Author Topic: Project: SSK revival  (Read 83672 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Project: SSK revival
« Reply #250 on: Wed, 02 October 2013, 20:08:44 »
backburner. everything is actually in pretty good shape, but a whole bunch of sheet metal needs to be cut and bent and paid for. not in the budget right now unfortunately.
Offline Photoelectric
« Reply #251 on: Wed, 02 October 2013, 20:24:13 »
That's unfortunate.  I've only recently learned about this project.  Hopefully it is only a matter of [not terribly long] time before it reaches its goal.
Offline mkawa
« Reply #252 on: Wed, 02 October 2013, 20:30:31 »
it is really just a matter of time. the designs don't really need that much work, and the membrane situation is under control enough for a first run, but i would need a whole bunch of time for construction and the budget to have the sheet metal cut and bent AND the printer needs to be up, all at the same time. quite a few moving parts, unfortunately. on the upside, the hardest work has been done for the most part. it's just a situation where the ROI is hugely negative (this was always a labor of love for all involved) and geeckers needs a revenue stream right now, so i'm focusing on meeting people's immediate and small-scale needs first.
Offline dante
« Reply #253 on: Thu, 03 October 2013, 12:19:02 »
As I understand it Mkawa you bought a bunch of controllers from Unicomp - correct?  If so, how many of these can you make before you run out?
Offline mkawa
« Reply #254 on: Thu, 03 October 2013, 14:12:36 »
i can make more boards than i believe there is demand for.
Offline Hellmark
« Reply #255 on: Thu, 03 October 2013, 17:12:52 »
Is the info for the plates available, in case people want to do that part on their own? I know doing en mass is cheaper, but if doing things piecemeal can help get things going faster...
« Reply #256 on: Thu, 03 October 2013, 17:22:49 »
I demand a board!
Actually, I don't, because shipping would be just silly :p
« Reply #257 on: Thu, 03 October 2013, 17:34:31 »
With my luck finding a reasonably priced vintage SSK, I'll probably be able to finally get a shiny new one when this project does come to completion!
Offline do_Og@n
« Reply #258 on: Thu, 03 October 2013, 21:37:07 »
Is it bad that I'd sell my old one for one of these new ones?
Offline mkawa
« Reply #259 on: Fri, 04 October 2013, 05:28:15 »
i'd prefer to make the first run of cases because they're a bit complicated. there's a plastic and metal component, and our plan is to lasercut stainless, which requires an amount of power that would be unattainable if it weren't for the_beast's laser cutting contact.
if everyone involved agrees, after the first run the board design will be made available under some variant of the ggppll. also, trading up to a revival board, if they come out like i want them to, won't be unheard of. the plates are going to be thicker than the thickest plates i've ever pulled out of an ssk, and the bottom case will be stainless instead of the break-prone plastic that the OEM units use.
Offline do_Og@n
« Reply #260 on: Fri, 04 October 2013, 06:49:28 »
Good to know. I am definitely in for one of these.
Offline Game Theory
« Reply #261 on: Fri, 04 October 2013, 07:00:13 »
Im in too! :thumb:
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline Hellmark
« Reply #262 on: Fri, 04 October 2013, 09:24:48 »
To be honest, I am not big on TKLs, but I would consider going for a new style SSK. I currently have 4 keyboards on my desk (5 if you count the built in keyboard for the laptop I have docked), and can see the benefit of not having everything be fullsized. As long as my main keyboard is fullsized, I would still be happy.
Also, I am a fan of metal. The stainless steel bottom sounds really intriguing. As long as I have the funds by the time things roll around, I would definitely want to get one.
« Last Edit: Fri, 04 October 2013, 09:28:22 by Hellmark »
« Reply #263 on: Fri, 04 October 2013, 09:37:38 »
I have an SSK and I want one of these lol
Offline MTManiac
« Reply #264 on: Fri, 04 October 2013, 09:44:34 »
I don't have an SSK and never have good luck on the auctions, always working during snipe time.
This will be perfect for me.
Patiently waiting and enjoying the progress you guys have made.
One of these days I will have one of these and it will be good.
Offline Hellmark
« Reply #265 on: Fri, 04 October 2013, 09:59:27 »
For me, I think it may be a bit better going this route. I would most likely have it at work, and if it is something using new parts, and easy to work on, I'd feel less hesitant about leaving it there. I am not so worried about things walking, as I am of things breaking.
« Reply #266 on: Fri, 04 October 2013, 11:01:27 »
If I could acquire an SSK  :-*
 I would want it to be made by kawa.
« Reply #267 on: Fri, 04 October 2013, 11:27:29 »
Or wcass Binge?
Offline dante
« Reply #268 on: Fri, 04 October 2013, 12:00:26 »
Or fohat.digs !! [I'm a big fan]
Offline mkawa
« Reply #269 on: Fri, 04 October 2013, 13:11:17 »
i also have a unique method of bolt modding that is high precision and will work with the thickened plating to produce a very unique feel.
that said, hugely labor intensive.
Offline dante
« Reply #270 on: Mon, 21 October 2013, 10:22:33 »
2013: teh year of hope?
« Reply #271 on: Mon, 21 October 2013, 10:23:55 »
Or wcass Binge?
:O that'd be like getting a finely crafted Japanese blade...  I am not worthy.
« Reply #272 on: Mon, 21 October 2013, 12:13:43 »
I got to try one out while staying at mkawa's apartment. I've gotta say that if I didn't have an SSK already, I'd be all over this. Hell, I *HAVE* an SSK and I'm still really interested in this. It doesn't feel *exactly* as springy as my SSK does but overall, it's so good that I was impressed. The new plate, the assembly of it, and how clean the folded Model M membrane looks all look great to me. Plus I thought the way mkawa had it bolt modded was very nice. The case felt..."tighter" or better assembled than my SSK (no offense to dorkvader).
