Author Topic: Model M space saver club  (Read 695336 times)
Offline smknjoe
Re: Model M space saver club
« Reply #450 on: Sun, 24 April 2016, 21:53:51 »
There is a difference between these 2 piece caps and the 1 piece that I have never heard mentioned before. The 2 piece caps are actually slightly larger around the perimeter when compared to the 1 piece keycaps. I noticed this because the Y and U keys were touching. Then, I noticed that the gaps between all of the keycaps were narrower...interesting...
SSKs for everyone!
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #451 on: Sun, 24 April 2016, 22:32:13 »
Really?  That's odd.  Both of my SSK's are different.  My Lexmark SSK has Single and my IBM has 2 piece.
Neither one has that issue.
Offline smknjoe
« Reply #452 on: Sun, 24 April 2016, 22:57:33 »
It is weird. This is my 3rd SSK. All IBM. First 2 are from plant F4 and made in 1987 and have 1 piece. This newest one is F8 and made in early 1992. I'll have to get the calipers out to verify, but until then...
SSKs for everyone!
Offline smknjoe
« Reply #453 on: Sun, 24 April 2016, 22:59:48 »
Those both look like the 2 piece on my F8 board...the gaps and the lighter numpad legends.
« Last Edit: Sun, 24 April 2016, 23:01:47 by smknjoe »
SSKs for everyone!
Offline Snowdog993
« Reply #454 on: Sun, 24 April 2016, 23:09:58 »
Yeah, you're right.  I thought it was single on the Lexmark.  It's not.  However, my 1370477's are.
Offline smknjoe
« Reply #455 on: Sun, 24 April 2016, 23:14:10 »
Now those look more like the gaps on my one piece boards. It's subtle, but the gaps are wider on that pretty 1370477 compared to your sweet SSKs. :)
SSKs for everyone!
Offline smknjoe
« Reply #456 on: Sun, 24 April 2016, 23:16:14 »
...the vertical gaps. Not the horizontal gaps between the rows...
SSKs for everyone!
Offline smknjoe
« Reply #457 on: Wed, 27 April 2016, 21:06:21 »
Yep, they are about .5 mm wider than the one piece caps.
SSKs for everyone!
Offline smknjoe
« Reply #458 on: Sun, 08 May 2016, 17:54:45 »
I don't think I like these caps as well as I do the 1 piece.
I may put this up for sale...
SSKs for everyone!
Offline menuhin
« Reply #459 on: Sun, 15 May 2016, 14:30:03 »
I had this IBM SpaceSaver II and I hated it... it has some super heavy rubber domes.
Does it count?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline smknjoe
« Reply #460 on: Sun, 15 May 2016, 14:37:29 »
Technically, yes. Rubber domes can be heavier than lots of other mechs.
SSKs for everyone!
Offline Snowdog993
« Reply #461 on: Sun, 15 May 2016, 21:30:29 »
Does it count?
No, it is not a Model M keyboard at all.
Offline menuhin
« Reply #462 on: Sun, 15 May 2016, 21:53:09 »
Opss... I overlooked the "Model M" and just saw the "Space Saver".
Does it count?
IBM M13 black
HHKB Pro 2 HasuBT
Offline ThoughtArtist
« Reply #463 on: Sun, 29 May 2016, 00:25:57 »
Time 4 bed...
Offline need
« Reply #464 on: Mon, 30 May 2016, 09:46:37 »
Time 4 bed...
You can't trick me, it clearly is a full size board.
Offline Snowdog993
« Reply #465 on: Mon, 30 May 2016, 09:59:04 »
Offline need
« Reply #466 on: Mon, 30 May 2016, 10:32:43 »
Time 4 bed...
That's an SSK.
It's clearly a full sized one with SSK keycaps.
Otherwise prove me wrong.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #467 on: Mon, 30 May 2016, 10:40:28 »
There's enough evidence shown in the picture to prove it's an SSK.  Without a doubt.
Offline Snowdog993
« Reply #468 on: Mon, 30 May 2016, 12:58:46 »
No doubt!  It IS an SSK.  The top of the clamshell is a dead giveaway,
Offline need
« Reply #469 on: Mon, 30 May 2016, 13:54:09 »
Which bit exactly are you talking about?
« Reply #470 on: Mon, 30 May 2016, 14:09:22 »
Maybe you'll want to find a picture of an SSK and fullsize and compare them yourself.
Offline need
« Reply #471 on: Mon, 30 May 2016, 14:37:14 »
I see what you mean.
Offline TacticalCoder
« Reply #472 on: Thu, 02 June 2016, 20:47:52 »
Nice, at 9:03 he's showing a SSK (missing a few keycaps apparently but nothing hard to fix), saying it's convenient that the Z170-A and Z170-Deluxe mobo's still come with a PS/2 port for those still enjoying rocking on Model Ms!
(found this because I'm planning to build a Skylake / M.2 SSD PCI-e 3.0 4x / system soon and was googling / searching YouTube for some infos)
Is he someone from GH?
« Last Edit: Thu, 02 June 2016, 20:49:56 by TacticalCoder »
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #473 on: Tue, 21 June 2016, 05:02:37 »
Just in today! My industrial SSK P.1395682  ;D
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline Crossfire
« Reply #474 on: Tue, 21 June 2016, 13:11:43 »
 :eek:
Offline menuhin
« Reply #475 on: Sun, 26 June 2016, 17:08:29 »
Gorgeous!  :thumb:
How do the 'Yes' and 'No' keys work? And why the F1 and F2 are located in the arrow keys?
