Author Topic: It's in the mail...  (Read 3067916 times)
Offline noobas4urus
  • Mod Munky of another realm
    • The Mod Zoo
Re: It's in the mail...
« Reply #11050 on: Tue, 11 October 2016, 12:24:09 »
Night Caps come today and I've got PC water cooling supplies and sleeving stuff en route as well.
man, I wanna try watercooling at some point.
I've done a few custom loops for product reviews I've done but this is my first personal loop. I'm pumped to get it up and running!
"You miss 100% of the raffles you don't enter."
-Wayne Gretzky
Offline kawasaki161
« Reply #11051 on: Tue, 11 October 2016, 12:46:51 »
Short version: Not worth it, but I know you will do it anyways.
Explanation plus little rant:
Modern CPU coolers (even the 40 Euro ones) are really silent and have enough cooling power for everything you might throw at them. GPU's are a different thing, watercooling GPU's really does improve both Temps and noise a lot, the thing is, to get a watercooling setup done in a way that it is not louder than a good aircooled setup at idle costs a lot of work and money. There is so much stuff  you could spend the money on instead that would make a lot more of a difference. But, once you go watercooled you don't really want to go back, even if it doesn't make much of a difference it looks way too fancy to not keep it.
Also, if you ever have to change your GPU you'll have to pay for a new waterblock for it (if it is a different model), but more importantly you have to drain the whole System which I find really annoying. I still miss my HD7970 (RIP), the GTX970 could never replace it and performs worse in a few cases, so I never went the extra mile kilometer (and 200 Euros) to grab a waterblock and backplate for it, now I'm stuck with a watercooling setup that is overkill (I'm talking 240x120x60 and 360x120x60 rads) for just my CPU and limits airflow too much to achieve good GPU temps.
Offline noobas4urus
    • The Mod Zoo
« Reply #11052 on: Tue, 11 October 2016, 20:57:28 »
I agree with you on many points.  Considering CPU cooling, look at the gold standard the CM Hyper 212 EVO set, for only $30.  Even GPU-wise, the thermal efficiency of the Pascal chips is sufficient under air.  Upgrading GPUs under water adds at minimum the cost of the block, usually another $100+.  CPU swaps might be better depending on what you're going to.  The blocks have been universal across the 115X chips from Intel but the buggers keep switching the pins so you need a new motherboard anyway.  If you plan on swapping hardware a lot I'd stay away from a custom loop.
As you said though, it looks amazing.  I'm building a modded case right now, fully decked out, so I have to go the extra distance and do watercooling.  Doesn't hurt to get sponsored for most of the parts either  :thumb:
-Wayne Gretzky
Offline missalaire
  • Great Finder of Great Finds
« Reply #11053 on: Wed, 12 October 2016, 00:23:40 »
Tag Heuer Aquaracer watch
Overwatch track jacket
Offline kolec94
« Reply #11054 on: Wed, 12 October 2016, 09:16:01 »
I got a hakko 936 clone soldering station and some beyblades in the mail
kbparadise v60 blues
Offline alh84001
« Reply #11055 on: Wed, 12 October 2016, 11:42:16 »
mine's infested with corrosion, sad thing to see. similar to this, but multiply by 30.
after opening it up i pretty much gave up on it straight away, never even plugged it in :-X
PMed :)
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #11056 on: Thu, 13 October 2016, 15:06:53 »
A FiiO E10K
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline xondat
  • i'm not a star
« Reply #11057 on: Thu, 13 October 2016, 16:33:33 »
Not much which is quite sad :(
Marmalade Skies, Moon Drop Frost/Chill, and the first doubleshot V2 ;D
Offline Mattr567
« Reply #11058 on: Thu, 13 October 2016, 18:30:32 »
Tandem 6526 w/ super rare SKCL Amber Alps ;)
IBM P77, SKCC Green, 1984
« Reply #11059 on: Thu, 13 October 2016, 19:57:30 »
LZ CE
Offline Elth
« Reply #11060 on: Thu, 13 October 2016, 20:00:41 »
Reaper v1 & GMK CMYK
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #11061 on: Thu, 13 October 2016, 20:10:32 »
LZ CE
Damn nice!  I've wanted one for a while.  What color did you get?
WTB/WTS/WTT ---->
Offline Brammm87
« Reply #11062 on: Fri, 14 October 2016, 02:24:58 »
poor poor boy.
pls gief bbv2
Offline SBJ
  • Tactile pls
« Reply #11063 on: Fri, 14 October 2016, 07:20:46 »
A FiiO E10K
I'm very happy with mine. For the price tag it does what I expect. The bass punch could be a bit better in my opinion. But again, the price tag.
Got 4 green Jellykey's on the way for a WASD cluster on my daily driver.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #11064 on: Fri, 14 October 2016, 15:23:41 »
A FiiO E10K
Glad to hear. I've been meaning to get one for a few years now. It still gets good reviews even nowadays.
WTB/WTS/WTT ---->
Offline MJL
« Reply #11065 on: Fri, 14 October 2016, 18:11:27 »
Leopold FC660M with blue Cherry MX switches and a complete set of Leopold top printed PBT dye-sublimated keycaps to replace the laser etched PBT keycaps that are presently on.
Offline MJL
« Reply #11066 on: Fri, 14 October 2016, 19:05:10 »
Just waiting to get to my 50 post min then i can tap up the classifieds!
So if anyone has something suitable to spare i'd happily spend a few pennies :D
Did you see the new classified rules?
https://geekhack.org/index.php?topic=56284.0
You need  two months and 25 posts....