« Reply #273 on: Tue, 22 October 2013, 09:08:44 »
Or fohat.digs
Thanks for the vote of confidence, but I am a tinkerer, not a fabricator.
Non-Model F projects are mostly off my radar anymore.
- D Trump 2026-10-24
Offline Hellmark
« Reply #274 on: Tue, 22 October 2013, 10:03:27 »
That really does give me some hope, Cap'n. I am not a huge fan of TKLs, but for certain circumstances, this would be an awesome board to have.
Offline do_Og@n
« Reply #275 on: Tue, 22 October 2013, 10:51:10 »
I'm still ready to trade my SSK in for this revival version in a heart beat!
I like the older model SSK's but the idea of a bolt modded newer version with a thicker plate sound awesome to me.
« Reply #276 on: Tue, 22 October 2013, 10:58:16 »
Plus brand new plastic that hasn't weathered a decade or more!
« Reply #277 on: Tue, 22 October 2013, 11:10:11 »
Yes with the save of insane prices SSKs are getting on ebay, this project is more needed than ever.
Offline do_Og@n
« Reply #278 on: Tue, 22 October 2013, 11:28:10 »
Meh....that just adds more layers for resistance. ;)
Offline dante
« Reply #279 on: Sat, 02 November 2013, 13:01:56 »
Unicomp still insists (per Facebook) that they are working on a SSK.
Multiple people have said that they do not have the ability to do it - but if so - why do they keep saying they are?
Offline Hellmark
« Reply #280 on: Sat, 02 November 2013, 15:29:31 »
Keep up interest. People want SSKs. If they say they aren't going to make one, people will be upset.
Offline dante
« Reply #281 on: Mon, 02 December 2013, 22:20:19 »
Offline Moosecraft
  • HHKB Pro
« Reply #282 on: Tue, 03 December 2013, 12:09:04 »
I want this as my only BS board
Offline mkawa
« Reply #283 on: Tue, 03 December 2013, 20:52:09 »
oh, right. sorry, i'm up to my ears in stuff right now dudes. i got what i needed out of the beta test and i believe we have the entire chassis blueprinted but i just don't have the resources to push these out yet. this is all funded by me moi myself and the few beta testers so far and the result is that it's just going to be a huge money and time sink i don't have the money and time for at the moment. sorry folks! stay tuned etc. etc.
Offline mkawa
« Reply #284 on: Tue, 03 December 2013, 20:52:31 »
also my assembly jig is literally in iowa right now. so there's that.
Offline Moosecraft
  • HHKB Pro
« Reply #285 on: Wed, 04 December 2013, 03:22:53 »
Patience is key, especially for healing my wallet :p
Offline Hellmark
« Reply #286 on: Mon, 16 December 2013, 14:59:37 »
Kickstart it? You have prototypes, so that's enough to get going. Have interested people make donations, and if they want to get in on the next batch of testing, have a higher end donation range that would be enough to fully fund the build of a keyboard for them.
Offline mkawa
« Reply #287 on: Mon, 16 December 2013, 22:05:49 »
1) we've attempted to work with kickstarter before and they do not like us.
2) kickstarter takes 10% of proceeds. we have community funding here and on the soon-to-be-launched geekhackers store
3) i don't have time. really, very seriously, i don't have time to build a single board right now. even if i built another jig up with new parts and have the money to get the sheet metal cut, i would not have time to make a single unit.
sorry, but patience is the only answer here.
Offline Hellmark
« Reply #288 on: Thu, 19 December 2013, 13:26:04 »
I wasn't necessarily meaning kickerstarter itself, but the basic general premise of crowd funding.
As far as point number 3, that goes without saying. Everyone knows that you've been crazy busy, plus not even home much. I think we were mostly just spitballing ideas to try and come up with a solution for the money part, since the only solution for the time part is to wait.
Offline dgreekstallion
  • B.S. Fiend
« Reply #289 on: Mon, 30 December 2013, 19:56:43 »
I am definitely in.
Recent keyboard fanatic.
Model F-122 convert.
Offline mkawa
« Reply #290 on: Tue, 31 December 2013, 00:53:51 »
when i have time, i will probably GB a small production run, similarly to how i am running the other two geekhackers GBs -- quick, pay-at-order, short lead times, a dozen or two units max.
Offline Pacifist
  • on hiatus
« Reply #291 on: Tue, 31 December 2013, 00:54:38 »
do you know around how much it would cost?
Offline mkawa
« Reply #292 on: Tue, 31 December 2013, 01:01:29 »
ONE MILLION DOLLARS
not going to guess. depends largely on shop fees.
Offline REVENGE
« Reply #293 on: Tue, 31 December 2013, 05:19:32 »
Oh sweet jesus, thank you for an AB reference!!!
Offline mkawa
« Reply #294 on: Tue, 31 December 2013, 12:34:28 »
there's always time for altered beast ;)
Offline mkawa
« Reply #295 on: Thu, 26 June 2014, 20:30:02 »
total necro, but i was actually prodded hard enough to build a set of rev2 internals and put them in a case.
https://www.dropbox.com/s/3x52i8foohgxuoe/2014-06-26%2018.04.47.jpg
weight is 4lbs, which i think is the heaviest i've yet recorded for an ssk
« Reply #296 on: Thu, 26 June 2014, 20:49:26 »
In the true spirit of IBM keyboards of old :D
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #297 on: Thu, 26 June 2014, 20:55:40 »
Would have been something to have produced kits to run up against all the MX and Thorpie keyboards flooding into Geekhack daily.  Pity BS gets so little support these days amongst the community here now.
At least you tried mkawa, and I thank you for that  :thumb: .
