Author Topic: What did you get in the mail today?  (Read 23436312 times)
0 Members and 21 Guests are viewing this topic.
« Reply #53200 on: Wed, 06 December 2023, 00:36:37 »
I think I'm in love...  :-*
This beautiful little thing just arrived.
Classy camera.
Offline Belfong
« Reply #53201 on: Sun, 31 December 2023, 02:43:12 »
I have some Matias blank keys for me to replace the modifiers. I am using the Matias Quiet Pro, meant for a PC, on a Mac. I changed the Windows key to Option and the Alt key to Command key and so needed the blanks modifiers to hide them from my view so I can press them correctly. Through this purchase, I found out that Matias keyboards have undergone some changes in the past 10 years where all the modifiers are now 1.25x. In the older design, the Opt/Windows key is a 1x. Cost me a bomb to buy from Matias due to shipping. And, it seems, no one is selling Matias keyboards used (not here, DT nor Reddit).
Happy New Year, GH!
Offline transeurasian
« Reply #53202 on: Mon, 01 January 2024, 22:22:13 »
classy~ not sexy enough though  :)
Offline argentstonecutter
  • Greetings, programs!
« Reply #53203 on: Tue, 02 January 2024, 17:48:00 »
New OS keycap (OEM profile grey).
305232-0
Yes I know it should have been the solid A on that side, this just looked better to me.
« Last Edit: Tue, 02 January 2024, 17:59:24 by argentstonecutter »
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #53204 on: Sat, 03 February 2024, 04:31:37 »
Just receive at an artisan keycap, a Catnap from Sodie Caps.
It's based of the Loot bug from Lethal Company, and I do really love this cap, On my board as we speak.
« Last Edit: Sat, 03 February 2024, 04:35:43 by Rhienfo »
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline KebinPls
  • OK
    • Insta
« Reply #53205 on: Tue, 09 April 2024, 08:40:15 »
Sketchy Sketchy :)
And some musics
And one day we will die
And our ashes will fly
FROM THE AEROPLANE OVER THE SEA
« Reply #53206 on: Tue, 09 April 2024, 15:25:53 »
Such a great album  ^-^
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #53207 on: Fri, 03 May 2024, 16:53:37 »
307706-0
307708-1
307710-2
Got a Matrix 8XV 3.0 today! Not a huge fan of the alum meme cut plate, so I might opt to grab a non meme cut aftermarket alum plate for it. Other than that though it's a great looking board! Can't wait to get it built & give it a go!
Offline Rhienfo
« Reply #53208 on: Fri, 03 May 2024, 19:38:49 »
Very nice board. Yeah that meme cut plate seemed way overkill. If I had to get a matrix board, I would get a 1.2og cause of the low typing angle, which I don't think this board has.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
« Reply #53209 on: Mon, 11 November 2024, 21:40:14 »
Temtop M2000 Air Quality Meter.
Was worried about CO2 levels in the home since experiencing symptoms of high C02, so sprung for this tester after some research. It was also 50% off which helped.
Probably the best meter in the $100 range, and came in a nice metal carry case. On initial testing the CO2 lvs in my bedroom were over 2000 which aint too healthy. After leaving my window open just a crack all weekend the levels are drastically improved. Every home should have an air purifier and an AQ meter.
310928-0
310930-1
Offline Belfong
« Reply #53210 on: Wed, 01 January 2025, 20:18:27 »
I live at the Equator and all our windows are always open to cool down the house. So, it is interesting for me to note that there are such meters and that high CO2 inside a house is a thing. Is it due to the house/room always being closed up due to cold weather? It's funny how I hate the heat and you all hate the cold  :)
« Reply #53211 on: Fri, 07 March 2025, 10:38:00 »
Been getting back into PSP lately and was always fascinated by the colored 3000s released in Japan. Just picked this thing up and loving it!
« Reply #53212 on: Mon, 16 June 2025, 22:30:01 »
Fun things.  ;D
« Reply #53213 on: Sat, 21 June 2025, 21:38:12 »
I feel much better now. Cheers.
Online phinix
« Reply #53214 on: Mon, 23 June 2025, 08:46:34 »
Recently I got myself couple of new lens for my Nikon Zf.
One of them is zoom lens for family trips, focal lengths I mostly use - 20mm and 40mm :)
Tamron 20-40mm f2.8 E mount.
313731-0
« Last Edit: Mon, 21 July 2025, 17:53:08 by phinix »
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline missalaire
  • Great Finder of Great Finds
« Reply #53215 on: Mon, 23 June 2025, 12:15:34 »
Recently acquired one of my chase boards - Matrix MY-2K 100NG Sea Blue. Came with the typical alu plate, but got a PP plate from Hypekeyboards for it as well. Planning to build it with Kailh Box Navies and GMK Blue Alert.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #53216 on: Mon, 23 June 2025, 20:33:43 »
Great to see people still getting mail :cool:
« Reply #53217 on: Tue, 24 June 2025, 07:30:37 »
i got some triple A amazon batteries
« Reply #53218 on: Tue, 24 June 2025, 08:47:11 »
I hate having to "sign" packages on a touch screen with a finger. Hand me an effin' STYLUS to do it with!
Got my Sensor Watch Pro - a programmable circuit board that fits in a Casio watch. Crowdfunded in October.
Not all the LCD segments got activated. Other people seem to have the same issue, so we'll see...
Hopefully, it could be solved by washing with contact cleaner, or maybe it is a pin-connectivity issue that could be fixed with a visit to a reflow oven.
« Reply #53219 on: Mon, 30 June 2025, 17:25:41 »
Will I see Nintendo Switchnollie 2 sleeves in this thread?
« Reply #53220 on: Tue, 01 July 2025, 02:09:53 »
Shirakami Fubuki tea
« Last Edit: Tue, 08 July 2025, 05:34:15 by Sifo »
« Reply #53221 on: Sun, 06 July 2025, 21:07:16 »
More cardboard.
Offline ejewell89
  • 4ever Smol
« Reply #53222 on: Wed, 24 December 2025, 13:57:16 »
More cardboard.
romevi. that's a name i've not heard in a long time.
I got this keyset finally. so i got that going for me.
« Reply #53223 on: Wed, 31 December 2025, 15:32:16 »
More cardboard.
ejewell, another name we haven't seen in a long time :O
Offline reaper
« Reply #53224 on: Sun, 04 January 2026, 12:43:47 »
That brings back memories.  I was one of the mods on Sony Playstation PSP forums when it first launched and that was a fun time.. got invited to a lot of betas (SOCOM US Navy Seals Fireteam beta was one of them).  I remember going to work in the day time and come home looking forward to fragging some noobs that just joined.  :)
Seen lots of weird posts on the Playstation forums too (i believe it was back in 2005) and that's where I gained most of my moderators experience.
« Last Edit: Sun, 04 January 2026, 13:01:51 by reaper »
Din Eli
Online phinix
« Reply #53225 on: Sun, 04 January 2026, 14:14:36 »
Logitech Pro X Superlight 2 DEX
315725-0
« Last Edit: Sun, 04 January 2026, 14:18:17 by phinix »
« Reply #53226 on: Tue, 20 January 2026, 20:51:02 »
I added some carbon fiber to my 2080Ti, also got a pure cf GPU bracket to help hold it up :cool:
315936-0
« Reply #53227 on: Thu, 26 March 2026, 22:07:58 »
New plant stand and light setup
316435-0
