Author Topic: Cleaning keycaps  (Read 4377 times)
Offline viasacra89
Cleaning keycaps
« on: Sun, 29 July 2012, 01:49:27 »
Hey GH, I was wondering how you guys clean your keycaps.  I have a filco majestouch 2, which i think is abs, and some random pbt caps.
|Filco MJ2 TKL Browns|
Offline Glissant
Re: Cleaning keycaps
« Reply #1 on: Sun, 29 July 2012, 02:22:45 »
This thread might give you some insight
http://geekhack.org/index.php?topic=32995.0
If it doesn't then a search might help.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Sun, 29 July 2012, 02:27:09 »
I just use warm water and a tiny bit of soap. Then hand dry each key wiping off the top of the key with a bit more force
Offline 486
« Reply #3 on: Sun, 29 July 2012, 03:01:38 »
Originally I used ammonia and/or Jif to clean my keys.
I then moved to detergent and hot water.
But I now use denture cleaning tabs.
I find the tabs work very well.
Get some hot tap water and about 5-6 tabs and let them dissolve. Place keys in and leave for about 3-4 hours.
Wash after with clean water and dry.
« Last Edit: Sun, 29 July 2012, 03:03:13 by 486 »
« Reply #4 on: Sun, 29 July 2012, 10:18:34 »
Powdered laundry detergent in hot water. 1 spoonful in 2-3 liters is fine. I also add Oxi-clean or Biz.
Soak for an hour or less and rinse well.
Toss them onto a towel to air-dry in a couple of hours, or shake each one by hand to dry in 10-20 minutes.
Cheap, fast, leaves them feeling squeaky-clean.
Use alcohol or pencil eraser for stubborn spots.
Never use heat unless you are sure they are all PBT.
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Offline Zykos
« Reply #5 on: Mon, 30 July 2012, 19:08:37 »
I hand wipe each individual key with water and soap.
Offline yearn4
  • formerly known as 4en
« Reply #6 on: Mon, 30 July 2012, 20:14:56 »
i cook boiling water in a pot and drizzle in detergent and then let it cool for about 5 minutes and then i just dump all my keys in the pot.
my keys are all pbt so they don't melt. i'm not sure about abs though
after the keys have been marinated for a few hours i cook another boiling water pot but this time without detergent
