Author Topic: IBM Mug  (Read 15760 times)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
IBM Mug
« Reply #50 on: Fri, 26 March 2010, 10:00:33 »
Quote from: HaaTa;166967
Nah, you mis-understand a bit (I agree with your point though, played lots of games myself). To be compatible with the TI 83 Plus Silver the OS can only utilize as much ram as the TI 83 Plus. So the OS leaves 64 K sitting there doing nothing and unusable... Why? Dunno.
The TI 84 series (successor) has the same amount of ram as the TI 83 Plus, so its probably a restriction to maintain app compatibility. Even in the 84 silver edition.
Ohhh, alright, yes, I see what you're saying.
Without having used the newer one my perspective is from the 83+ looking up to the newer ones, speaking only about what their specs claim rather than what ends up being usable.
kishy.ca
  • Live long and prosper
IBM Mug
« Reply #51 on: Sun, 28 March 2010, 15:19:49 »
You have an Apple mug there, so you have to get a Microsoft mug too.  Only then will you complete your set.
tp thread is tp thread
Offline Half-Saint
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline EverythingIBM
IBM Mug
« Reply #53 on: Sun, 28 March 2010, 18:17:13 »
Then you might want the IBM kitty mug:
Kitty sees IBM.
Offline kcsaff
IBM Mug
« Reply #54 on: Sun, 28 March 2010, 23:19:18 »
I saw the following come up in the "You may also be interested" section of one of my searches:
MUG ibm keyboard red lingerie computer vintage clicky
Someone needs to ask the seller what kind of IBM that is.  It's tough to say at that resolution, it kind of looks like a model F but I don't think an F is sexy enough.  Maybe it's a space saver.
Offline sethstorm
IBM Mug
« Reply #55 on: Sun, 28 March 2010, 23:35:11 »
To change things up a bit...
In a previous life, this mug came into my possession.
They are indeed part of the larger Atlanta-based entity that provides various newspaper and telecommunications products across the nation.  This was  a mug passed out in celebration of a major expansion.
I can't say they're "Evil Empire" but the parent entity(Cox Enterprises) is quite huge and well spread out in various forms across the CONUS.
Quote from: ripster;167693
The trick with company mugs is to find one that is decent looking enough you don't want to barf in.
Left mine untouched.
« Last Edit: Sun, 28 March 2010, 23:46:58 by sethstorm »
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
IBM Mug
« Reply #56 on: Mon, 29 March 2010, 01:29:47 »
ch_123 might like this mug:
