Author Topic: Post your clacks!  (Read 11936438 times)
Offline HipsterPunks
  • Gangnamember
Re: Post your clacks!
« Reply #8300 on: Sat, 25 October 2014, 20:55:26 »
Maybe don't smash your finger onto it like that? I understand that it's probably loose, but judging from that video it's not a jumping frog toy...
I'm not hitting it any harder than you would in normal usage.  It's so loose that I don't even need a key cap puller to remove it and there's no resistance from the stem when I lift the cap off.  That makes me worry that it could pop off in transit somewhere or any other number of ways.  Clack does quality work, this one just slipped through QC and I'm worried about losing it.
If that's no problem to you, you can always trade me a tight stemmed Topre Clack for it in a color I like for it.
I guess it must be part of making a topre cap, all of my topre brobots have been super easy to come off. That is definitely a shame though.
I have 10 Topre CC's on my HHKB right now and all of them are tight. :P
Tight like spandex kid *hipster holds hand up for high five*
sell ass and eat out
Offline HPE1000
  • Keycap Paparazzo
« Reply #8301 on: Sat, 25 October 2014, 20:59:52 »
The stems on those blues are really loose for whatever reason; for example, I can fully lift my 4+ pound filco (with mx blacks) off the ground holding on to that green gasmask, but on these blues the gasmask launches. Half of those artisans flew off the keyboard doing that as well. I prefer keys that don't fit very snug anyway as I don't have to worry about damaging them with a keycap puller, my red click clack got some battle scars from a keycap puller once (I was able to fix them luckily)
« Reply #8302 on: Sat, 25 October 2014, 22:11:53 »
Crappy phone video sadness:
That's the fear all Clacks collectors have!!
I PMed CC to see if there's anything we can do, but haven't heard back from him.  Hopefully something can be done since it's such a sexy color.  If not, I may go the way of moose and try and transform it into a BS Clack.  It just sucks that it's a loose stem.  It's almost like the stem isn't long enough or something.
I haven't said the name of the person who traded it to me since I'm trusting it was ignorance on their part since they've been a good member of the community so far and I don't want to tarnish their reputation.
Nubs, I've had several loose stem CCs straight from clack himself. All topre. He's fixed them all for me no worries. That's why my mint green blank has a baby blue underside. #1ofakind
« Reply #8303 on: Sat, 25 October 2014, 22:22:24 »
Yay!  So it's just the waiting game now of waiting to hear back from him.  I figured that would happen since I've heard others say the same thing.  The color of the Forgotten Red is just so awesome, so I'd love to have it solid without having to worry.  I honestly think it's just that the stem is a little too short and that causes it to not fit snugly.
« Reply #8304 on: Sat, 25 October 2014, 22:23:37 »
Waiting game indeed! He's been busy these days it seems :( Hope he's doing well!
Offline YoungMichael88
  • HHKB Wannabe
Post your clacks!
« Reply #8305 on: Sat, 25 October 2014, 22:27:39 »
My GirlDC pumpkin is similar to this except it doesn't touch the stem at all. You can put it on the switch by just sort of dropping it onto the stem and you cannot use the switch when it's on as just lifting your finger off the cap gently causes it to stick to your finger and fall off the stem. #PaintersTapeFix
« Reply #8306 on: Sat, 25 October 2014, 22:29:31 »
YEA BUT URDUM
  • HHKB Wannabe
« Reply #8307 on: Sat, 25 October 2014, 22:31:24 »
YEA BUT URDUM
Some jerk bought it for me for Xmas last year. He had the nerve to put a big cock cap in the box it came in.
« Reply #8308 on: Sat, 25 October 2014, 22:32:17 »
YEA BUT URDUM
OH YA! That was brilliant!
Offline Belfong
« Reply #8309 on: Sat, 25 October 2014, 22:41:08 »
I have some Topre CC that just slid into the stem smoothly. There's no resistance, they feel easy to fall off and yet they stay put. But, I imagine that the more I put and take them out of the board, the more the plastic skin will rub off each other and it will come a time it will be super loose. It's inevitable, isn't it? Especially when it is an old clack.
When I had issue with the Bro set (MX) modifiers fitting into the keyboard, some members suggested putting a tape on the stem. I tried that and it worked. Can't you do that on the Topre cc, nubbs?
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8310 on: Sun, 26 October 2014, 02:05:05 »
« Reply #8311 on: Sun, 26 October 2014, 02:13:33 »
And profile pic updated.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8312 on: Mon, 27 October 2014, 02:05:27 »
excellent. :)
i hope you are able to get your loose clack fixed!  i have one old topre skull that's pretty loose and will fall off the board if you even look at it funny.
Offline Lu_e
« Reply #8313 on: Mon, 27 October 2014, 14:25:27 »
So, I never thought to put my checkkeys on the windows keys, they just don't look right on f and j but they look a lot better on those keys.
Awesome collection, that ninbro or whatever it's called looks nice :D
Them teeth imperfections
Just say NO to ABS keycaps
Offline HPE1000
  • Keycap Paparazzo
« Reply #8314 on: Mon, 27 October 2014, 15:40:31 »
Need a click clack dentist up in here
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8315 on: Mon, 27 October 2014, 15:54:22 »
hehe.  i actually clean all of my clacks with a toothbrush when i get them. :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8316 on: Mon, 27 October 2014, 16:06:54 »
What kind of tooth paste do you use? Anticavity?
