Author Topic: Post your G80-1800 pictures  (Read 720294 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Post your G80-1800 pictures
« Reply #850 on: Sat, 04 November 2017, 12:40:26 »
I've been trying to get this guy converted without any luck.  Planning on getting a Leeku PCB to get it up and running and use it as my new work daily.
Those vintage blues are clicky as hell.
You'll love it.
Offline dorf
  • divine creator
« Reply #851 on: Sat, 16 December 2017, 12:12:18 »
First test with PCB-mounted Silent Blacks.
Offline kiwi99
  • that's a gnarly dookie
« Reply #852 on: Sat, 16 December 2017, 14:03:32 »
are those regular carbon alphas?
Offline dorf
  • divine creator
« Reply #853 on: Sun, 17 December 2017, 00:56:35 »
Yes, they are.
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #854 on: Mon, 22 January 2018, 19:05:37 »
What is the best way to go about paint matching a colour to paint a standard beige g80-1800 case? Painting a cheapo 1800 case matched to the colour of the g80-1800 H2099 (the green sailors model) would be an interesting project, depending on whether I could get a sample or paint code for the H2099  :p
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline Giorgio
« Reply #855 on: Tue, 23 January 2018, 02:27:13 »
How does it feel? Wobbly? Silent? Mushy? Thanks
Offline dorf
  • divine creator
« Reply #856 on: Tue, 23 January 2018, 03:03:31 »
They definitely need to be lubricated and I have switched spring to 72g Sprit. Quieter than usual, yes. They hiss a little but nothing that bother me.
Offline Giorgio
« Reply #857 on: Tue, 23 January 2018, 03:38:17 »
Lubricated? So this means that not all silent switches are smooth...  :rolleyes:
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #858 on: Tue, 23 January 2018, 07:43:51 »
Even a smooth switch can benefit from lube.
Offline dorf
  • divine creator
« Reply #859 on: Wed, 14 February 2018, 12:45:21 »
Really like the old style sticker for NCS-indicators. Also, spring swap, lube your silent blacks and PCB-mount them! Awesome. My fav-keeb for now. Anyone willing to sell me their Goupil 1800 or even only the case, let me know.
Offline lucar
    • BIT SPLITS
« Reply #860 on: Sun, 11 March 2018, 05:24:09 »
Here is my Dolch PAC64  / Cherry G80-1813 Keyboard.
I got this Dolch Pac 64 from Ebay and it was missing a keycap, so I added a "bug" from the Signature Plastics DSA Alps/Matias "Granite" keyset giving a "theme" to the whole PC.
Being a "bug", the key is different from all the other keys, shape included.
Luca
« Reply #861 on: Sun, 11 March 2018, 06:00:23 »
Luca
This is great. Did you fit some sort of computer into the monitor??
Offline lucar
    • BIT SPLITS
« Reply #862 on: Sun, 11 March 2018, 07:20:22 »
Luca
I upgraded the Dolch Pac 64 to Intel Core i7-3770T plus  Nvidia GTX 1060 and  replaced the LCD display.
The specs are:
LCD: 12.1" ChiMei G121X1-L04 LCD Screen Display
CPU: Intel Core i7-3770T 3.70 Ghz Quad-Core Processor
COOLER: AKASA AK-CC7124EP01 Low Profile
RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3
MOTHERBOARD: Axiomtech SHB120 PICMG 1.3 Full-size CPU Card
STORAGE: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive 1.44 Mb Floppy Disk Drive LG GTC0N R/W CD/DVD drive
VIDEO CARD: AsusTURBO GTX 1060 6GB POWER SUPPLY: Silverstone SFX ST45Sf-G 80 Plus GOLD 450W
The upgrade is not that easy nor cheap,  here is my  build log https://www.youtube.com/watch?v=6BgUoO9gYjU
I did not modify the keyboard that is perfectly PS/2 compatible.
