Author Topic: Bug Reports  (Read 1128510 times)
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Embedded Youtube Video
« Reply #650 on: Sat, 28 February 2015, 08:25:02 »
Is this supposed to work?:
I'm putting in code like:
Code: [Select]
[youtube]http://youtu.be/mEN6Rry4ekk[/youtube]
And there should be a video here:
But I see nothing but a big vertical space.  Tried on two different browsers, no adblock/noscript, still nada.   Is there some setting I changed?
It has to do with "insecure content".
This will explain how to temporarily fix it better than I can: https://support.haikulearning.com/hc/en-us/articles/202581573
How can I prevent this from happening in the future?
At this time, Chrome and Firefox do not offer an easy way to disable this warning, and do not recommend that you do.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #651 on: Sat, 28 February 2015, 08:33:03 »
Thanks.  You'd think the browser would put a placeholder there that says "click to active flash" like I get on the game sites...
Didn't notice the little shield up in the url field.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #652 on: Sat, 28 February 2015, 08:48:58 »
No problemo.
Yeah...it should've been a pop-up like the malicious content one.
Offline baldgye
  • Will Smith Disciple
Re: Bug Reports
« Reply #653 on: Sat, 14 March 2015, 18:00:50 »
Not sure if this is a bug or what but my avatar is all compressed to ****... but the image I'm using is totally fine...
what the ****
>'fixed' it by changing it from jpg to png... not sure what that is about
« Last Edit: Sat, 14 March 2015, 18:06:12 by baldgye »
Re: Bug Reports
« Reply #654 on: Sun, 15 March 2015, 00:40:45 »
JPG does not have built-in transparency, AFAIK, but PNG does.
Offline baldgye
Re: Bug Reports
« Reply #655 on: Sun, 15 March 2015, 04:45:08 »
there is no transparency in my avatar...
Offline Coreda
Re: Bug Reports
« Reply #656 on: Sun, 15 March 2015, 04:59:34 »
PNG is lossless quality and supports transparency, while JPEG is lossy and in particular hates reds (they compress terribly, not sure about pinks). JPEG at maximum quality isn't so bad though depending on the image, but PNG will preserve the original faithfully.
Unless you're trying to say the original was a JPEG, and the forum re-compressed it, yet merely changing the file extension preserved the original quality. That would be something worth changing on the forum if the case.
« Last Edit: Sun, 15 March 2015, 05:03:55 by Coreda »
Re: Bug Reports
« Reply #657 on: Wed, 18 March 2015, 06:44:07 »
I've noticed in Tapatalk the 'Participated' feature has stopped working and doesn't load anything for geekhack. But it works on other forums.
Offline strict
  • TKL Zealot
Re: Bug Reports
« Reply #658 on: Wed, 18 March 2015, 07:43:19 »
iOS or Android? Mine works on iOS, I just used it this morning.
Re: Bug Reports
« Reply #659 on: Wed, 18 March 2015, 07:43:45 »
Android.
Also it works sometimes but other times just times out.
« Last Edit: Wed, 18 March 2015, 08:56:39 by SpAmRaY »
Offline baldgye
Re: Bug Reports
« Reply #660 on: Wed, 18 March 2015, 11:36:04 »
That's pretty much exactly what I'm saying lol, I saved the original as a high quality .jpg to make the file size as small as possible, because I'm nice like that but it would then be re-compressed when uploading it as an avatar, you can see in my post the original .jpg... but when i opened that jpg on my machine and then resaved it as a png and uploaded it, it had non of the compression...
Offline NoblesseOblige
Re: Bug Reports
« Reply #661 on: Thu, 19 March 2015, 09:49:40 »
This probably isn't a bug but I wanted to confirm. Does posting within certain areas of the forum not add to your post count? I notice about a third of posts I make are uncounted. Not a big deal but was curious.
Thanks.
Re: Bug Reports
« Reply #662 on: Thu, 19 March 2015, 09:51:51 »
Thanks.
That is correct.
Re: Bug Reports
« Reply #663 on: Thu, 19 March 2015, 14:15:39 »
Thanks.
Yes.  Off topic, new members and classifieds posts don't count.
Re: Bug Reports
« Reply #664 on: Mon, 23 March 2015, 17:10:55 »
Anybody else having trouble loading GH? Past few days it's taken a few refreshes and waiting as the site seems to be overstressed.
It generally happens after navigating away from the site and returning, but not exclusively. Chrome
Re: Bug Reports
« Reply #665 on: Mon, 23 March 2015, 17:14:29 »
Seems fine to me.
There's no big sales or anything on, so it should be running normally.