IBM M13 black
HHKB Pro 2 HasuBT
« Reply #476 on: Sun, 26 June 2016, 17:28:50 »
Gorgeous!  :thumb:
It's all the same under the covers.  The blue-capped I-SSK's you sometimes see come from (or were destined for) Mopar Diagnostic Systems using IBM hardware.  Those keys correspond to specific functions in the software, probably ones most often used.
« Reply #477 on: Mon, 11 July 2016, 13:39:22 »
Got my first SSK in the mail today! Very excited! Member of the club, finally.  :thumb:
I was browsing Pinterest the other day for keyboard ideas and came across this picture:
141995-0
My first thought was that they're custom caps from Unicomp. I emailed them asking about SSK caps and if they offered sub-legends with different colors. They emailed back saying they offer the sub-legends only in gray.
Anyone know what model these come from? I'm also thinking they may still be from Unicomp, but they don't offer that color anymore.
« Last Edit: Mon, 11 July 2016, 13:49:56 by romevi »
« Reply #478 on: Wed, 05 October 2016, 04:46:04 »
That's probably the cleanest one I've ever seen!
Phosphorglow?
Offline juahenza
« Reply #479 on: Wed, 05 October 2016, 04:47:42 »
Phosphorglow?
Eclipse
Sent from my LG-H961N using Tapatalk
Offline Laurel
« Reply #480 on: Wed, 05 October 2016, 12:36:38 »
Phosphorglow?
Eclipse
How much do they go for?
« Reply #481 on: Wed, 05 October 2016, 12:40:05 »
Phosphorglow?
Eclipse
$500-$1000.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #482 on: Wed, 05 October 2016, 14:40:50 »
more like 1300$ when he meant Ellipse instead of Eclipse
« Reply #483 on: Mon, 10 October 2016, 04:36:59 »
Offline kekstee
« Reply #484 on: Mon, 01 May 2017, 11:58:39 »
After all those years I finally got myself a SSK.
1392980 Terminal, Feb '90.
Using it with a regular fullsize M (1391403) controller board and cable currently.
167370-0 167372-1
Offline Snowdog993
« Reply #485 on: Mon, 01 May 2017, 21:16:34 »
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #486 on: Mon, 01 May 2017, 21:40:36 »
Nice and clean.  And the keycaps are pretty unique with front prints.   :thumb:
Offline mrduul
« Reply #487 on: Sun, 28 May 2017, 16:37:13 »
Industrial has same insides as any Model M SSK right?
But grats man wow  :cool:
Offline snoopy
  • The Flying Ace
« Reply #488 on: Mon, 29 May 2017, 07:58:45 »
yes
Offline Pete
« Reply #489 on: Wed, 02 August 2017, 22:32:49 »
Member of the Model M Space Saver Club checking in.  I actually have two: one in a box and one without the box (first drawer in the pic below):
Offline Snowdog993
« Reply #490 on: Fri, 04 August 2017, 20:07:31 »
I am more curious than ever. I would think the regular controller would still allow you to use the extended features of the SSK without any problems, would it?
I believe it's the same controller for the SSK if I am not mistaken.
But I could be.
« Reply #491 on: Sat, 05 August 2017, 07:38:24 »
But I could be.
Doesn't have the same firmware.   You cannot active the embedded numpad when using a fullsize controller.
Offline JP
« Reply #492 on: Tue, 08 August 2017, 11:24:06 »
I recently just joined the club. I posted this find recently on Deskthority.
3 NIB Lexmark branded Model M SSK's  ;D (2 of which are completely sealed from the factory)
A IBM SSK from 1990 that is kinda beat up.
175309-0
175311-1
175313-2
175315-3
175317-4
175319-5
« Last Edit: Tue, 08 August 2017, 11:25:43 by JP »
About Me | The Collection
Offline JP
« Reply #493 on: Wed, 09 August 2017, 15:30:57 »
I just bought one of these. Does this count as well?
175444-0
Offline hapakey
« Reply #494 on: Wed, 09 August 2017, 16:10:42 »
No
« Reply #495 on: Wed, 09 August 2017, 16:55:52 »
Technically it counts more than most of the keyboards posted as the thread is called the "Model M space saver club", while the SSK stands for "Space Saving Keyboard".
Yours is a "Space Saver II".  It's a decent keyboard for what it is,  I've thought of grabbing one as a travel board.
« Reply #496 on: Tue, 03 October 2017, 05:49:34 »
I can't be the only one that got this message:
A topic you are watching has been split into two or more topics by HoffmanMyster.
View what remains of this topic at: https://geekhack.org/index.php?topic=34712.new;topicseen#new
Why was this split?
That link goes to this thread, which I'm already watching.  Why does it not give us the link to the thread that was split off?
Offline efex
« Reply #497 on: Tue, 18 September 2018, 02:02:07 »
Hello :)
My SSK modified in ISO and "boltmod"
« Last Edit: Wed, 19 September 2018, 11:54:21 by efex »
Offline hayt
« Reply #498 on: Wed, 19 September 2018, 11:46:29 »
<3 my SSK
A little twist on the RGB theme with a Taylor Swift Red Wrapped ;) and a home-made case
RGB SSK
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #499 on: Sat, 27 October 2018, 22:45:57 »
Cleaned up my SSK today! Such a beautiful board, and really love the feels :thumb: :cool:
