Author Topic: Free stuff! Pay it forward!  (Read 15408179 times)
Offline iloveucla
  • Trade Count: (0)
Re: Free stuff! Pay it forward!
« Reply #3350 on: Tue, 17 June 2014, 19:01:55 »
Does anyone have a working model m cable? I just got a model m with no cable.... :-[
  • Trade Count: (0)
« Reply #3351 on: Tue, 17 June 2014, 19:11:37 »
If you don't end up finding one for free in this thread and need to buy one, you'll want to look for an SDL cable*.  You can buy them fairly readily if it comes down to it, though they're not super cheap.
*Unless there's another possible cable for Model Ms that I'm not aware of?
Offline iloveucla
  • Trade Count: (0)
« Reply #3352 on: Tue, 17 June 2014, 19:13:43 »
Yeah, I think I will order one from unicomp if I cant find anything here, I just wanna know if someone has a very old but still working cable so I can test it out before I buy the cable.
Edit: I just got one accidentally today, $34 shipped without cable, 401 1992 model m, I am very new to the model m world, I just find out it use SDL cable"I believe"....
« Last Edit: Tue, 17 June 2014, 19:17:13 by iloveucla »
  • Trade Count: (0)
« Reply #3353 on: Tue, 17 June 2014, 19:30:12 »
Cables from orihalcon are VERY highly recommended:
http://www.ebay.com/itm/USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Model-M-Clicky-Keyboard-Cable-NEW-/271367683396
http://www.ebay.com/itm/BEIGE-USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Model-M-Clicky-Keyboard-Cable-NEW-/271470078682?pt=LH_DefaultDomain_0&hash=item3f34e0aada
Offline badloop
  • Trade Count: (0)
« Reply #3354 on: Thu, 19 June 2014, 12:08:28 »
OK, I have a set of all white blanks from this group buy (http://geekhack.org/index.php?topic=31861.0), however I am missing the non-stepped caps-lock and 2.25 right shift key.  These are IMSTO thick PBT... ideally what I would want is a full grey IMSTO modifier set, but really any color of IMSTO thick PBT would be nice so I could have a complete set.
I know its a long shot, just thought I'd see if anyone out there has anything.  Hit me up on here or I idle in the IRC channel all the time.
« Last Edit: Thu, 19 June 2014, 15:03:43 by badloop »
PBT FTW
Offline roaming pear
  • Trade Count: (0)
  • THE Roaming Pear
« Reply #3355 on: Thu, 19 June 2014, 14:31:43 »
Anyone have a dell inspiron laptop charger?
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline user 18
  • Trade Count: (0)
« Reply #3356 on: Thu, 19 June 2014, 16:09:28 »
You'll need to be more specific than that -- huge wide range of chargers that work with different inspirons.
Avatar by ashdenej
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #3357 on: Thu, 19 June 2014, 16:18:14 »
Are you sure about that? My charger for an insprion I got in 2004 works with the one I got in 2012
Offline user 18
  • Trade Count: (0)
« Reply #3358 on: Thu, 19 June 2014, 17:07:51 »
Maybe I just have the weird instance then -- The last inspiron I had was a 5100, and the connector isn't even physically the same as inspirons from today.
You also need to be aware of the specifications of the ac adapter. The output voltage needs to be the same, and the current needs to be the same or greater (I think).
Avatar by ashdenej
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #3359 on: Thu, 19 June 2014, 17:11:57 »
When using a 60 watt power supply from the old laptop with the new one, it still worked but every time I plugged it in it said that 90 watt would be ideal but not necessary. So as long as the plugs the same, they should work. Hell, I even used HP power supplies on the dell and it worked no problems
Offline user 18
  • Trade Count: (0)
« Reply #3360 on: Thu, 19 June 2014, 17:48:47 »
I'm glad it's worked out well for you. Just keep in mind that it's not always safe to use a different ac adapter, particularly if the voltage is wrong. Some devices have a wide enough voltage range that a slightly different voltage range is acceptable, but not necessarily will any adapter that physically fits work. In terms of current, you need a current rating high enough to provide the necessary energy to run the machine. For safety, you should always use a current rating high enough to provide the necessary power (watts, W = V * A). Because the voltage needs to be the same, this means you need a current equal to or greater than the original current on the ac adapter.
