Author Topic: My keys are sticky  (Read 2051 times)
Offline ty_moon
My keys are sticky
« on: Thu, 23 August 2012, 09:11:23 »
About 5 drops of red wine landed on my keycaps and somehow got into the switch, resulting in a few keys being stiffer than others.
How can I fix this without de-soldering the keys? I was thinking of squirting some rubbing alcohol into the switch using a syringe with the stem pushed down and them letting it air dry. Would this help?
Thanks GH
Re: My keys are sticky
« Reply #1 on: Thu, 23 August 2012, 09:16:58 »
You didn't say what switch type you have, but I would beware of moving the problem deeper down into the system.
At this point, I would suggest wiping and drying as much as possible before doing any squirting.
- Oliver Willis 2026-08-01
Offline ty_moon
« Reply #2 on: Thu, 23 August 2012, 09:19:30 »
They're MX Reds. The difference between a stiff key and a unharmed key is very, very small, but I can notice it. This happened a few days ago.
Obviously I could just order some new switches and swap them out, but I'd rather not risk breaking the board as my soldering skills are sub-par.
« Last Edit: Thu, 23 August 2012, 09:28:28 by ty_moon »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #3 on: Thu, 23 August 2012, 09:39:19 »
Subpar skills are good enough for switches.
Squirting alcohol into it may work, but it may not and the risk of making a mess is very great.
Fight For Freedom. Stand with Hong Kongers
« Reply #4 on: Thu, 23 August 2012, 15:34:28 »
I managed to drip one or two small drips of coffee (black with 2 sugars) onto my MX blue keyboard.
I immediately removed all key caps in the affected area (; ' . / enter and r-shift) and wiped all visible liquid up.
A tiny amount seemed to have gone into the dummy switch on the right of the right shift key (on the Ducky Shine, the wider keys have the MX switch in the middle, and a kinda dummy switch on either side - just the dummy switch was affected).
As a result the right shift key sticks a bit from time to time.
Now, about a week later, I have been repeatedly pressing the r-shift and it has greatly loosened up.  Almost back to normal.
The total spillage was about enough to cover a little finger nail, and only a fraction of that went into the shift key.  Surprising how little liquid can affect a keyboard.
If your switches still work, then it might just be a matter of a little time, and repeatedly pressing the keys to get back to normal.
I seem to keep the dust cover on a bit more now.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #5 on: Thu, 23 August 2012, 15:37:14 »
It's another one of THESE threads xD
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
