Author Topic: Desoldering iron best investment so far  (Read 7489 times)
Offline tgujay
« on: Wed, 29 August 2012, 13:19:31 »
I'm currently in the process of renovating an old Chicony with mx blues and a desoldering iron made the process immensely less time consuming.  So far I have removed all the switches and am going to sand and repaint the plate.  Since the plate was rusty and some of the switches have rust/gunk on them, is there a preferred method of cleaning switches?
Gotta collect them all
Offline WhiteFireDragon
    • youtube
Re: Desoldering iron best investment so far
« Reply #1 on: Wed, 29 August 2012, 13:37:03 »
Which desoldering iron do you have?
Offline tgujay
« Reply #2 on: Wed, 29 August 2012, 13:41:19 »
Radioshack cheap thing with a bulb, works great.
Offline PointyFox
« Reply #3 on: Wed, 29 August 2012, 19:33:18 »
Is bulb better than the solder sucker?  Mine sucks, but not in a good way.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 29 August 2012, 19:44:01 »
I have one of those too, makes desoldering an entire board worth of switches sooooooooo easy. Definitely worth $11. Certainly cheaper that chewing through braid.
Offline tgujay
« Reply #5 on: Wed, 29 August 2012, 19:47:39 »
It works awesome, i set the iron down around the pin with solder let go of the bulb and it sucks it all up, spit it into a box and keep going. I spent a day and got half the keyboard desoldered with braid, finished the other half in 15 minutes with the desolder iron.
Offline tgujay
« Reply #6 on: Wed, 29 August 2012, 19:48:44 »
Yusssss
Offline PointyFox
« Reply #7 on: Wed, 29 August 2012, 19:52:13 »
Is this a solder sucker/bulb combo?
Offline tgujay
« Reply #8 on: Wed, 29 August 2012, 20:20:16 »
It looks like this, because it is this haha.
Offline PointyFox
« Reply #9 on: Wed, 29 August 2012, 20:26:19 »
Ah, I might have to get one of those.  Mine are separate and hard to use on small parts.
Offline tgujay
« Reply #10 on: Wed, 29 August 2012, 20:31:12 »
Yeah it's pretty awesome, and like lysol said they are like 11 bucks. Totally worth it.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #11 on: Wed, 29 August 2012, 23:58:08 »
Get a soldapult i think it call best thing next to a desoldering iron.
Offline PointyFox
« Reply #12 on: Thu, 30 August 2012, 04:34:17 »
Sounds like you should wear goggles with that one.  :eek:
Offline modulor
« Reply #13 on: Thu, 30 August 2012, 08:24:04 »
These work very well for how much they cost! :cool:
21XX (soon) | Leggera-G | ClassicGLO | Frog TKL 8K | GH60 rev.C + Leggera-T | 86U 45g  | G80-2100HDU | G80-1000HBU | G80-3700HAU | QFR V1  | FC200R | PokerX | G80-11900LUMEU
Offline tgujay
« Reply #14 on: Thu, 30 August 2012, 11:54:28 »
I would have to argue that the desoldering iron is infinitely easier to work with and is a single tool. If you are desoldering an entire board I wouldn't use any else.
Offline PointyFox
« Reply #15 on: Thu, 30 August 2012, 13:53:10 »
Especially when holding something like pliers in the other hand.
    • youtube
« Reply #16 on: Thu, 30 August 2012, 15:16:09 »
Since I already have a radioshack iron, is the bulb and tip just an add-on I can buy? Or do I need to buy the whole desoldering assembly including the iron?
Offline tgujay
« Reply #17 on: Thu, 30 August 2012, 15:18:14 »
It's a set not an add on.
Re: Re: Desoldering iron best investment so far
« Reply #18 on: Thu, 30 August 2012, 23:03:39 »
i would agree it better an faster but a good one also costs multiple times more.
Offline tgujay
« Reply #19 on: Fri, 31 August 2012, 09:42:27 »
What defines a good one?  Mine has removed switches from 2 whole boards and had no trouble.
Offline PointyFox
« Reply #20 on: Fri, 31 August 2012, 11:03:39 »
Maybe one with a vacuum pump?
« Reply #21 on: Fri, 31 August 2012, 22:23:54 »
yes that would be what im refering to.
