Author Topic: Dell SK-8000 Quietkey  (Read 4670 times)
Offline noir
« on: Fri, 08 June 2012, 17:12:42 »
Ok, so I've read a bit about them and it got me interested.
They're supposedly superb membrane keyboards, but the quality depends on where it was made.
I heard that the made in China's one's suck while the made in Taiwan one rocks.
What I'm wondering about is if anyone tried the made in Malaysia ones?
Also. semi-off topic. But has anyone else heard of any good membrane keyboards?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #1 on: Fri, 08 June 2012, 17:37:44 »
The Dell KB1421 is pretty decent for a dome switch IMO, but some people here hate it.
The tactile feel is similar to Topre, but with the usual rattle and scrape of cheap domes instead of Topre's smooth, fluid keystrokes.
Even Topre is pretty squishy and rubbery after using Cherry though.
Bore Awards
Offline aegrotatio
« Reply #2 on: Fri, 08 June 2012, 21:35:17 »
I'm mystified.  There is nothing overtly unusual about these rubber-dome keyboards, except that certain models of them made from 2004-2008 are rather pleasant to type on.  These early "slimline" Dell OEM keyboards that came out which have the heavily sculpted Windows/Alt/Space keys and very thin bezels stand out as good rubber dome keyboards.  They're usually marked SK and are manufactured by the famed keyboard maker from the old days known as "NMB."
Models made later than 2008 may or may not be NMB-made, so the quality of those is touch-and-go.  The 2004-2008 models are usually NMB and are good keyboards for being rubber-dome keyboards.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
  • RIP
    • Boring twaddle
« Reply #3 on: Sat, 09 June 2012, 09:00:42 »
When people here say "Quietkey" they're referring to old beige keyboards, which the SK-8000 is. I had a beige 105-key Dell rubberdome that was pretty decent – no idea on the model number as it wore out and died. That one had carbon-coated domes, probably over an actual PCB instead of membranes, as I took it apart once to clean it as part of an increasingly futile attempt to keep the one good keyboard I'd ever had, working. (OK, blue ALPS notwithstanding.)
The slimline sculpted models include the SK-8115 ("midnight grey") and L100 (jet black). I find both prone to emitting a horrid rattling noise, and while the SK-8115 is light but gritty, the L100 keyboard is stiff and gooey. Neither keyboard is worth bothering with, and the KB1421 is a significant improvement all round.
Bore Awards
