Author Topic: Cherry MX Switch Lubrication Guide  (Read 599266 times)
Offline Aranair
  • Software Engineer @ PocketMath
    • Tech blog
Re: Cherry MX Switch Lubrication Guide
« Reply #300 on: Fri, 17 May 2013, 09:56:28 »
i can't get hold of 105 oil so i'm using 205 only. Maybe its a mistake damn lol.
...Time to look for some clear switches for my poker ...
Present  : HHKB Pro 2 Type-S White | HHKB Pro 2 White Blank | Ergodox EZ
Past      :  Poker 2 Brown | Black Widow Ultimate Blue | Filco TKL Brown
Offline Photoelectric
« Reply #301 on: Fri, 17 May 2013, 11:17:55 »
Have you guys lubricated "new" black switches, including the spring?  If so, how would you describe the change (if there was a noticeable change)?  Wondering if lubricating would make them a tad easier to press.
Offline godly_music
« Reply #302 on: Mon, 20 May 2013, 15:14:44 »
I used PTFE (Teflon) to lube brand new MX Blacks and it actually made them stiffer. I wouldn't touch new switches.
« Reply #303 on: Mon, 20 May 2013, 15:39:55 »
Good to know--thanks!  I wonder if its because that lube has thick consistency and fills tiny unworn spaces to make overall movement more difficult, even if reducing friction on the moving parts.
« Reply #304 on: Tue, 21 May 2013, 06:24:42 »
Lubrication very rarely makes them easier to press. That isn't the attraction. Lubing makes the action smoother. If you use grease then you will definitely notice that the switch is stiffer, if you use an oil or a mixture or an oil & grease then it only feel a little heavier, if at all.
New blacks do feel much smoother after lubricating. Incredibly smooth, and incredibly nice to press. If you want a lighter version just use reds.
Offline Masterchief79
« Reply #305 on: Tue, 21 May 2013, 09:25:28 »
I have a 1984-1986 keyboard with prototype blacks here (no cherry logo on them). They are extremely scratchy and have a lot higher press-resistance if you don't hit the cap right in the middle. I was thinking about lubricating them, but I'm not sure yet... They are plate-mounted, so I would have to solder them out, and on the other hand I also don't want to ruin my nice old vintage keyboard by changing the typing feeling^^
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
« Reply #306 on: Tue, 21 May 2013, 10:04:31 »
No I definitely don't want reds.  Im very much enamored with the feel of blacks after trying them out on an acquaintance's Steelseries 7g, where they felt worn in and very smooth.  No noticeable Grundy friction.  They seemed easier to press than another MX black keyboard I tried briefly at PAX East, but then the latter was brand new.  I was just wondering if lubricating would help with that smooth worn-in feeling that required a slightly lighter touch, but I guess it's all about actually using the switches for a good long while.
Offline Aranair
    • Tech blog
« Reply #307 on: Sat, 25 May 2013, 08:54:39 »
quick question again: is a mix of 105 oil and 205 grease suitable for springs/stem or is the mixture too viscous still?
« Reply #308 on: Sat, 25 May 2013, 09:04:56 »
For springs you want only the oil. And since Krytox oil is expensive, most people use other oils for those, Victorinox multi tool oil, for example.
Offline Aranair
    • Tech blog
« Reply #309 on: Sat, 25 May 2013, 09:08:02 »
oh well, i don't know if i was dreaming or what when i bought the 105. I wanted the 103 but bought the 105 instead /sigh
I guess i'll just make do with the expensive one (lol)
« Reply #310 on: Thu, 13 June 2013, 18:09:52 »
What do you use to clean Costar stabilizer bars prior to lubricating?  Alcohol is okay for that?  Are those bars mostly rust-proof?
Offline fateswarm
« Reply #311 on: Fri, 14 June 2013, 19:34:54 »
Let's assume I have a switch with a LED on it that probably needs disoldering to be taken apart and let's assume I will not do it.
If I drop a couple of droplets above the switch while the top of it is depressed (oil entering the caved-in area around the main 'cross'), what areas will the oil be able to access after I press the switch a few times?
