Author Topic: Doctor, My Balls Glow! - LED 101 - how to light up switches and trackballs  (Read 8202 times)
Offline elbowglue
Awesome mod ripster.  You are totally nuts, and I love it.
PS sorry I didn't know what the heck I was doing, I accidentally modded your original post (I didn't make any mods but it put my name on it heh.  I had no contribution to this fine post!)
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline nanu
    • http://T-T.be/portal
« Reply #1 on: Fri, 19 March 2010, 12:23:22 »
Good work.
Kind of makes me regret giving away that last smidgen of (bootleg) Lego I had in storage.
After getting some extra Cherry MX switches I'm considering embarking on a modding spree (replacing LCD display power buttons, PC power/reset buttons?  Maybe even IR remote controls with rubber-carbon membranes that inevitably fail).
Offline skcheng
    • Tenafly Dentistry
« Reply #2 on: Fri, 19 March 2010, 14:18:43 »
That's such an awesome mod!!!   Very cool.    Now where can I find one of those trackballs??    I don't think I've ever used one of those??
Offline didjamatic
« Reply #3 on: Fri, 19 March 2010, 15:38:48 »
Great mods Ripster.
Offline skcheng
    • Tenafly Dentistry
« Reply #4 on: Fri, 19 March 2010, 15:40:13 »
Quote from: ripster;165452
Trackballworld for all things trackball.  But I got these pretty cheap on Ebay, like $40 for the CST and $10 for the CH.   Gotta be patient though.
I haven't been able to figure out how to open up the Kensington Expert or I would have done that one too.  If anybody knows please post.
Edit:  Opening it up is simple.  Peel off the rubber feet.
Which one do you like better??   I see that the last two DT225 trackballs went for $77 and $31 on ebay.   Gotta love the big bay for deals.
Offline Rajagra
« Reply #5 on: Thu, 29 April 2010, 16:37:56 »
EDIT> Warning: I bought one of these and it was slightly too big (around 62mm?). It won't fit in a trackball like the CST without modifying it, e.g. widening the aperture. :Cry:
I bet one of these would look great in that:
LASER 3D ART CRYSTAL FLYING DRAGON GLASS SPHERE 2 1/4"
This is a neat 3-Dimensional Laser Crystal with FLYING DRAGON design. Using computers, special software and finely tuned lasers, the 3D image is engraved inside a solid sphere of optical quality crystal without affecting the crystal surface.
The crystal is highly polished. IT'S BRAND NEW. [strike]The diameter of sphere is 2 1/4 inches[/strike].
I'm thinking this:
« Last Edit: Sat, 08 May 2010, 06:37:44 by Rajagra »
Offline ironcoder
Nice work, Ripster. I'd like to figure out to replace the bearings in my Trackmen, if that is at all possible. They seize very shortly after cleaning. Anybody have any sapphire trackball bearings they don't need?
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ironcoder
I guess if you can afford Ruby trackball bearings you can probably afford the installation and the LearJet to fly the guy to your house to do the work.
Offline ironcoder
Thanks Ripster.
Offline yamaha200
Ripster,
 Does the clear 2.25" balls really work? or do you have them in there just for show. I have one about 57mm and I get no tracking.
Offline British
ripster, since you are toying with a 3200 dpi one, are you gonna give this wiki an addendum, so the outer buttons can be jacked-in instead of soldered ?
Also, is the LED for DPI the same in the 3200 than in the "older" 1600 ?