A message saying a higher watt power supply is recommended would be related to the fact that ac adapters are rated with maximum output specifications. An adapter rated for 90w (example 4.74A) can supply 60w (ex. 3.16A) without trouble, but if the system attached to it requires 80w for a period of time (it's being stressed for some reason), a 60w supply can't safely meet that demand.
It's great that you haven't had any issues, but the physical fit is one of the last things you should be worried about. I or another user may have an adapter that works for roaming pear, but I personally wouldn't feel comfortable sending one unless I knew I was sending something that wasn't liable to fry something or start a fire.
Avatar by ashdenej
Offline blighty
  • Trade Count: (0)
« Reply #3361 on: Thu, 19 June 2014, 18:24:03 »
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR11.TRC1.A0.H1.Xdell+inspiron+charger&_nkw=dell+inspiron+charger&_sacat=0&_from=R40
More than likely you can get one for under $10 shipped.  Even if someone had a spare, shipping would be $5 or $6.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline combataran
  • Trade Count: (0)
« Reply #3362 on: Fri, 20 June 2014, 07:21:39 »
Edit: sorry wrong thread
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline xAznxStylezx
  • Trade Count: (0)
« Reply #3363 on: Fri, 20 June 2014, 21:11:30 »
Does anyone happen to have these keycaps I could have?
4x White PBT 1.25 Mods
1x White PBT 2.75 Shift (Right shift)
My order of white PBT banggood keycaps shipped with a 84 key set so I'm missing those 5 keycaps until I have a full set ):
Either those.. or a full set of PBT mods, but I'm assuming this is more unlikely haha.
Located in Canada.
Thanks.
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #3364 on: Fri, 20 June 2014, 21:14:24 »
Located in Canada.
Thanks.
I assume OEM?
  • Trade Count: (0)
« Reply #3365 on: Fri, 20 June 2014, 22:10:58 »
Located in Canada.
Thanks.
I assume OEM?
Yeah, I believe they're OEM profile.
The ones that arrived are http://www.banggood.com/84-White-Blank-Set-PBT-Key-Caps-For-Cherry-MX-Switch-p-83642.html
Offline swill
  • Trade Count: (0)
  • builder & enabler
    • swillkb.com
« Reply #3366 on: Sat, 21 June 2014, 00:15:07 »
Located in Canada.
Thanks.
I assume OEM?
You may consider getting these: http://www.banggood.com/Keycool-PBT-Multicolor-Top-Or-Side-Or-Blank-Laser-Engraving-Keycap-p-84137.html
They are pretty good for the price.  I have a set of the blanks on my keyboard now.  I do OEM bottom row with my Cherry profile Thick IMSTO PBTs because the OEM bottom row matches the spacebar profile better.  Its another option anyway...
  • Trade Count: (0)
« Reply #3367 on: Sat, 21 June 2014, 16:35:01 »
Located in Canada.
Thanks.
I assume OEM?
Ah, yeah I've seen those. I was looking to have all my mods the same color.
Offline Beca
  • Trade Count: (0)
  • what am i doing with my life
« Reply #3368 on: Mon, 23 June 2014, 21:30:10 »
Anybody have an extra wire keycap puller I can use? I left mine in storage back at school and I'm getting the Penumbra set soon :( I will of course pay for shipping and ship it back to you after I get back to school!