Will it reach all areas around the top? Will it reach the spring on the inside?
Offline gnubag
« Reply #312 on: Sat, 15 June 2013, 14:05:00 »
1. maybe
2. not until you flood the switch
Offline fateswarm
« Reply #313 on: Sat, 15 June 2013, 15:21:45 »
Hrm, that's encouraging because I have developed the following brutal method:
If it's flooded, blowing compressed air in it pushes everything out.
It's still safe for the mechanism itself.
Offline Nakapfao
« Reply #314 on: Sun, 16 June 2013, 16:51:15 »
Slick guide, thanks ^_^
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #315 on: Sun, 16 June 2013, 22:37:27 »
you can try it on a test switch but i doubt it will work, you really need to disassemble the switch assembly to properly lube. if you are going to go through the trouble to lubricate i highly suggest learning to desolder and solder, its seriously not hard when it comes to switches and leds; just don't apply too much heat or too little heat and its easy. in fact i would say doing the dis assembly of the switch and lubricating is more work than desoldering and soldering.
on another note i am lubricating right now a race with reds and im trying a different method for the springs, for the stem/sliders i used 205/103 mix with a fine paint brush and then for the springs instead of using machine oil i used the silicone lube that dries with a film, it seems to work fine. maybe not the full effect that machine oil would do but it does soften the spring's contact with the assembly. I was just afraid of over-lubricating the whole assembly which i think i did for a few switches on my first lubrication job i did on my ergodox #1.
« Last Edit: Sun, 16 June 2013, 22:43:00 by Glod »
Offline calavera
« Reply #316 on: Sun, 16 June 2013, 22:53:37 »
Quick and dirty way to lube springs is to put all of them into a plastic bag, add few drops of lube, seal with air in it as if it were a ballon. Commence shaking the crap out of it. :P
Offline Glod
    • YouTube Channel
« Reply #317 on: Sun, 16 June 2013, 22:57:53 »
i did a similar thing with the silicone lube that drys into a film, i put them in a small Rubbermaid container like you would put leftovers in and then applied lube, shifted it around and then let the springs sit for a day to dry, they were then lubricated via the dry film. Again, it is not the same effect as the machine oil but it does lubricate the spring at the point of contact with the assembly of the switch. its obviously something to try and decide not exactly a recommendation.
Offline fateswarm
« Reply #318 on: Mon, 17 June 2013, 17:07:19 »
The issue with disoldering a switch with a LED isn't exactly knowledge but if it's worth the work needed (and the connection points are at least 4 for each switch, because of the extra LED). I'm not even experienced, but even if I were, I find it not worth the trouble if it has to be done on one hundred keys.
If flooding with any method works I prefer it even if it's messy.
If I were making it something from scratch etc. etc. then it might seem worth it. It's about personal priorities.
« Last Edit: Mon, 17 June 2013, 17:28:30 by fateswarm »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #319 on: Mon, 17 June 2013, 17:11:29 »
This. I sold my Ducky Shine II with Clears for this exact reason. Desoldering LED's is such a pain in the ass because not only is there 2 extra points per switch, they are also smaller and much harder to desolder.
Offline ksm123
« Reply #320 on: Tue, 18 June 2013, 05:52:17 »
Can somebody show me, how to disassemble a switch on ErgoDox without desoldering (on Massdrop's acrylic plate).
What tool do you use to open "snaps" in the switch?
OK I see it, my wrong, I was trying to pry open the switch from below. The correct way to do it is to use 2,4mm flat screwdriver as a lever. You insert it (verticaly) into side of top switch housing, where there is a "socket" prepared for it. The rest is as simple as YouTube video shows it is.
I used FinishLine Extreme Fluoro on stems, I distributed it with brush. Now my MX Clears feel real smooth :-)
« Last Edit: Fri, 28 June 2013, 03:33:46 by ksm123 »
« Reply #321 on: Tue, 18 June 2013, 07:06:29 »
I'm not sure this is possible, unless the ergodox has the extra cutout for the switch to be opened. Most boards do not.
