Author Topic: Bug Reports  (Read 1126863 times)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Bug Reports
« Reply #950 on: Thu, 08 December 2016, 18:33:35 »
@ZSsloane:
Testing:
Also, check my sig.
EDIT:
Link
Yeah this seems like it is an issue on your end.
But it is also the first time I see Geekhack resizing images (img width=640 height=84), so it might have to do with that.
« Last Edit: Thu, 08 December 2016, 18:36:22 by JaccoW »
|||My other keyboards :
x
Offline zslane
Re: Bug Reports
« Reply #951 on: Thu, 08 December 2016, 19:47:56 »
So what "feature" in a godaddy-hosted directory would "block" images being accessed through a bbcode tag like [img]?
Offline user 18
Re: Bug Reports
« Reply #952 on: Sun, 11 December 2016, 20:30:37 »
GH counts my own posts as new posts. Has for a while. Wasn't really bugging me until right now.
Carries over to several platforms.
Not quite sure what you mean by this, can you clarify?
@ZSsloane:
Testing:
Also, check my sig.
EDIT:
Link
The resizing shouldn't be the issue.
Avatar by ashdenej
Re: Bug Reports
« Reply #953 on: Mon, 12 December 2016, 12:48:07 »
If I make a post in the Keyboards subforum, then click on "Home" to look at another subforum, the keyboards subforum shows as having unread posts when there aren't any.
Applies to all forums.
Offline user 18
Re: Bug Reports
« Reply #954 on: Wed, 14 December 2016, 15:19:25 »
I see. I'll pass that along to the people with backend access.
Avatar by ashdenej
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Bug Reports
« Reply #955 on: Wed, 14 December 2016, 17:28:34 »
I am still getting security issues
NET::ERR_CERT_AUTHORITY_INVALID
When I click on advanced, I get the message
Theis server could not prove that it is geekhack.org; its security certificate is not trusted by your device's operating system.  This may be caused by a misconfiguratio or an attacker intercepting your connection.
This is on my phone.  I do not get the issue on any of my desktops or laptops.
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Bug Reports
« Reply #956 on: Mon, 06 February 2017, 20:56:49 »
Has the ability to block certain users been removed recently?
Re: Bug Reports
« Reply #957 on: Thu, 09 February 2017, 17:35:40 »
did you guys remove the group at the top left for **** like unread replies?
Re: Bug Reports
« Reply #958 on: Thu, 09 February 2017, 18:32:40 »
Nope.  Did you push that little up arrow to hide them?
Re: Bug Reports
« Reply #959 on: Thu, 09 February 2017, 19:10:47 »
WTF I didn't even know that was a thing thanks
Re: Bug Reports
« Reply #960 on: Thu, 09 February 2017, 19:11:22 »
And you've been here how long?  ;)
Offline katushkin
  • Just the guy
Re: Bug Reports
« Reply #961 on: Sat, 11 February 2017, 00:54:58 »
please god where is the block button
Offline Photoelectric
Re: Bug Reports
« Reply #962 on: Sat, 11 February 2017, 00:57:55 »
Profile -> Modify Profile -> Buddies / Ignore List... -> Edit Ignore List
That?
For PMs, there are separate rules in Messages.
« Last Edit: Sat, 11 February 2017, 00:59:31 by Photoelectric »
Offline katushkin
  • Just the guy
Re: Bug Reports
« Reply #963 on: Sat, 11 February 2017, 01:00:19 »
actual bug report though; when a watched topic gets moved (like from IC to GB) the watch gets removed. I imagine this is because you are essentially creating a new thread just with all the old replies in it?
Edit: OK the old IC thread is still open and yet the GB thread has all the old replies in it  :-\
That?
ohhhhhhhhh
i thought there was an option to do it on someone's profile. Thank you though :) that has saved my sanity
« Last Edit: Sat, 11 February 2017, 01:25:08 by katushkin »
Offline Coreda
Re: Bug Reports
« Reply #964 on: Sat, 04 March 2017, 09:11:26 »
Is anyone else experiencing this? A row of whitespace is auto added in the Quick Reply text box when writing posts. Deleting the whitespace while composing has no effect and seems to re-add itself.
Been noticing this for a few weeks off and on (not that frequently though as I normally use the full Reply page) but originally thought it was accidental keypresses.
