Author Topic: OK, So who has the New Das S?  (Read 20280 times)
Offline alpslover
« Reply #50 on: Tue, 03 November 2009, 08:28:57 »
Quote from: wonkotron;130024
I
EDIT:  Well after testing 'qwas', it would seem that 6-key rollover isn't working quite as one might expect.  Previously, I tested with 'asdfui', which does work.  I wonder what the limitations of the hardware are (though if it were working as advertised, there wouldn't be any).
the keyboard seems to be 3-key rollover.  i.e., every combination of 3 keys i've tried works, but not every combination of more than 3 keys.
metadot has acknowledged this issue, they claim it's a problem with the first batch of das s's.
Offline AndrewZorn
« Reply #51 on: Tue, 03 November 2009, 08:35:23 »
why is it always a "whoops, first batch!" type thing?
this is not like the first time you make a cake with a new recipe or something, hoping it comes out of the oven delicious.
the entire time, during the design and production processes, no one bothered to actually test the thing before they slapped NKRO on the box and sent it out the door?
« Last Edit: Tue, 03 November 2009, 08:39:32 by AndrewZorn »
Offline timw4mail
    • https://timshomepage.net
« Reply #52 on: Tue, 03 November 2009, 08:44:16 »
Quote from: AndrewZorn;130089
I've noticed that this seems to happen with software...hardware, not usually.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
« Reply #53 on: Tue, 03 November 2009, 08:45:27 »
I don't get this with either Costar or Metadot.  There seems to be no process to randomly select a keyboard here and there and do a thorough test to ensure it works exactly as advertised.  They have, IMO, an appealing product, but their QA leaves much to be desired.
At least they have a generous return policy.  It sort of reminds me of the scene in Tommy Boy where Chris Farley says something like, "you can put **** in a box and put a guarantee on it, but all you have is a guaranteed piece of ****."
Offline hacfed
« Reply #54 on: Tue, 03 November 2009, 10:59:53 »
Quote from: itlnstln;130094
itlnstln++
I respectfully decline the invitation to join your delusion.
Offline watduzhkstand4
« Reply #55 on: Tue, 03 November 2009, 11:04:39 »
after I saw this, I just totally forgot about the DAS S.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline itlnstln
« Reply #56 on: Tue, 03 November 2009, 11:09:20 »
I hope Elitekeyboards gets the white Filcos.  I would buy one ASAP.
« Reply #57 on: Tue, 03 November 2009, 11:12:19 »
Quote from: itlnstln;130140
Definitely =D
But according to kbdmania, the white one is only domestic =[
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline itlnstln
« Reply #58 on: Tue, 03 November 2009, 11:14:47 »
Boo...
Majestouch was able to get some Cherry blue Tenkeyless Filcos made, maybe he can get some white ones.
That said, I am still saving up for the metal Filco.
Offline itlnstln
« Reply #59 on: Tue, 03 November 2009, 11:31:54 »
Excellent.  It looks like they are learning from the Das III.  In this case (moreso than the III), it seems that they have better leverage in pressing Costar for recalling/replacing defective product.  The Das III had similar symptoms as the Filco Zero, IIRC, which, as we all know well enough by now, is not considered a defect.  In this case, it is apparent that the controller has a serious defect(s), so a resolution should be easier to come by.  In the end, though, this is another black eye for Metadot, but at least this time, they are taking swift, decisive action, and I applaud them for it.
Offline AndrewZorn
« Reply #60 on: Tue, 03 November 2009, 11:35:37 »
well then they must have fixed it, already!  hooray!
Offline itlnstln
« Reply #61 on: Tue, 03 November 2009, 11:35:57 »
Well, at least they are acknowledging the problem and replacing defective units.  That's more than many folks got for the Das III.
« Reply #62 on: Tue, 03 November 2009, 11:39:17 »
I wonder how that metal Filco would feel like. It would be so cold to type on in the winter
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline itlnstln
« Reply #63 on: Tue, 03 November 2009, 11:39:49 »
Quote from: ripster;130150
Believe it or not I actually feel sorry for the Das Marketing folks right now. I've been through stuff like this before and it's no fun.
Same here.  Especially since they just released a defective product that was to replace an already defective product.  Instead of saving face, they ended up covering their collective face in egg.
Offline itlnstln
« Reply #64 on: Tue, 03 November 2009, 11:41:01 »
Quote from: watduzhkstand4;130157
Just think of it as icing-down your RSI-inflammed wrists.  It'll be nice.
Offline alpslover
« Reply #65 on: Tue, 03 November 2009, 11:44:36 »
Quote from: itlnstln;130156
yes, but now the question becomes, which part of the fixed keyboards will be broken?
