Author Topic: Duckys - I Don't Recommend Their ISO Layout  (Read 3559 times)
Offline bugfix
« on: Sat, 08 January 2011, 10:35:37 »
My Enter key has only one Cherry switch under it...
(DAS Model S)
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline 7bit
  • MX1A-G1DW
« Reply #1 on: Sat, 08 January 2011, 10:39:44 »
Quote from: ripster;275157
Remember one Geekhacker complaining about their bigass Enter key being a bit stiff.
Great cost-efficient idea!
If this keyboard is ever resold, just put your ANSI or ISO-layout key caps on.
Much better than having 2 incompatible versions!
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline bpiphany
« Reply #2 on: Sat, 08 January 2011, 11:17:21 »
What's ISO in that layout? To me it just looks like the worst combo possible of ISO and ANSI... I would have understood if there was a switch in the position immideately to the right of '" and another with stabilizers vertically on the right side. This doesn't make any sense at all.
Edit: Well that wouldn't work either of course =P Bigass enter keys like that makes little sense at all I guess.
« Last Edit: Sat, 08 January 2011, 11:20:03 by PrinsValium »
Offline Soarer
« Reply #3 on: Sat, 08 January 2011, 11:29:17 »
Most ISO keyboards have a different arrangement like this.
That is not ISO, nor is the Ducky.
or just a hole and a peg like this
That is.
I have a Dolch with a bigass enter which had two switches, I just removed the dummy one.
Offline sixty
    • http://deskthority.net
« Reply #4 on: Sat, 08 January 2011, 11:33:44 »
Cherry used this method too on their "US" version of the MX2100:
The enter key has 2 switches underneath, one of them missing the spring. Works out quite well.
And yeah, as Soarer just mentioned.. that is the "obscure Asian-American huge ass L enter layout" and not ISO.
Offline Minskleip
« Reply #5 on: Sat, 08 January 2011, 11:35:10 »
He can desolder all the switches, open up the uppermost of the big ass-enter and remove some of the inards and make it less stiff!
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline fssbzz
« Reply #6 on: Sat, 08 January 2011, 15:37:30 »
Thanks to the detective work by Fssbzz who asked at another keyboard forum.
actually i asked Jimmeh from Geekhack tru Geekhack pm and forward it to you. lol
« Reply #7 on: Sat, 08 January 2011, 17:19:26 »
Offline Pylon
« Reply #8 on: Sat, 08 January 2011, 18:03:07 »
It looks oddly cluttered, though that serifed Chinese font seems to give it an odd character (no pun intended). Reminds me of Confucius.
Offline fssbzz
« Reply #9 on: Sat, 08 January 2011, 18:27:39 »
i wonder if change that BIGASS enter to regular size enter and replace it with the "\" key cap on ducky 1008?
Offline laden3
« Reply #10 on: Sat, 08 January 2011, 18:40:26 »
Quote from: fssbzz;275416
Taiwan already has that... a few days ago...
I rrrove brrracks.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #11 on: Sat, 08 January 2011, 18:44:42 »
Quote from: ripster;275408
I have no idea why 3 "extra" character, do you?
On the upper left on the keys, in red, is the character set known as "Bopomofo", or the "National Alphabet". This is an alternative way to express Chinese phonetically, instead of using our Roman alphabet to type in Pinyin.
The lower right of the keys contains the characters assigned to the keys when typing text using the DaYi input method. That is a popular and efficient commercial input method for Chinese which allows typing characters based on their appearance.
The lower left of the keys contains the characters assigned to the keys when typing text using the Zhuyin Fuhao input method. This is another method for typing in characters based on how they look; it's the most common one which has been around for quite some time.
Offline fssbzz
« Reply #12 on: Sat, 08 January 2011, 18:47:39 »
Quote from: laden3;275426
mind explain it more clear with some source?
Offline laden3
« Reply #13 on: Sat, 08 January 2011, 18:56:59 »
Quote from: fssbzz;275435
... search pchome, told u to join the discussion group...
I rrrove brrracks.
Offline fssbzz
« Reply #14 on: Sat, 08 January 2011, 18:58:39 »
Quote from: laden3;275441
sigh. you expect me to type english in PCHOME, just to search for that enter key?
well that's ok.
not really important to me.
Offline laden3
« Reply #15 on: Sat, 08 January 2011, 20:03:05 »
go to google, search "world pchome", then search "ducky". The words in " " are Chinese characters, so, it's better to copy n paste.
The keyboard is kinda expensive compare to the one with L shaped enter.
I rrrove brrracks.
Offline Moogle Stiltzkin
« Reply #16 on: Sat, 08 January 2011, 22:41:24 »
the dk-9008 i got came with a small enter. Not this L shape enter in the picture you showed :/
Also Cherry keyboards also have those cherry stabilizers but i didn't hear complaints about them. So what makes Ducky different from those ?
Pressing down on the stabilizer keys seem fine to me, and has no wobble to it.
There is of course a different feel (some stiffness) between the enter vs  typing  on the smaller keys , but that seems fine to me :X
Anywayz i liked the cherry stabilizers because i could easily replace those keys without much hassle or worry about breaking the keyboard.
Royal Kludge discount code:
Lowyat15
15 USD discount.