« Reply #8317 on: Mon, 27 October 2014, 16:09:51 »
Only you can prevent Gum Rot :))
« Reply #8318 on: Mon, 27 October 2014, 17:37:02 »
How many hours does that take? :p
« Reply #8319 on: Mon, 27 October 2014, 23:09:04 »
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8320 on: Fri, 31 October 2014, 15:00:15 »
The SSK has returned!  Now with RGB.
colors:  revenge red, good times green, globe blue
« Last Edit: Fri, 31 October 2014, 15:53:27 by naasfu »
Offline t2russo
« Reply #8321 on: Fri, 31 October 2014, 15:05:08 »
Those shades of green and blue are to die for.  Wonderful.
« Reply #8322 on: Fri, 31 October 2014, 15:06:23 »
So that's where the other Good Times Green BS clack is! And what color blue is that? Looks like an F2 Blue.
Offline esoomenona
  • Gnillort?
« Reply #8323 on: Fri, 31 October 2014, 15:07:05 »
« Last Edit: Tue, 01 September 2015, 09:21:03 by esoomenona »
« Reply #8324 on: Fri, 31 October 2014, 15:08:06 »
I think mine looks a little darker....although I'm not exactly having the best of days and my memory is a bit shot.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8325 on: Fri, 31 October 2014, 15:31:22 »
Globe Blue, I'd wager.
Same, not nearly as dark as the RWB clack sets blue
Offline skcheng
    • Tenafly Dentistry
« Reply #8326 on: Fri, 31 October 2014, 15:41:14 »
BS Clacks Rule!!!
« Reply #8327 on: Fri, 31 October 2014, 15:54:01 »
Those look so good!
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8328 on: Fri, 31 October 2014, 15:56:19 »
It is Globe Blue. :)  I updated the post with the color names.  With my camera, Globe Blue always comes out looking like F2 Blue.  In person, it is more of a "faded" looking blue shade with some slight purple to it.
BS Clacks Rule!!!
Yes!  And so does this SSK!  :thumb:  I love it so very much.
« Reply #8329 on: Fri, 31 October 2014, 15:58:01 »
Ok cool. I didn't think I was going that crazy yet lol.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #8330 on: Fri, 31 October 2014, 16:04:29 »
The Globe Blue looks always different depending on the lighting, sometimes it's too violet, sometimes too bright. I tried to compare the Globe Blue with the IBM Pantone or CMYK color, under different light conditions. It can be totally different!
inb4 learn 2 white balance... :)
Offline pr0ximity
« Reply #8331 on: Fri, 31 October 2014, 21:34:14 »
BS Clacks Rule!!!
Yes on both accounts. Really hope we see some more
BS Clacks in the future.
Offline frosty
  • jukebox hero
« Reply #8332 on: Sat, 01 November 2014, 03:00:53 »
sometimes i just aspire to be a burglar...
ehhhh nice photos!
« Reply #8333 on: Sat, 01 November 2014, 17:32:47 »
Very nice!
So jelly.
Much SSK.
Such Clack.
Wow!
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #8334 on: Sun, 02 November 2014, 11:38:20 »
How does globe blue compare to F2 blue?
« Reply #8335 on: Sun, 02 November 2014, 11:42:36 »
Globe, EK, and F2 look really close to me. I'd never will be able to tell unless there's a side-by-side. Maybe Globe is a touch lighter?
« Reply #8336 on: Sun, 02 November 2014, 11:43:03 »
F2 is a more washed out shade than Globe.
Offline C5Allroad
« Reply #8337 on: Sun, 02 November 2014, 11:43:46 »
Oh, thanks..
Offline Belfong
Post your clacks!
« Reply #8338 on: Mon, 03 November 2014, 03:51:59 »
Globe Blue has a tinge of purple/indigo at certain angle. That makes it unique and beautiful. F2 blue is a little bit like sky blue.
Edit: pix
(left to right: Enviro (the base is Globe Blue), Historic Blue and F2 Blue)
« Last Edit: Mon, 03 November 2014, 03:55:46 by Belfong »
Offline C5Allroad
« Reply #8339 on: Mon, 03 November 2014, 05:32:47 »
Edit: pix
Oh cool.
I like the way it looks. :)
Offline Grim Fandango
« Reply #8340 on: Mon, 03 November 2014, 05:38:00 »
Offline Distilled
« Reply #8341 on: Mon, 03 November 2014, 05:45:02 »
« Reply #8342 on: Mon, 03 November 2014, 06:36:18 »
Mate that looks awesome!
Thanks man XD thanks to your trade I actually have another one to use with a 23UB with the same color keycaps :D
Offline Distilled
« Reply #8343 on: Mon, 03 November 2014, 06:40:48 »
Now that would be a good looking desk. Glad your enjoying the cap :D
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8344 on: Wed, 05 November 2014, 00:25:19 »
Got one of 0100010's cool BS keychains today. :)
click click click click click click click click click click click click click click click click click click click click click
« Reply #8345 on: Wed, 05 November 2014, 00:35:52 »
Looks great! I've got one on the way but I don't have any BS artisan caps to put on it. :'(
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8346 on: Wed, 05 November 2014, 00:43:57 »
Thanks. :)  The keychain came with a blank BS cap, which is still pretty awesome.  Clicking with this keychain is pretty addicting, haha.
Offline justify
  • Great news!
« Reply #8347 on: Wed, 05 November 2014, 15:03:48 »
Offline yicaoyimu
« Reply #8348 on: Thu, 06 November 2014, 17:07:48 »
A few months ago, I traded my Drunken skull for something I can't care less about. I have been living with regret ever since, until I get it back today!
A close-up shot.
Playing with the light.
The two stars from last year's EK sale.
Offline Belfong
« Reply #8349 on: Thu, 06 November 2014, 17:31:27 »
Congrats for being able to get it back yicao! I think I know the feeling very well!