162059-0
« Last Edit: Sat, 04 March 2017, 09:12:58 by Coreda »
Offline katushkin
  • Just the guy
Re: Bug Reports
« Reply #965 on: Mon, 24 April 2017, 13:49:27 »
I have no idea why the code has gone all mad on the KOTM winner's thread, I can't see what I've done at all. Would a mod be able to look at it for me and tell me why i'm stupid?
https://geekhack.org/index.php?topic=87762.0
If you go into the code it looks as if it's written as it appears, but if you delete it and make it right, it just reverts back to being wrong again
« Last Edit: Mon, 24 April 2017, 14:42:32 by katushkin »
Re: Bug Reports
« Reply #966 on: Mon, 24 April 2017, 17:44:57 »
I think I've fixed it.  You had an "img=" instead of "img]" for the part that was broken.  It was messing up everything afterwards.
Offline katushkin
  • Just the guy
Re: Bug Reports
« Reply #967 on: Tue, 25 April 2017, 04:15:44 »
Goddammit. Thanks dude.
Offline hapakey
Re: Bug Reports
« Reply #968 on: Mon, 05 June 2017, 11:11:16 »
Post count messed up
Offline hapakey
Re: Bug Reports
« Reply #971 on: Tue, 06 June 2017, 21:50:02 »
https://geekhack.org/index.php?topic=89926.0
Top 10 posters looks messed up
Nothing wrong there as fas as I can see, except the numbers are a bit smaller than they were.
What aspect of it is messed up?
Re: Bug Reports
« Reply #972 on: Tue, 06 June 2017, 21:57:53 »
Actually 'itlnstln' is out of place, I would say since his posts were older they were not affected by this recent blip, at least not to the degree ours were.
Re: Bug Reports
« Reply #973 on: Tue, 06 June 2017, 22:07:02 »
itlnstln is old guard - 13093 active posts but only 9872 total posts :))
Back before the purge.
Re: Bug Reports
« Reply #974 on: Wed, 07 June 2017, 01:34:40 »
Kirkle still banned please fix
Re: Bug Reports
« Reply #975 on: Wed, 07 June 2017, 05:25:45 »
That's a feature?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Bug Reports
« Reply #976 on: Thu, 08 June 2017, 02:31:15 »
Yeah what happened here? I got to 2400 posts last week in 8 years time and now I am below 1400.
x
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Bug Reports
« Reply #977 on: Thu, 08 June 2017, 05:18:15 »
I'm same. From 1310 to 1010 post  :confused:
Offline dgneo
  • Supervillain
Re: Bug Reports
« Reply #978 on: Thu, 08 June 2017, 05:19:09 »
People with post count questions: https://geekhack.org/index.php?topic=89926.0
Offline Coreda
Re: Bug Reports
« Reply #979 on: Sun, 19 November 2017, 21:17:47 »
It seems all externally hosted images are being forced to 640px width, regardless of the BBCode used in the post (haven't tested attachments). This was introduced years ago but according to user 18 it was possible to adjust the BBCode dimensions to scale the image.
However it doesn't seem possible now as it's forced back to 640px wide (and 360px high for 16:9 ratio images).
Offline Blazestorm
Re: Bug Reports
« Reply #980 on: Fri, 01 December 2017, 20:54:22 »
You can't unwatch from threads if they're closed, it seems possible, I made a URL that worked for a few topics but not all. Had some invalid session errors, probably the GUID being incorrect at the end.
Code: [Select]
https://geekhack.org/index.php?action=unwatch;topic={topic_number};{session_guid}
Note: no "Watch" or "Unwatch" button.
Offline katushkin
  • Just the guy
Re: Bug Reports
« Reply #981 on: Thu, 18 January 2018, 05:13:02 »
I think the hit boxes on some things are slightly off to the right. I have to click off to the right of page numbers and check boxes (like when changing the options on a poll) to actually select them.
Re: Bug Reports
« Reply #982 on: Thu, 18 January 2018, 11:22:02 »
Hmm.  Everything is looking okay in my current environment.  What browser are you using?
Offline dgneo
  • Supervillain
Re: Bug Reports
« Reply #983 on: Thu, 18 January 2018, 11:31:25 »
Same, everything working as intended here.