The machine is a pleasure to use  :D
Luca
« Reply #863 on: Mon, 12 March 2018, 19:14:21 »
Luca
Okay, this is AWESOME.  Really nice work on that build, I think this is the first time I've seen someone smash a modern computer into a Dolch PAC.  :thumb:  Do you foresee yourself using the computer in a semi-mobile fashion?  Would make a really great LAN party machine.  :D
Offline dblack
  • Formerly ZuXzu
« Reply #864 on: Mon, 12 March 2018, 20:09:31 »
Luca
The specs are:
Luca
very cool, im sure that took some time.
Offline lucar
    • BIT SPLITS
« Reply #865 on: Tue, 13 March 2018, 04:50:37 »
@ HoffmanMyster and ZuXzu
Yes, being able to change video cards or processors at will makes this build very versatile. This is perfect for Lan Parties, as well as hooking it up to Your HD tv for gaming or a VR google set. Its' compact and you can still enjoy the feel of a mechanical keyboard in a vintage machine that You can use every day.
Using a stripped off Dolch keyboard is not the same experience as using it on the original chassis!
It took 6 months more or less with most of the time spent studing pictures and diagrams of the new parts against the chassis non standard dimensions.
Every new part I tried to fit, I had new mechanical interference problems to solve and, using mostly special parts, I also had to wait for them to go back an forth from China, US, Germany and so forth.
Some parts had to be  hand made such as the lcd fixing brackets for example, but there is nothing that and average skilled builder can't make in this build.
It's just a matter of having a lot of patience.
Luca
« Reply #866 on: Tue, 13 March 2018, 05:08:44 »
Luca
The specs are:
Luca
That is a lot of work and such a unique piece. Splendid job!
Offline 2ter
« Reply #867 on: Sat, 21 April 2018, 15:05:00 »
194328-0
Offline ideus
  • Björkö.
« Reply #868 on: Sat, 21 April 2018, 15:26:13 »
Luca
The bug ruins the keyboard's look. I am afraid, so. But if you like the theme, well, let's be it.
Offline Nafs_asp
« Reply #869 on: Tue, 29 May 2018, 17:55:19 »
Posted in the mail day thread too, but figured I'd share here. Found a NIB G80-1838HPU the other day. It was made in 1996 and has vintage MX browns and is one of the few boards to come with black on white double shots:
196644-0
196646-1
196648-2
Offline kiwi99
« Reply #870 on: Wed, 30 May 2018, 16:33:24 »
Looks great, is it a very bright white? or a bit of cream to it?
Offline Nafs_asp
« Reply #871 on: Wed, 30 May 2018, 16:55:10 »
They are very close to the alpha color for Cherry beige double shots. Here is a picture comparing the two:
196714-0
Here is the caps next to Cherry hellgrau color:
196716-1
« Reply #872 on: Wed, 30 May 2018, 20:24:27 »
The creamy alpha colour but all-over? Love it :fire:
Offline duynguyenle
  • Personal text? What personal text???
« Reply #873 on: Thu, 31 May 2018, 16:01:01 »
I believe the Compaq off-white doubleshot base is the exact same colour code used for the GMK Barebones Stormtrooper kit
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline mrkevint
  • OK.
« Reply #874 on: Fri, 01 June 2018, 17:01:53 »
I also have a G80-1838HPU. To me, the key caps resemble GMK Pristine (L9) more than GMK Stormtrooper (CP). The alphas are a creamy white rather than off-white.
I agree with the sentiment that they are close to the alpha color of OG Cherry beige.
« Last Edit: Fri, 01 June 2018, 17:03:59 by mrkevint »
Offline simpleface
« Reply #875 on: Sat, 16 June 2018, 04:01:11 »
is there g80-1800 and g80-3000 have same capslock ?! thanks
Offline Malenky
« Reply #876 on: Sat, 16 June 2018, 09:42:44 »
All G80 keyboards use stepped caps lock as far as I'm aware.
Offline ramnes
  • T fou, mec?
« Reply #877 on: Sat, 23 June 2018, 17:12:26 »
awesome find nafs_asp!
Offline Nafs_asp
« Reply #878 on: Sat, 23 June 2018, 18:27:19 »
Thanks man, one of my best finds so far (:
Offline armin
« Reply #879 on: Sat, 14 July 2018, 11:16:32 »
Just my humble addition.
