Author Topic: Speaking Of North Korea, No typos or transposition errors PLEEEZZZZZ  (Read 2817 times)
Offline wap32
I found the first image pretty funny. :biggrin:
The photos remind me of WarGames.
Still, how do you design a mission-critical keyboard?
Does it use two switches per key for redundancy or something? Or is it just a regular keyboard built with military-spec parts?
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #1 on: Fri, 26 November 2010, 17:36:04 »
Fortunately, it looks like the X Window System - maybe ancient fvwm - on those screens. Had the computers involved in this critical task been running Microsoft Windows, a comment to the effect of "We're all DOOOMED" would have been de rigeur at this point.
But OS/2 I could live with.
Offline nathanscribe
« Reply #2 on: Fri, 26 November 2010, 19:30:59 »
Quote from: wap32;252583
That is exactly what I was thinking.  Turn the key SIR!
Conquering the world with BASIC since 1982
Offline 8_INCH_FLOPPY
« Reply #3 on: Fri, 26 November 2010, 20:08:06 »
They probably don't worry too much about keyboards, considering how reliable they are.  I bet they worry more about the complicated network of electronics and mechanics that launches the missiles, not to mention the guidance system.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline ch_123
« Reply #4 on: Sat, 27 November 2010, 05:39:25 »
Quote from: quadibloc;252735
I'm not so sure that that can be counted as 'fortunate'
Offline ricercar
  • mostly abides
« Reply #5 on: Sat, 27 November 2010, 11:11:27 »
In the late 1990s you'd put a Motorola 68030 CPU with firmware on every key, programmed to prevent keybounce and other undesirable behavior. At least this is what they did on the stealth aircraft.
Source: the man at Northrop who wrote the firmware.
Offline RickyJ
« Reply #6 on: Sun, 28 November 2010, 01:04:07 »
Newfoundland, Canada's lifeboat.  Quebec might survive but it'd sink in the Atlantic from all the poutine on board.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
