Author Topic: Plate mounted Poker. Recycling My Old RK-9000  (Read 18083 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Wed, 25 July 2012, 23:25:13 »
Here is a simple mod I did in only a couple of hours. MUCH prefer the feel of plate mounted switches. Makes the poker feel like a mini Filco!  :D
Still messing with the case to get it to fit right. Its a hair off.
and I am missing my space stabilizer, so I really need to get one of those : )
Re: Plate mounted Poker. Recycling My Old RK-9000
« Reply #1 on: Wed, 25 July 2012, 23:27:41 »
wooo looks really good!
I want a plate mounted poker now :(
fartq
  •  Guest
« Reply #2 on: Thu, 26 July 2012, 00:26:53 »
nice! what did you use to cut the plate? i've never been particularly good with either tin snips or hacksaws :X
  • I <3 60%
« Reply #3 on: Thu, 26 July 2012, 06:42:20 »
I used a jigsaw with a PVC cutting blade oddly enough xD
Offline truongnd
« Reply #4 on: Thu, 26 July 2012, 09:13:31 »
this is really amazing! how did you manage to cut all the switch slots so evenly
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Thu, 26 July 2012, 12:08:55 »
Did you have to cut/mod the PCB at all?
Offline harrison
« Reply #6 on: Thu, 26 July 2012, 12:22:53 »
he re-used an existing plate, as far as I can tell, the plate was only cut down to fit the poker profile... none of the switch cutouts needed (or should have been needed) to be modified.
[work]ducky tiger dk-9008G2, cherry mx brown|logitech performance mx
[home]corsair k70 LUX RGB, cherry mx brown|logitech G700s
« Reply #7 on: Thu, 26 July 2012, 12:42:36 »
LS, don't you need to drill holes for the screws to mount the PCB to the case?
  • I <3 60%
« Reply #8 on: Thu, 26 July 2012, 15:41:28 »
The plate was from my broken Rosewill RK9000. All I had to do was cut it to match the Poker PCB. I didnt have to cut the PCB at all.
and eventually I wanna make it screw in like normal, but for now the case is held on by friction. Its REALLY tight though. In fact, I'm doubting I'm gonna be able to remove the case.
But, my case is kinda warped and messed up from trying to remove paint with acetone, so when I get a new case, Im going to drill proper screw holes. :D
« Reply #9 on: Thu, 26 July 2012, 15:46:02 »
Thanks so much for the plate idea. I was going to harvest the red switches from my RK-9000 for use in my Phantom when it gets here, and now I have a use for the Rosewill plate as well! If I could get an RK-9000 from Newegg for $64.99 shipped, like they had before, I would buy it just for more switches and the plate...
Offline sth
  • 2 girls 1 cuprubber
« Reply #10 on: Thu, 26 July 2012, 15:59:35 »
That's badass! the plate cut looks really good - you should just make a mounting plate case like Half Saint from DT. Show off that red plate!
« Reply #11 on: Thu, 26 July 2012, 16:06:07 »
Red PCB + Red Plate + Red Switches = WIN!
Offline braaaiiins
« Reply #12 on: Thu, 26 July 2012, 16:20:53 »
so... sweet. I like this!
edit:
how is your desolder suction tool? I got a cheap one on amazon that works well.... some of the time and not so well a lot of the time. I can bare with it for a few switches, but for an entire board, that would literally take me all day!
Oh and I definitely didnt like the flex with the factory poker either. I placed a 1/16 (or 3/32 inch.. cant remember) neoprene rubber sheet to fix that problem. No more flex and its feels rock solid, but I can still access my stems and springs easily =)
« Last Edit: Thu, 26 July 2012, 16:25:32 by braaaiiins »
Offline JustCallMeCrash
  • ErgoDox Lover
« Reply #13 on: Thu, 26 July 2012, 16:21:57 »
If you've got a plate, you can't see the PCB... STILL a win, though!
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
Offline rainb1ood
  • so pretty so plastic
« Reply #14 on: Thu, 26 July 2012, 16:23:59 »
I'm imagining it on a clear case and it looks sexy. You can see the red pcb underneath :P
  • I <3 60%
« Reply #15 on: Thu, 26 July 2012, 16:36:11 »
xD thanks guys.
only problem is the back where I actually made the cut. It looks pretty crappy. I Might have to desolder everything so I can sand it down and paint it. There is also that little chip in the middle. Don't know how that happened.
and braaaiiins, My suction tool is pretty good. it does the job, but I have to clean it every 10-ish switches. It gets clogged pretty easy.
« Last Edit: Thu, 26 July 2012, 16:37:42 by Lethal Squirrel »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #16 on: Thu, 26 July 2012, 16:41:37 »
If you can't spring for something like a Hakko 808 then I suggest springing for the best manual solder sucker... Edsyn Soldapullt.  It is BIG so it does a good job of thoroughly sucking out the solder.
Filco w/ Imsto thick PBT
  • ErgoDox Lover
« Reply #17 on: Fri, 27 July 2012, 07:40:19 »
If you don't want to spend an eff-ton of money, Radio Shack has a perfectly serviceable desoldering iron with a bulb for about $15.  It automatically cleans itself with each squeeze of the bulb and the replacement tips (because you WILL mess up a tip) are only about $5 or less.  I used mine to desolder 4 full-sized boards before the tip was totally destroyed.  Beats the pants off how I used to do it (with the $18 plunger-style desolderer that requires a separate soldering iron and good timing).
http://www.radioshack.com/product/index.jsp?productId=2062731  Is the one I use now.
http://www.radioshack.com/product/index.jsp?productId=2062745  The plunger one I was talking about above... it has its uses, but it's a lot more work than the desoldering iron.
G80-11900.
Offline gimpster
« Reply #18 on: Fri, 27 July 2012, 12:21:01 »
I had that one, too. I made it through 3 full-size boards before the iron wouldn't heat up anymore. I tossed it and bit the bullet on the Hakko 808...it'll be here Tuesday, meanwhile 2 more boards sit taunting me with their switches still attached. :)
-Ryan
Offline braaaiiins
« Reply #19 on: Fri, 27 July 2012, 14:54:42 »
Sweet, that Hakko looks awesome, but that radioshack deal is hard to pass up! I'll definitely try that one.
Offline Zykos
« Reply #20 on: Fri, 27 July 2012, 22:18:07 »
Wow that looks surprisingly very nice. I wish i had one.
Offline theultrazord
« Reply #21 on: Fri, 27 July 2012, 23:29:07 »
holy crap that's a genius idea =O.
Offline sth
« Reply #22 on: Sat, 28 July 2012, 04:11:58 »
if anybody has a busted platemount ANSI board they would like to get rid of, drop me a line!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #23 on: Sat, 28 July 2012, 10:07:33 »
Wonderful mod. Especially nice e-cycling job!
Just missing a red alert set now. :P
  • I <3 60%
« Reply #24 on: Sat, 28 July 2012, 11:36:17 »
That's my goal lol
