. Kind of uncomfortable after long periods of typing.
Good for a mechanical keyboard on the go. It's quite portable.
Offline MMB
« Reply #5 on: Wed, 06 June 2012, 01:01:28 »
Quote from: bazemk1979;608294
These use Cherry ML switches, and are mechanical, low-profile, tactile switches:
http://deskthority.net/wiki/Cherry_ML
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Wed, 06 June 2012, 01:10:20 »
Quote from: Quarzac;608301
i thought we had some pretty negative reviews for these around here..
  • I <3 60%
« Reply #7 on: Wed, 06 June 2012, 01:15:39 »
The G84 does have mechanical switches. Cherry ML's.
I had one for a while.
  • I <3 60%
« Reply #8 on: Wed, 06 June 2012, 01:16:51 »
Offline AngryRant
« Reply #9 on: Wed, 06 June 2012, 05:38:37 »
Quote from: Lethal Squirrel;608367
Yeah, I can confirm that too. Although the keyboard itself isn't very comfortable.. bwin ipad
Offline nar
« Reply #10 on: Wed, 06 June 2012, 23:44:03 »
If your friend likes slim keys, how about the Topre HE0100? I like slim keys which is why I got it, love it for gaming (The JP layout and PS/2 port may be a problem for your friend though). There's a used one going on Taobao right now for 800RMB too, pretty much the cheapest topre you'll be able to find.
Better yet, if your friend has been using scissor switches all this time, the Topre will feel very similar, just much better.
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
« Reply #11 on: Thu, 07 June 2012, 09:47:35 »
I paid about $20 for mine, but it has dyesub PBT keys (So they're beige).
Also, it's great if you don't like key travel. I use it all the time when I take my laptop travelling. The biggest issue is awful key rollover and it does tend to bind a bit if you hit off axis.
Offline nar
« Reply #12 on: Thu, 07 June 2012, 12:56:16 »
Quote from: dorkvader;609121
Awful key rollover? I'm using it with a bluecube USB converter right now and I'm getting 5KRO which is the bluecube's limit.
Offline Quarzac
  • A very busy dude!
« Reply #13 on: Thu, 07 June 2012, 16:02:00 »
Quote from: mkawa;608361
The build quality is not terribly well regarded. But I think they probably work. I wouldn't recommend them normally, but I definitely would over G84s.
Offline AngryRant
« Reply #14 on: Tue, 12 June 2012, 05:37:23 »
G80 is a better choice than G84 for sure! bwin bonus 50
