Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Projects
Making Stuff Together!
(Moderator:
Soarer
Cant easily swap stems and springs if the switches have LEDs?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Cant easily swap stems and springs if the switches have LEDs? (Read 4298 times)
oTurtlez
DAT ZACKATTACK
Thread Starter
Fo' Realforce
on:
Fri, 10 August 2012, 10:14:54 »
Hey guys, i read somewhere that you can't swap a stem or spring on switches that have LEDs without completely desoldering the switch from the pcb, is this true? If so, why is it like that?
Logged
Quote from: mkawa on Tue, 03 December 2013, 15:06:18
TOO BAD FOR YOU
Phantom 62g
MX Whites
alaricljs
I be WOT'ing all day...
Moderator Emeritus
Re: Cant easily swap stems and springs if the switches have LEDs?
Reply #1 on:
Fri, 10 August 2012, 10:18:46 »
On a PCB mount board you need only desolder the LED. The LED leads go through the top and bottom switch housings and quite thoroughly ping it shut.
Logged
Filco
w/ Imsto thick
PBT
oTurtlez
DAT ZACKATTACK
Thread Starter
Fo' Realforce
Reply #2 on:
Fri, 10 August 2012, 10:21:02 »
Ahh, this would make sense then. God damn me having to get the LED pure lol. Debating whether or not going from reds to ergo clears is worth it for all of the work
EDIT: Have you or anyone here had any experience with the o-ring sound dampeners? I might snag a set of those instead if theyre worth it.
Logged
TOO BAD FOR YOU
Phantom 62g
MX Whites
alaricljs
Moderator Emeritus
Reply #3 on:
Fri, 10 August 2012, 10:26:01 »
No personal experience w/ o-rings but plenty of people here have used them red->ergo clear is *completely* different than red->red&o-rings.
Ergo clears have the sizable tactile bump of clear switches with the same spring as red/brown/blue switches. Red w/ o-rings is just red with a squidgy bottom-out that's a little higher than normal.
Logged
Filco
w/ Imsto thick
PBT
oTurtlez
DAT ZACKATTACK
Thread Starter
Fo' Realforce
Reply #4 on:
Fri, 10 August 2012, 10:27:31 »
Yeah, I know, but I just dont trust myself with my ****ty soldering iron on the back of my brand new keyboard, know what I mean lol?
Logged
TOO BAD FOR YOU
Phantom 62g
MX Whites
SmallFry
Moderator Emeritus
Leaving 6/15; returning 6/22 or so.
Reply #5 on:
Sun, 19 August 2012, 12:16:09 »
I'll do it for you if you have the parts. I have a good iron at home.
Logged
Thanks much,
SmallFry
Meebcast Mondays and WiredTangenT Tuesdays
Check out the
Click Clack Wiki
and my own
Projects!
CALLING ALL CLACK OWNERS!
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Projects
(Moderator:
Soarer
