Author Topic: LED's for Poker.  (Read 4133 times)
Offline Lethal Squirrel
  • I <3 60%
LED's for Poker.
« on: Tue, 21 August 2012, 20:52:27 »
I want to change the LEDs in my poker to red. I'm not sure the type of led's I need. Can anyone help me out? :3
Offline modulor
Re: LED's for Poker.
« Reply #1 on: Wed, 22 August 2012, 10:48:24 »
You will need 3mm leds.  I plan on attempting something similar (as well as adding leds in other places) but it seems all those I find have a little edge around the bottom that won't allow the led to sit in the switch without sanding it down.
I've been looking for some that don't have a bottom lip, as that would make installing them much simpler!
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
  • I <3 60%
« Reply #2 on: Wed, 22 August 2012, 10:53:15 »
Thanks much! : )
Offline modulor
« Reply #3 on: Wed, 22 August 2012, 11:01:34 »
Also a thought, my Leopold seems to have rectangular leds, so that may be an option. They seem to be lower profile, too.
Example: http://keyboardporn.com/images/leopold_preview/12_led_closeup.jpg
I'll do some more research to see what I can find  :)
Offline modulor
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Wed, 22 August 2012, 11:39:06 »
There are also 3mm flat top LEDs which have a wider angle diffusion and are shorter so you shouldn't have to trim the edges (I do anyway).
Filco w/ Imsto thick PBT
Offline modulor
« Reply #6 on: Thu, 23 August 2012, 08:55:00 »
Where do you usually get them?  I also found another supplier that has a variety of types: http://www.kingbrightusa.com/category.asp?catalog_name=LED&category_name=KCThrough-Hole+LED&Page=1
Offline bpiphany
« Reply #7 on: Sun, 02 September 2012, 06:32:00 »
I don't even know if the stock LEDs on the Poker are all blue?... Be aware that there are series resistors for the LEDs. Red LEDs usually have a smaller voltage drop than other LEDs, so there may be a small risk your new LEDs will emit blue smoke rather than what you want.. You may or may not need to change the resistors as well. It may be a good idea to at least figure out the value of the stock resistors and check that the voltage used for the LED driving is 5V and not something else.
