Author Topic: Does a stock Filco have a 7 unit space bar or 6.2?  (Read 4074 times)
Offline m00nshake
« on: Wed, 12 September 2012, 15:12:29 »
I'm about to order a space bar and need to know if the Filco uses a 7 unit or 6.2...
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Offline Wildcard
  • When caffeine isn't enough
Re: Does a stock Filco have a 7 unit space bar or 6.2?
« Reply #1 on: Wed, 12 September 2012, 15:19:57 »
6.25
Offline m00nshake
« Reply #2 on: Wed, 12 September 2012, 15:25:07 »
6.25
Ok thanks alot. Almost made a mistake... :\
Offline Wildcard
« Reply #3 on: Wed, 12 September 2012, 15:37:48 »
NP, usually the 7 unit space bars are seen on winkeyless boards.
Edit: Also, make sure the stem placement matches.
« Last Edit: Wed, 12 September 2012, 15:41:07 by RiffRaff »
Offline m00nshake
« Reply #4 on: Wed, 12 September 2012, 16:29:43 »
This was for overrun on the cream cheese and green group buy. I wanted to get a couple of extra space bars and a few other keys just in case they start showing wear. They've only got two kinds of space bars that came from the group buy, the 6.2 unit and 7 unit space bar. So hopefully the stem placement for the space bar is correct... I've already sent payment.
Offline Chicken Chaser
« Reply #5 on: Sun, 16 September 2012, 06:52:39 »
Is the 6.2 and 6.25 unit space bars the same or different? I notced on Keycaps Direct that they only show 6.2 and 7.0 unit space bars. I sent an email the other day but no response yet.
Leopold TKL Blues || Leopold TKL Reds || Filco TKL Ninja Browns
« Reply #6 on: Mon, 17 September 2012, 11:45:33 »
I am pretty sure "6.2 unit" spacebars are actually all 6.25 units. I'm sure you won't notice the extra 0.03 units difference. That's like 0.57 mm.
They probably just truncated the 5 off the end. keycapsdirect is SP (Signatureplastics) and their spacebars work.
