Author Topic: Best way to shine keytops (removal of letters is ok)  (Read 16631 times)
Offline gvfarns
Re: Best way to shine keytops (removal of letters is ok)
« Reply #50 on: Wed, 05 September 2012, 21:41:49 »
Ahh, that makes sense.  Another trip to the store for me, I guess.
It actually feels awesome on my hands.  Since I don't actually look at my keyboard all that much I'm a little tempted to keep it as is.  Although I have cleaned it with a wet towel and a dry one, it feels silky smooth, almost like a hard surface with baby powder on it or something.  It's not bad at all.  Not the shiny surface I was looking for, but a good move.
Thanks for the advice.  I'll give it another shot with the 1000 and then the 2000.  I also have another keyboard of the same model that needs the same treatment so once I have everything worked out with this one, I'll be moving on and starting again.
Actually I'll probably try buffing with the felt dremel first.  I have a feeling it might be smooth enough that the dremel will work well.  I just have to be super careful not to let it overheat and melt the plastic like it did last time.
Offline gvfarns
« Reply #51 on: Fri, 07 September 2012, 18:39:55 »
Ok, I think I have the whole thing worked out, and I have now done it on two keyboards:
Start with a Coolermaster Storm Quickfire Rapid keyboard.
1. Grind off nubs on J and F keys with dremel and grinding tool
2. Wet sand logo on spacebar and windows keys with 400 grit sandpaper until completely gone
3. Wet sand each key individually to remove texture and enough of the letter paint that you can no longer feel it.
4. Wet sand everything with finer sandpaper.  I went straight to 2000, but something intermediate first would have been better
5. Use dremel tool with felt tip to polish each key to a shine.  It doesn't take long.
6. Remove plastic dust and felt residue from sides of the keys and rub everything with a soft cloth.
Voila!  Perfectly smooth and shiny keys with no bumps and no annoying logo on the spacebar or windows keys.  It was a lot of work but it was so worth it.
A couple of notes:
* I did one keyboard with dry sanding and the other wet.  Wet went faster, was cleaner, and didn't gunk up the sandpaper as much.  Definitely use water when sanding.
* On one keyboard I skipped the 2000 grit and went straight to the polishing with felt.  That keyboard is not as shiny as the other.  They are both shiny enough for my taste, though, and my fingers are very glad I didn't put them through another punishing round of sanding.
* When using the felt tool and the dremel, be sure not to leave it in one place too long or the plastic gets hot and melts.  Very bad.
* None of the chemicals I tried were effective at bringing out a shine or significantly smoothing the keys.  I think mechanical smoothing is better.
* I had a little bit of polishing compound on my felt tool left over, but I never applied more.  I don't think it made any difference (it's for polishing metal and is very fine).  I personally believe that plain felt would have worked as well but I'm not sure.
Thanks for all your help, guys!
« Last Edit: Fri, 07 September 2012, 18:50:25 by gvfarns »
« Reply #52 on: Fri, 07 September 2012, 21:55:33 »
That's a thorough guide! This will be helpful for people who have old keycaps that have fingernail "ripples" on them, as well as people like you who prefer shiny keycaps.
Do you mind if I appropriate this information into a wiki page? I'll cite you, of course.
Offline gvfarns
« Reply #53 on: Fri, 07 September 2012, 23:41:49 »
No prob.  You can add anything you want, with or without citing and with or without modification.