Offline ksm123
« Reply #322 on: Tue, 18 June 2013, 07:33:46 »
There are cutouts on the sides, but acrylic plate is much thicker than metal plates.
Offline Glod
    • YouTube Channel
« Reply #323 on: Wed, 19 June 2013, 03:56:41 »
It has those extra notches so the switch can be opened. It was a nice touch litster put in his case design.
Offline kaiserreich
  • HHKB Elite
« Reply #324 on: Tue, 25 June 2013, 05:47:22 »
Victorinox oil is so hard to get around my place.
Any known problems with using Singer oil? (Sewing machine mineral oil)
Offline WhiteFireDragon
    • youtube
« Reply #325 on: Fri, 28 June 2013, 18:28:01 »
I think it might be ok. Maybe even victorinox oil is just a glorified version of sewing machine oil. Can't really confirm this because we don't know the composition of what the oil actually is. As long as it's relatively high viscosity, plastic and metal safe, it should be fine.
Offline cgbuen
    • cgbuen.io
« Reply #326 on: Sun, 07 July 2013, 04:05:20 »
I haven't found a more recent discussion on lubing stations other than the small lubing station IC thread, but I just wanted to share my makeshift one:
For several months now, I've been using WFD's universal plate as a lube station. I used to have to fit in the switch bottoms on all the ends/throughout the whole plate for it to balance, as they'd stand on the pins. Then I'd have to lay it all on top of something (usually a thin piece of plastic) so the pins wouldn't scratch up my workspace.
Somehow it only hit me tonight that I could lay it atop a TKL top cover for better results. If you've already opened up a board for servicing, you could just use that. Or if you're like me, you could use the branded QFR top cover that you never knew what to do with (since I got unbranded one from CM's store several months ago).
« Reply #327 on: Sun, 07 July 2013, 04:06:56 »
Hah I wish I ordered an extra plate to do that with. Smart!
Offline gnubag
« Reply #328 on: Sun, 07 July 2013, 04:38:59 »
maybe he still has some, pm him :)
« Reply #329 on: Sun, 07 July 2013, 04:39:41 »
Nah I'm good for now, I won't be building any new boards soon I don't think.
« Reply #330 on: Fri, 19 July 2013, 11:26:44 »
How many of you put some oil into this depression where the stem travels:
I saw on WFD's wonderful lubing video that it's good to put high viscosity oil in there (like Victorinox), but I'm wondering if this will slow down the stem movement.  Or is that viscosity not enough for that effect vs. spring stiffness?
« Reply #331 on: Fri, 19 July 2013, 11:32:42 »
I plan on doing something like this but was thinking of using some rubber feet or stand offs but never thought to just throw a QFR top underneath!!
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #332 on: Fri, 19 July 2013, 13:52:41 »
I've followed WFD's video and done that on both reds and blacks and had no issues. Like WFD, I also lube the stem with the same oil.
Lubing MX-White
Last night I tried a couple of different methods of lubing MX-White switches and had mixed results.
   - Lubing the side rails killed the click.
   - Lubing the actuator on the clicking element killed the click
   - Lubing the post hole and stem reduced the click
Ultimately, I just don't think it's worth it. Either I don't have the patience, or the right mix and since MX-White have a softer click, I just didn't want to spend the time.
Anyone else have any success lubing MX-White switches?
« Reply #333 on: Fri, 19 July 2013, 13:54:21 »
Lubing MX-White
Don't they come pre-lubed to some degree from the factory?
Offline mashby
    • Mashby
« Reply #334 on: Fri, 19 July 2013, 13:56:13 »
There did feel to be a little bit of a residue of something on the spring and clicky part, but it's hard to say definitively. I'm installing switch stickers, so I figured while I was in there, I could give some tests a go.  ;D
« Reply #335 on: Fri, 19 July 2013, 14:10:53 »
He only used the high viscosity oil on the springs and the inside of the hole in the bottom part of the housing.  For the rest, he used the Krytox mixture, like the stem sides and front.