Re: Bug Reports
« Reply #666 on: Thu, 26 March 2015, 14:49:05 »
OK well, GH is still unbearably slow loading pages and still just stalls out half the time. Every other website loads right away, so it's definitely GH's problem.
I cannot be the only one experiencing this issue.
Offline JPG
  • Model F is my new passion!
Re: Bug Reports
« Reply #667 on: Thu, 26 March 2015, 14:52:24 »
It's only slow cause of the devil!
95310-0
Re: Bug Reports
« Reply #668 on: Fri, 27 March 2015, 17:57:45 »
OK, it is becoming painful to browse GH on my PC due to it dropping requests constantly, deleting my comments while I am trying to submit them because it loses connection again, even opening a new tab works maybe 40% of the time. WTF is going on with this site, and why am I the olny person having issue with it.
I haven't changed any settings on my PC/Chrome/ or GH profile, and I cannot fathom why this is the only site on the internet that won't work for **** the last week or so.
Offline godly_music
Re: Bug Reports
« Reply #669 on: Sat, 28 March 2015, 14:33:43 »
I can't seem to Quote a particular post. It's stuck on the 'Loading...' popup without ever getting anywhere. Other, shorter posts work fine. The post in question is this one.
It seems to work in Chromium, but not in Palemoon 25.3.1. Quoting other posts works fine on both.
Re: Bug Reports
« Reply #670 on: Sat, 28 March 2015, 23:38:56 »
How is your internet connection?  When I moved into this house the cable was crap and the connection dropped out every few minutes.  GH was acting very much as you describe.  During an upgrade on the street Telstra replaced all the cables, and now it is much better, and GH is behaving very well.  In fact the only problems I had recently were related to the Radlenac.
This has been reported by a few people, myself included.  There was some suspicion that it was particular members whose posts could not be quoted, perhaps as a result of unexpected or Unicode characters in their username, signature or even post.
Yet to be confirmed.
Offline tbc
Re: Bug Reports
« Reply #671 on: Sun, 29 March 2015, 18:14:49 »
https://geekhack.org/index.php?topic=56515.msg1698542#msg1698542
seems fine to me
using firefox dev edition v39
Re: Bug Reports
« Reply #672 on: Sun, 29 March 2015, 21:17:55 »
It's not my connection, it's only this website. Could it be something to do with Tapatalk? Honestly that's all I can think of, it takes about a minute and a ghalf to load a page, and any submission is a crapshoot 50/50 with the lag.
Re: Bug Reports
« Reply #673 on: Sun, 29 March 2015, 21:18:44 »
It's really pissing me off, this website is ****ed >:(
Re: Bug Reports
« Reply #674 on: Sun, 29 March 2015, 22:29:15 »
I'm using it at work today - working fine.  No anomalies observed.
Offline baldgye
Re: Bug Reports
« Reply #675 on: Mon, 30 March 2015, 06:36:21 »
I find that it's pretty hit and miss to loading pages on here and making posts... sometimes my phone does it np (at work) other times my work machine has no problems... and at home it's a bit random too...
prob just server costs etc etc
Re: Bug Reports
« Reply #676 on: Mon, 30 March 2015, 08:01:07 »
I've been having issues with pages loading and with posts timing out as well.
Re: Bug Reports
« Reply #677 on: Thu, 02 April 2015, 14:27:44 »
GH is still broken as ****, and no one has given me any insight or answer or even a guess why it's the only web page on the goddamn internet that isn't working for me but apparently is for everyone else.
Re: Bug Reports
« Reply #678 on: Thu, 02 April 2015, 16:38:01 »
These time-outs and dropped posts are actually making me mad. Does no one have any insight at all?
Offline tbc
Re: Bug Reports
« Reply #679 on: Thu, 02 April 2015, 21:29:20 »
I don't understand, i thought tapatalk was a mobile app that reformatted forums to display the same mobile friendly interface.  it's for PC as well?
Offline user 18
Re: Bug Reports
« Reply #680 on: Thu, 02 April 2015, 23:15:05 »
I've got no idea, GH has been working just as well as the rest of the web for me.
Avatar by ashdenej
Offline byker
  • Literally Canada
Re: Bug Reports
« Reply #681 on: Thu, 02 April 2015, 23:22:30 »
It is hard to have insight when geekhack is working fine for everyone else. Did you try different browsers and different computers on your network?
Re: Bug Reports
« Reply #682 on: Thu, 02 April 2015, 23:24:42 »
It works fine on mobile and I disabled TPT just in case. It only happens on my home connection, not even when I log in on an outside computer, only at home even with different PCs/laptops hooked up via wifi or hardwire.