Go, go, go.... quick now!  ;D
« Reply #11067 on: Fri, 14 October 2016, 19:07:34 »
Some Topre 3D printed fun, including this guy:
Offline funderburker
« Reply #11068 on: Fri, 14 October 2016, 19:19:57 »
PLEASE SEND THIS TO ME!
Keyboard design by Skepur
Offline alienman82
« Reply #11069 on: Fri, 14 October 2016, 19:20:24 »
removed.
« Last Edit: Thu, 01 March 2018, 13:56:54 by alienman82 »
Offline y11971alex
  • Looking for Toronto meetup
« Reply #11070 on: Sat, 15 October 2016, 17:48:11 »
Offline E3E
« Reply #11071 on: Sun, 16 October 2016, 00:37:18 »
More bam springs? Jeez. I want to try one one of these days. :P
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #11072 on: Sun, 16 October 2016, 10:12:54 »
Some caps and shave soaps.
Offline dgneo
  • Supervillain
« Reply #11073 on: Sun, 16 October 2016, 10:39:00 »
:O all my wants
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #11074 on: Mon, 17 October 2016, 13:41:39 »
A lot of caps
Offline alienman82
« Reply #11075 on: Tue, 18 October 2016, 19:54:59 »
removed.
« Last Edit: Thu, 01 March 2018, 13:55:22 by alienman82 »
    • WTB/WTTF Thread
« Reply #11076 on: Tue, 18 October 2016, 20:07:04 »
OTD 356CL DGE
Nice man! What switches
In other news though, I've got some mummy 3s coming in.
Offline alienman82
« Reply #11077 on: Tue, 18 October 2016, 20:07:41 »
removed.
« Last Edit: Thu, 01 March 2018, 13:55:15 by alienman82 »
    • WTB/WTTF Thread
« Reply #11078 on: Tue, 18 October 2016, 20:12:54 »
Offline captaineleven
« Reply #11079 on: Wed, 19 October 2016, 08:56:43 »
Gonna be getting a realforce 45g board in the mail today. Pretty excited as I recently parted ways with my HHKB and I'm looking towards the opposite direction, size-wise. It's the uniform 45g but I'd love to get my hands on the variable weight to see how it compares to 30g gat clears (also something I recently parted with).
So fancy!
Offline kawasaki161
« Reply #11080 on: Wed, 19 October 2016, 09:46:02 »
GMK Skeletor, still (was shipped on 4th of October -.-).
and
Holtite sockets (should arrive Friday)
Offline mason
  • have fun with her, ryan
« Reply #11081 on: Wed, 19 October 2016, 12:37:21 »
My hydrodipped HHKB case and Nantucket Selectric later today
« Reply #11082 on: Wed, 19 October 2016, 14:39:09 »
What print did you get?
Offline missalaire
« Reply #11083 on: Wed, 19 October 2016, 16:10:10 »
Mondaine Retro White Dial Ladies Watch
Game of Thrones House Targaryen Stein
Offline Elth
« Reply #11084 on: Wed, 19 October 2016, 16:20:18 »
HWS caparoos
« Reply #11085 on: Fri, 21 October 2016, 03:17:54 »
Today I'll get the PBT spacebar I ordered from ebay. Don't have matt3o's one to compare it with but I'll share my impressions anyway.
« Reply #11086 on: Fri, 21 October 2016, 03:34:44 »
CRICK CRACK
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #11087 on: Fri, 21 October 2016, 04:14:15 »
Finally getting a AUX kit for my E46.
http://quidzel.com/aux/#tabs1-specs
WTB/WTS/WTT ---->
« Reply #11088 on: Fri, 21 October 2016, 04:48:24 »
Offline alienman82
« Reply #11089 on: Fri, 21 October 2016, 09:54:38 »
removed.
« Last Edit: Thu, 01 March 2018, 13:53:40 by alienman82 »
« Reply #11090 on: Fri, 21 October 2016, 09:57:43 »
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #11091 on: Fri, 21 October 2016, 10:18:16 »
The Aedied for my class.
Offline dgneo
  • Supervillain
« Reply #11092 on: Fri, 21 October 2016, 10:18:35 »
Nikon D7000
Offline cicada
  • Formerly iamacicada
« Reply #11093 on: Sat, 22 October 2016, 14:20:57 »
Offline E3E
« Reply #11094 on: Sat, 22 October 2016, 15:12:43 »
oh snap
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #11095 on: Sat, 22 October 2016, 16:44:19 »
WTB/WTS/WTT ---->
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« Reply #11096 on: Sat, 22 October 2016, 17:38:48 »
Topre PBT spacebars are finally en route. Interested to see how they turned out, considering some of the reviews I've been hearing. However, I don't have any round 1 spacebars to compare.
Offline E3E
« Reply #11097 on: Sat, 22 October 2016, 21:49:13 »
Matt3o seems to say that the criticisms against the new round are overblown, and that the warping is something that's easily fixed with a hair dryer (which is true). I've also seen someone else say the texture IS the same as the first.
It's anyone's guess
Offline aaron6301
  • Pixel Pusher
« Reply #11098 on: Sun, 23 October 2016, 12:58:26 »
It's anyone's guess
Received both of my Topre spacebars sets and both sets have none of the issues that have been brought up by other buyers. Perhaps I got lucky with my shipment but no complaints here. While they aren't perfect, they are acceptable and color/texture is extremely similar to my stock ABS HHKB spacebar.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #11099 on: Sun, 23 October 2016, 14:39:29 »
Some pop figure that I forgot to cancel