Offline gnubag
« Reply #336 on: Fri, 19 July 2013, 14:38:15 »
Lubing MX-White
I have tried some very low viscosity sewing machine oil on blue stems. it worked for me when I was only lubing the railes and the hole where the stem is moving in. almost no change in sound.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #337 on: Fri, 19 July 2013, 15:59:51 »
I put Victorinox oil in the hole. It doesn't slow down the stem movement at all. The main reason for doing it is to reduce the bottoming out sound and I love the soft sound it produces. HOWEVER, I've had experiences where if you put too much oil in there, the stem will make a popping sound when going into the hole because of the bubble being formed and pushed down until it pops because of too much oil in there. It doesn't slow down any movement of the stem but it can throw you off when you feel the slight pressure build up as you press down until it pops... it's actually kind of nice feeling :)) but the inconsistency would throw you off. It does eventually go away though, which I assume is a result of the oil being pressed out and distributed around.
« Last Edit: Fri, 19 July 2013, 16:01:22 by VesperSAINT »
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #338 on: Fri, 19 July 2013, 21:14:38 »
Just don't put EK mechlube in the hole... God help you if you do... (Yes, I was the poor sod who tried putting EK Mechlube in my capslock switch over a year ago...) Thin oils are just fine, but it isn't really necessary or noticeable.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline turtle
« Reply #339 on: Tue, 13 August 2013, 01:20:52 »
I am in the process of lubing, plate, and stickering  on my cm qfr w/ ghetto greens but only have the kryptox 205 grease. I see the guide don't recommend it with clickys stems but wondering if anyone tried it. Planning to do it since i got it sitting at my desk. What  other recommendation would you guys recommend for set up. Thanks.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #340 on: Tue, 13 August 2013, 01:26:38 »
I've done it for keyboard science. DON'T DO IT. Why? From my experience, you'll lose all clicking and it'll just feel broken, and I only lubed the sides of the stems and not even the slide itself! The bad-feels you get is almost identical to when you get switches that won't click on a clicky keyboard (those that have felt this issue know the true heart ache). Once you've lubed them, you'll have to clean all the stems and replace the switch housing because you can't even clean those, which might even mean you might have to desolder all your switches out for new ones... I really do highly recommend you don't lube your clicky switch.
« Last Edit: Tue, 13 August 2013, 01:30:50 by VesperSAINT »
Offline Grim Fandango
« Reply #341 on: Tue, 13 August 2013, 01:59:21 »
Thanks for this guide. I am contemplating lubing at least one of my keyboards, but I am not sure whether I would like the result. At least now I know how to do it without messing it up.
Offline turtle
« Reply #342 on: Tue, 13 August 2013, 07:58:09 »
Thanks for your input! are you referring to just kryptox 205 or lubing them in general?
Offline The_Ed
« Reply #343 on: Tue, 13 August 2013, 08:11:03 »
Krytox 200 (the thinnest of the krytox greases) kills the click, and even the krytox oils have been known to kill the click. That is why there is the consensus that if you have clicky switches you shouldn't lube them. The tiniest amount of lube is enough to slow down the click slider enough for it to no longer click.
R.I.P.ster
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #344 on: Tue, 13 August 2013, 09:01:50 »
all the krytox greases have the same viscosity.
Offline turtle
« Reply #345 on: Tue, 13 August 2013, 11:09:07 »
Okay, I'll leave my ghetto greens alone. Thank you all =]
Offline The_Ed
« Reply #346 on: Tue, 13 August 2013, 15:02:48 »
No they don't... I have 200 and 205, and their viscosities are completely different. The lower the number the thinner the grease/oil.
R.I.P.ster
Offline mellohello
« Reply #347 on: Wed, 14 August 2013, 20:54:09 »
Can anyone comment on using sprays on plate mounted keyboards? I've had my MX Black Quickfire Rapid for something like a year and would prefer to get rid of that scratchy feeling. I guess I just press down the stem and spray. Is this method long-lasting/effective?
Thanks.
« Reply #348 on: Wed, 14 August 2013, 21:15:55 »
Thanks.
Its not really a recommended method.
Offline mellohello
« Reply #349 on: Wed, 14 August 2013, 21:19:44 »
K :(
Thank you.