But again, it's not effecting mobile using the same wifi. I am absolutely baffled.
Offline user 18
Re: Bug Reports
« Reply #683 on: Thu, 02 April 2015, 23:42:03 »
Does it work normally if you use the web browser on mobile, or just with tapatalk?
Avatar by ashdenej
Re: Bug Reports
« Reply #684 on: Fri, 03 April 2015, 01:48:48 »
Might be something silly like a mis-configured DNS in your router or something.
Offline baldgye
Re: Bug Reports
« Reply #685 on: Sun, 05 April 2015, 13:36:39 »
Just browsing geekhack....
All seems normal...
Offline baldgye
Re: Bug Reports
« Reply #686 on: Sun, 05 April 2015, 15:06:32 »
Why is posting so ****ing difficult on this website
Re: Bug Reports
« Reply #687 on: Wed, 08 April 2015, 00:31:10 »
I think I finally fixed it. There was some spyware masquerading as Windows .dll rootkit files that wasn't detectable by my antivirus until just recently. I hate knowing I was operating with that **** in my system for over 2 weeks. Ugh, I feel violated.
Offline byker
  • Literally Canada
Re: Bug Reports
« Reply #688 on: Wed, 08 April 2015, 01:45:57 »
Good to hear you got it fixed man!
Re: Bug Reports
« Reply #689 on: Wed, 08 April 2015, 05:51:29 »
Congratulations :)
Offline swill
  • builder & enabler
    • swillkb.com
Re: Bug Reports
« Reply #690 on: Wed, 22 April 2015, 20:36:28 »
Is the tapatalk software on the server at the latest version?  Since recent changes to tapatalk it had been almost unusable (as can be judged by my absence). The main issue is that the 'unread' section does not populate at all anymore.
Anyone fixed this issue with tapatalk?
Offline azhdar
  • Praise the AZERTY god
Re: Bug Reports
« Reply #691 on: Thu, 23 April 2015, 01:43:13 »
Sometimes when you respond by quoting, you arrive into the quoted part, it seems to happen to a lot of people lately.
Azerty Propagandiste
Re: Bug Reports
« Reply #692 on: Fri, 01 May 2015, 11:25:35 »
You mean like this?
I think its a problem with quote tags accidentally being deleted when replying, and/or just typing inside the quotes as I did above.
Offline wlhlm
Re: Bug Reports
« Reply #693 on: Mon, 11 May 2015, 17:52:06 »
Hi,
I'm having trouble with smilies randomly not rendering for my posts even though I have "Don't use smileys" unticked.
Examples:
https://geekhack.org/index.php?topic=70769.msg1743334#msg1743334
https://geekhack.org/index.php?topic=33130.msg1743321#msg1743321
Other posts work fine without me having changed any setting :confused:
https://geekhack.org/index.php?topic=70769.msg1741364#msg1741364
(For this post everything works as expected...)
Offline trizkut
Re: Bug Reports
« Reply #694 on: Mon, 11 May 2015, 18:06:44 »
Hi,
Examples:
If you quote something (or quote a quote of a quote etc.) that has a picture, smileys don't work.  To get around this, I usually just right click the smiley and go to "copy image URL" and embed it using [img] tags.
Offline wlhlm
Re: Bug Reports
« Reply #695 on: Mon, 11 May 2015, 18:13:23 »
Hi,
Examples:
What a weird bug! Sometimes it appears like a wonder that this forum software works at all. :rolleyes:
Re: Bug Reports
« Reply #696 on: Mon, 11 May 2015, 18:18:43 »
;D  You're gonna make the hamsters feel bad!
Offline absyrd
  • CPT HYPE PADAWAN
Re: Bug Reports
« Reply #697 on: Mon, 18 May 2015, 11:06:43 »
I'm trying to quote someone and am getting a "LOADING..." bar stuck at the top of my page in firefox. Tried several times since 6am.
EDIT: same with IE
And it was this post I was trying to quote:
https://geekhack.org/index.php?topic=33088.msg1749327#msg1749327
« Last Edit: Mon, 18 May 2015, 11:11:37 by absyrd »
Offline byker
  • Literally Canada
Re: Bug Reports
« Reply #698 on: Mon, 18 May 2015, 12:42:28 »
EDIT: same with IE
I can quote that post in chrome. (if that helps)
Re: Bug Reports
« Reply #699 on: Mon, 18 May 2015, 15:15:12 »
EDIT: same with IE
I cannot quote that post either, using Chrome on Mac.
There are some users whose posts generally cannot be quoted at all, and other posts that cannot be quoted at random.