Offline tigersharkdude
  • Trade Count: (0)
« Reply #3369 on: Mon, 23 June 2014, 21:33:01 »
You can buy a brandnew piwce on Ebay for like $5
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #3370 on: Mon, 23 June 2014, 21:34:31 »
make one yourself? Unfortuantly I gave my spare to a friend to use on his first mech
  • Trade Count: (0)
« Reply #3371 on: Mon, 23 June 2014, 21:38:49 »
I got you. PM me.
Offline Beca
  • Trade Count: (0)
« Reply #3372 on: Mon, 23 June 2014, 21:44:30 »
I got you. PM me.
thank you <3
@pacifist: the thought of swapping 87 keycaps with crappy homemade paper clip pullers is just terrible x.x i'm back in norcal for now though~
Offline PublicAnarchism
  • Trade Count: (0)
« Reply #3373 on: Mon, 23 June 2014, 22:59:30 »
Anybody got a OTG cable? I am wanting to use my mech with my nexus.
  • Trade Count: (0)
« Reply #3374 on: Mon, 23 June 2014, 23:19:31 »
I know this isn't quite the nature of this thread, but I got my OTG cable quite cheap, less than $5 if I recall correctly.  Or is that not an option given your location or something?
Offline Xenderwind
  • Trade Count: (0)
« Reply #3375 on: Mon, 23 June 2014, 23:21:14 »
There was even a thread posted just a couple days ago...
http://www.ebay.com/itm/Universal-Micro-USB-Male-To-Female-OTG-Cable-for-Micro-USB-Phones-Tablets-MB97-/261450192337?pt=US_Cell_Phone_PDA_Cables_Adapters&hash=item3cdfa555d1
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline intelli78
  • Trade Count: (0)
« Reply #3376 on: Tue, 24 June 2014, 12:19:14 »
^ Yup, less than a dollar shipped to the USA. Many of the low priced USB OTG cables on eBay somehow show <$1 shipped on the search page but don't actually have free shipping. Not sure how those sellers have hacked the eBay search results. But that cable really is less than $1 shipped.
Offline SSIPAK
  • Trade Count: (0)
  • ★ Bootlegcaps ★
« Reply #3377 on: Tue, 24 June 2014, 23:56:29 »
Anyone have spare GMK PBT keycaps (Esc, F keys, and Number Row)? I need for a little project, let me know. Thank you!  :thumb:
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #3378 on: Wed, 25 June 2014, 00:00:37 »
Not much giving lately, in the spirit of summer sales, a Eets Munchies Steam Key, one letter removed to fool bots
5PYVQ8TUGNJ07F9
Offline BlueBär
  • Trade Count: (0)
« Reply #3379 on: Wed, 25 June 2014, 03:27:24 »
You mean BSP, GMK only produces ABS ;)
Offline SSIPAK
  • Trade Count: (0)
  • ★ Bootlegcaps ★
« Reply #3380 on: Wed, 25 June 2014, 03:54:14 »
oh my bad, yes BSP PBT. Thanks for your correction! :)
Offline Dubsgalore
  • Trade Count: (0)
« Reply #3381 on: Wed, 25 June 2014, 10:15:33 »
Anybody have 7x wires that they don't need? I have plenty of stabs just need some 7x luv
Offline mkawa
  •  No Marketplace Access
  • Trade Count: (0)
  • (ツ)@@@. crankypants
« Reply #3382 on: Thu, 26 June 2014, 17:57:30 »
110 matias quiet click switches. fcfs cost of shipping only (like 5$ domestic). i can always buy more when we get a board design together, but darned if i want to move switches that have been sitting for 10 months :P
  • Trade Count: (0)
« Reply #3383 on: Thu, 26 June 2014, 18:22:42 »
Im not familiar wirh cap models yet, but if this what the Quickfire Rapud has I can send you some
Offline user 18
  • Trade Count: (0)
« Reply #3384 on: Thu, 26 June 2014, 18:35:14 »
QFR is OEM profile ABS.