Offline AndrewZorn
« Reply #66 on: Tue, 03 November 2009, 11:49:26 »
no, they are just going to update the box design to read "THE EIGHTH BEST KEYBOARD IN THE WORLD. PERIOD. WELL, BASICALLY."  and it will have "3KRO 4 TEH GAMERZ!" in the corner.
Offline AndrewZorn
« Reply #67 on: Tue, 03 November 2009, 12:07:30 »
i still say it should not have even happened once.  they make keyboards.  they have people working for them.  why not TEST the final product to make sure it meets the BASIC specifications you advertise?
it would be one thing if there was some freak combination... 1+7+Shift+Left+J+N... that ghosted or something.  but this is not the case.
Offline itlnstln
« Reply #68 on: Tue, 03 November 2009, 12:13:24 »
Quote from: ripster;130164
?? They did acknowledge the scanning problem with a CEO public apology and took back products with little hassle ( I REALLY don't expect most manufacturers to pay return shipping on returns - sorry but it is just not standard industry practice). Only later did they put a one year limit on the returns and that I'm sure is because some Accounting Dweeb told them that he didn't want to keep the liability on the books forever.
I mean - Stuff Happens. But twice?
Only after not doing anything for quite some time.  It was some months after the problem was discovered that Metadot finally acknowledged it.  Once they did, though, they really did go out of their way to help the customer.
I agree with you, too.  After the first debacle, how do you let it happen again, especially on release?
Offline itlnstln
« Reply #69 on: Tue, 03 November 2009, 12:15:45 »
I wonder if their software is any good.
Offline itlnstln
« Reply #70 on: Tue, 03 November 2009, 12:41:41 »
I'm sure that the Das is a secondary objective for Metadot.  I'm glad MIT likes their software, though, I just wish MIT would have designed their keyboard.
Offline AndrewZorn
« Reply #71 on: Thu, 05 November 2009, 02:38:34 »
what a sacrifice, even for the sake of knowledge.
Offline lowpoly
« Reply #72 on: Thu, 05 November 2009, 09:40:43 »
Are those for real?
Offline Hakhu
« Reply #73 on: Thu, 05 November 2009, 09:40:51 »
Quote from: ripster;130515
If you don't know German it says,
Quote:
Have you the beautiful Das Keyboard under your armpit?
Or something like that.
It actually says:
"Did you already hug your Das Keyboard today?"
Offline Hakhu
« Reply #74 on: Thu, 05 November 2009, 09:41:38 »
Quote from: lowpoly;130518
Are those for real?
Why, do you wanna get one?
The first one is much better. Much geekier!
Offline lowpoly
« Reply #75 on: Thu, 05 November 2009, 09:56:06 »
Quote from: Hakhu;130520
No, just thought they woudn't have taken a black stem switch for this. But it's a 1:1 copy from a Cherry brochure.
Offline Rajagra
« Reply #76 on: Thu, 05 November 2009, 12:53:31 »
I need something to remind me of my DIP switch settings. :biggrin:
Offline itlnstln
« Reply #77 on: Thu, 05 November 2009, 13:27:53 »
Excellent.  Strong work, Metadot.  That's how you handle a defective product.
Offline itlnstln
« Reply #78 on: Thu, 05 November 2009, 14:28:01 »
Pretty much.
Offline JBert
« Reply #79 on: Thu, 05 November 2009, 15:24:26 »
Seriously, hiding behind "Das haben wir nicht gewusst!" is outrageous.
Maybe its some software development practice where they skimp on QA by sending their stuff to their [strike]guinea pigs[/strike] customers first and then fixing things if they ever turn up.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline lowpoly
« Reply #80 on: Thu, 05 November 2009, 15:31:20 »
Webwit's marketing critique aside, I think much of the blame goes to Costar who was a reputable OEM mfgr with Filco back then when Metadot chose them.
This last hickup could have been easily avoided at Costar as well. It's not like they didn't know the specs.
« Last Edit: Thu, 05 November 2009, 15:55:12 by lowpoly »
Offline ch_123
« Reply #81 on: Thu, 05 November 2009, 15:45:57 »
It would be very interesting to open up the new Das and see what sort of controller it has.
Offline Xero
    • http://www.xeron.cc
« Reply #82 on: Thu, 05 November 2009, 20:24:38 »
wow this is just crazy, they still haven't got a decent keyboard after all that hype. Blah, atleast they're trying to fix it, but I don't think I can even consider a das anymore...unless they make that front edge less sharp. Mid-december huh? Just around the same time for cherry g80-3000LSC's to hopefully start coming back in stock...
keyboards: cherry g80-3000 w/browns, das III, compaq mx11800, 2xblack dell at101w, nec apc-h412, black unicomp 101, ibm soft touch (greased buckling spring), model F AT, ibm model M industrial
mice: logitech g9, kensington expert mouse, logitech mx300
Offline Ulysses31
« Reply #83 on: Sun, 08 November 2009, 10:13:37 »
You typists clearly know nothing about keyboards >_>.  Tom's Hardware endorses this product, so clearly this is the only keyboard to have.
http://www.tomshardware.com/news/das-keyboard-ultimate,9022.html
Offline ch_123
« Reply #84 on: Sun, 08 November 2009, 10:16:53 »
Let the trolling of their comments section commence!