Re: Bug Reports
« Reply #984 on: Fri, 19 January 2018, 01:33:59 »
Looking good for me using Firefox, Chrome and Safari on macOS.
I also just discovered that in the list of page numbers, you can click the ellipsis displayed when there are too many pages and it will display all of the intervening page numbers too.
Re: Bug Reports
« Reply #985 on: Fri, 19 January 2018, 09:21:34 »
Offline dr_derivative
  • Not a real doctor
    • OC Lab Discord
Re: Bug Reports
« Reply #986 on: Sun, 21 January 2018, 18:30:53 »
I tried to post a Google form for an IC, and the random url Google gave me happened to contain the word '****'. The filter decided to censor the url replacing part of it with stars so anyone clicking on it got a 404 error. I'm pretty sure the filter should only censor visible text, not links, so this is a bug.
For reference here's the link. Click on it with censorship turned off, it works. With censorship turned on (or when logged out in incognito mode) you get a 404.
Google has since given me a new url so it's not urgent for me.
GH/Reddit/DT/Discord: dr_derivative | IG: dr_derivative_mk | Discord server: OC Lab
Re: Bug Reports
« Reply #987 on: Sun, 21 January 2018, 19:31:25 »
just regenerate the form if that happens, tbh
bad luck
Offline katushkin
  • Just the guy
Re: Bug Reports
« Reply #988 on: Sun, 28 January 2018, 03:39:16 »
I think I was using Chrome on Windows 10. It's fine now, don't know what that was all about.
Re: Bug Reports
« Reply #989 on: Sun, 28 January 2018, 03:56:29 »
Maybe you accidentally zoomed in/out slightly?  That can mess things up for no apparent reason.
Re: Bug Reports
« Reply #990 on: Sun, 22 April 2018, 02:17:46 »
The forum is borking some links.
In the GMK Yellow on Black IC thread there is a link to a Google form.
If you click the link, it takes you to a Rainbow Magicland page.
If you copy/paste the URL that is shown on the page i.e. the goo.gl link, it works.
I disassembled the link URL, which contains the thread and a few other bits and pieces (presumably for link tracking or counting), and they appear the same.
Re: Bug Reports
« Reply #991 on: Sun, 22 April 2018, 02:44:25 »
As above every google form link I can find goes to Rainbow Magicland.  If this is a 420 joke I'm not in on it :blank:
Offline haydoselefantes
Re: Bug Reports
« Reply #992 on: Sat, 26 May 2018, 18:18:50 »
I was getting SSL errors in Safari and Chrome on iOS for about half an hour around 3pm Pacific time today. Not sure if it was just something on my end, but wanted to give y’all a heads up.
196391-0
Offline dvorcol
  • Discord: dvorcol_5071
Re: Bug Reports
« Reply #993 on: Sat, 26 May 2018, 18:39:12 »
I was getting this all afternoon.  Now that I could finally get in, I cannot see my messages.  Anyone know what is going on??
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Re: Bug Reports
« Reply #994 on: Sat, 26 May 2018, 20:39:53 »
Can't see my messages either.  Site was down off/on for me all day as well.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Re: Bug Reports
« Reply #995 on: Sat, 26 May 2018, 21:16:37 »
There is a hardware fault with part of the server that this site is on (as far as I understand), and imav is working on a solution.  In the meantime, apologies for all the errors and downtime.
Offline rknize
    • metaruss
Re: Bug Reports
« Reply #996 on: Sat, 26 May 2018, 21:56:20 »
Geekhack experienced a hardware failure today.  We were able to get the site back up, but service may be spotty until the hardware is replaced.
Russ
Offline molecularronin
Re: Bug Reports
« Reply #997 on: Tue, 29 May 2018, 06:47:40 »
Was wondering if there is an ETA on the messages being able to work again?
Re: Bug Reports
« Reply #998 on: Wed, 13 June 2018, 23:10:18 »
Is it just me, or is the whole forum been intermittently down lately?
Offline user 18
Re: Bug Reports
« Reply #999 on: Wed, 13 June 2018, 23:33:27 »
I haven't noticed anything. However, that doesn't mean it's not the case. There were hardware issues a couple weeks ago, is it more recent than that that you're noticing this issue?
Avatar by ashdenej