Avatar by ashdenej
Offline swill
  • Trade Count: (0)
  • builder & enabler
    • swillkb.com
« Reply #3385 on: Thu, 26 June 2014, 22:22:59 »
If you are giving these away for the cost of shipping I will take them...  :)
  • Trade Count: (0)
« Reply #3386 on: Thu, 26 June 2014, 22:24:43 »
Damn my slowness.  An awesome and generous freebie.
Offline Smasher816
  • HHKB Master
  • Trade Count: (0)
« Reply #3387 on: Thu, 26 June 2014, 22:35:25 »
I'm not sure what to do with the 87 brown switches I desoldered from my WASD. They were only used for a few months and should still be in a fairly good condition. If anyone wants them I suppose I could ship them :)
Offline intelli78
  • Trade Count: (0)
« Reply #3388 on: Thu, 26 June 2014, 22:38:17 »
Generous!
  • Trade Count: (0)
« Reply #3389 on: Thu, 26 June 2014, 22:38:48 »
I'd be interested in them.  If anyone wants the stems and springs, feel free to send those on.  I really just need the housings for the pink stems I got from China.
On an unrelated note, since I'm tired of all the "does anyone have x" posts and the relative dearth of giveaways, I'm giving away a Skully and Ba'man cap to two people of my choosing in any color(s) of their choice to two people who have given anything keyboard related away for free in the past 15 pages.  Just PM me if you'd like to be considered and include a link to your post.
« Last Edit: Thu, 26 June 2014, 22:41:47 by nubbinator »
Offline asdfjkl36
  • blue shirt guy
  • Trade Count: (1)
« Reply #3390 on: Thu, 26 June 2014, 22:41:11 »
Id probably be interested in the stems and springs. I only really have clicky switches and i'm starting love the browns on my girlfriend's ducky.
Offline Badwrench
  • Trade Count: (0)
  • ummmm.....I forgot
« Reply #3391 on: Thu, 26 June 2014, 22:57:13 »
Awesome of you.  I am not in as I have been the recipient of your generosity more than once.
Offline RimpactPC
  • Trade Count: (0)
« Reply #3392 on: Thu, 26 June 2014, 23:47:04 »
Anybody have any keycaps they wanna send my way? <3
Offline swill
  • Trade Count: (0)
  • builder & enabler
    • swillkb.com
« Reply #3393 on: Fri, 27 June 2014, 08:06:44 »
I could send you a set of QFR caps, but since I am in canada, the cheapest shipping is like $9. :(
Offline destiriser
  • Trade Count: (0)
« Reply #3394 on: Fri, 27 June 2014, 14:23:53 »
Mod Note: Please review the classified rules located here: http://geekhack.org/index.php?topic=56284.msg1270020#msg1270020
WTB and WTS items should only be posted in the classified section of the forum when you have met the requirements.
« Last Edit: Fri, 27 June 2014, 14:51:49 by ekw808 »
Offline billnye
  • ability man
  • Trade Count: (0)
« Reply #3395 on: Fri, 27 June 2014, 14:50:19 »
Does anyone by chance have an extra set of legs for a Filco case or not use the legs on their case? I got a board in the mail this week that didn't have them and it would be great if someone has an extra pair! :)
Offline BlueBär
  • Trade Count: (0)
« Reply #3396 on: Fri, 27 June 2014, 16:58:40 »
In case nobody has some: http://www.keyboardco.com/product/filco-legs-one-pair.asp ;)
Offline billnye
  • ability man
  • Trade Count: (0)
« Reply #3397 on: Fri, 27 June 2014, 17:01:50 »
Thanks, I knew those were there, but it's gonna be $20 shipped to me. :(
Offline BlueBär
  • Trade Count: (0)
« Reply #3398 on: Fri, 27 June 2014, 17:04:16 »
Ah right, yeah that's crap :-X
Offline RimpactPC
  • Trade Count: (0)
« Reply #3399 on: Sun, 29 June 2014, 20:33:01 »
Any novelty keycaps you don't want?