Offline ch_123
« Reply #85 on: Sun, 08 November 2009, 10:20:49 »
Mechanical keys are a thing of the past. sorry tom's hardware guru guy but those wear out. My friend used to have one. Key thing is, used to. The keys wore out and quit working so he threw it out. I'm still using a very old NEC keyboard that I picked up when they still actually had computer shows and it works as good as new. Only thing is it is one of those spill resistant ones with the rubber pad thingies inside. I actually own two. They work pretty good. Then this USB keyboard sitting next to me is sufficient as well, cost me $7 from newegg or some site like that and made by rosewill. Not a very high end keyboard but it does the job and works great on my xbox360, pc, and laptop.
This is America's answer to Sandy55. =P
Offline AndrewZorn
« Reply #86 on: Sun, 08 November 2009, 10:29:10 »
also, fun to read about the wonderful clicky feel of a razer lycosa.
Offline hyperlinked
« Reply #87 on: Sun, 08 November 2009, 11:26:43 »
Quote from: ripster;131017
Sounds like a lotta work for a keyboard.
They forgot the very crucial step number 1: check to make sure that your keyboard is not a Das.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline ch_123
« Reply #88 on: Sun, 08 November 2009, 11:33:57 »
Also, if you're Microsoft Windows, you may need to play around with Config.sys to make sure there aren't any of those pesky IRQ conflicts - Windows 95 didn't deal with them too well.
Offline JBert
« Reply #89 on: Sun, 08 November 2009, 11:56:48 »
Quote from: Ulysses31;131005
That article reads like a press release. Sure, they love it. But would it have been that much trouble to put it in their own words instead of rehearsing Metadot's incessant banter?
Seems Ars Technica's Das Keyboard article linked from TH was more decent and gave food for thought instead of more marketing talk.
Moving on... Any other reviewers out there with hardwarde troubles?
The storage list:
[/SIZE]
Offline Rajagra
« Reply #90 on: Sun, 08 November 2009, 13:12:23 »
How can Tom's Hardware readers be so misinformed? Must have gone downhill since I last spent time there.
Loved the complaint about the blank keyboard not being backlit...:crazy:
Offline exousia
« Reply #91 on: Mon, 09 November 2009, 17:36:27 »
Quote from: AndrewZorn;130470
Sacrificing **** to gain knowledge that it IS ****. Priceless. :)
Offline BucklingSpring
« Reply #92 on: Tue, 10 November 2009, 17:56:46 »
Quote from: itlnstln;129073
Ah, yes. $300 of Filco lovin'.
Wow... says kit, can you buy it built?
Boards I own, click ->
Offline itlnstln
« Reply #93 on: Wed, 11 November 2009, 11:41:36 »
Great suggestion at the bottom.
Offline AndrewZorn
« Reply #94 on: Wed, 11 November 2009, 12:40:43 »
i dont understand the greediness.  i mean, is there really any other ADDED costs than the circuit's parts?  as in, the DESIGN doesnt get more complicated, etc...
Offline bigpook
« Reply #95 on: Wed, 11 November 2009, 15:34:33 »
The shiny is nice and all. But its a pain to keep clean.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #96 on: Wed, 11 November 2009, 16:28:26 »
I like the nice dull yellowish-beige color my keyboards come in.
Offline bigpook
« Reply #97 on: Wed, 11 November 2009, 18:40:10 »
my model m mini is beige? off-white? it works for me. I would like to see the das after a round of cheetos action. shiny and orange.
« Reply #98 on: Wed, 11 November 2009, 18:59:54 »
Personally, I don't like black shiny computer equipment. (Not being racist against black computers here) It's just too prone to fingerprints. With my computers, people expect them to be dirty heaps of junk so I can put as many fingerprints as I want on them.
Offline bigpook
« Reply #99 on: Wed, 11 November 2009, 19:32:46 »
ripster, I don't think she really cares. Honest. But she does like the das with blue cherry switches. The thing is though, she doesn't know its a das and she has no idea what a blue cherry is.
She is no keyboard geek. However, she did tell me once that she liked it. Which is secret code telling me to leave it alone. I wanted to swap it out with the filco tenkeyless with brown cherries as I think she would like it. But I don't want to risk 'the look' : )