Offline cinnamoncider
  • Thorpies are snappy
  • No clack; no life.
« Reply #880 on: Sat, 10 November 2018, 02:40:16 »
Cherry G80-1800, MX Brown, GMK Solarized Dark
Offline flying1911
    • Mechlovin' Studio
« Reply #881 on: Sat, 01 December 2018, 19:36:14 »
G80-1800 and Cherry OG Dolch caps. The caps lock switch is in the wrong position, should be a quick fix.
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline ramnes
  • T fou, mec?
« Reply #882 on: Sat, 08 December 2018, 11:44:51 »
Excellent!
Offline pixelpusher
« Reply #883 on: Sat, 08 December 2018, 13:22:06 »
And sorry to be that person, but is cerakote an option with plastics ;)
Sent from my iPad using Tapatalk
You can't cerekote plastics unless it can withstand 300c temps for multiple hours and even then you might have a tough time
Actually it's 300F, not 300C, but that's for quick cure.  You do 250F for 2 hrs.  If the case is ABS, it'll be a pile of goop, but PBT would take it like champ.  There are some photos and blog posts out there of people cerakoting a model M case.  Looks sweet.
Offline kybernator
« Reply #884 on: Thu, 07 February 2019, 16:19:37 »
My humble addition, with dyed keycaps from a Cherry hellgrau set
212401-0
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #885 on: Sat, 09 February 2019, 23:44:30 »
Love your keyboard. Classical board!
Offline Nigolski
« Reply #886 on: Mon, 11 February 2019, 07:11:48 »
my g80-1800 with assorted sa keycaps and retooled mx blacks
Offline kybernator
« Reply #887 on: Fri, 15 February 2019, 14:30:00 »
more now:
213013-0
Offline megasthenes
« Reply #888 on: Sun, 06 October 2019, 16:52:39 »
227722-0
resurrecting this thread for good
Offline Link01
« Reply #889 on: Sun, 09 February 2020, 19:34:06 »
I stumbled across this stack of Cherry G80 1800LPCEU-2 at work.
Offline pixelpusher
« Reply #890 on: Mon, 10 February 2020, 00:29:18 »
Did you tell them they're no good and you need them for a recycling project?  I'll take one, please  :p
Offline Obamas Mama
« Reply #891 on: Tue, 11 February 2020, 10:17:42 »
It's one month older than me. Vintage browns. Cleanest board I've ever touched.
Edit: I took out the brown stems and tops because I like linear ;)
« Last Edit: Tue, 11 February 2020, 10:19:30 by Obamas Mama »
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #892 on: Tue, 11 February 2020, 11:09:07 »
Boy oh boy. Apparently i missed this thread before. Time to correct that.
Offline Link01
« Reply #893 on: Tue, 11 February 2020, 13:24:14 »
I am offering new slick and shiny dell keyboards in exchange for these bulky old fashioned ones :)
@T0mb3ry
How did you add the back light to the second keyboard posted there ?  Or did the keyboard come with it ?
I am also interested in 1x1 size windows key replacement. I am a FreeBSD user and would like to get that logo on my newly found Cherry G80-1800.
Offline T0mb3ry
    • Flickr
« Reply #894 on: Wed, 12 February 2020, 11:31:48 »
@T0mb3ry
Back light? None of these keyboards has back light. The plate on the second board is red and its pretty visible. Maybe you mixed it with back light.
Offline Link01
« Reply #895 on: Wed, 12 February 2020, 22:51:45 »
Yes, I did confuse the red plate as a back light. It looks pretty real to me. Since I do a bit of typing at night, I would appreciate a bit of back light for the keyboard, even though it does not shine through the key caps.
Offline Mikhail
« Reply #896 on: Thu, 04 June 2020, 16:36:43 »
I dreamed about 1800 since I found HASRO and googled more about Cherry keyboards and their keycaps. And found - two months later. Data code is 1995. Black with a large logo, very similar to vintage. Smooth. The cap is almost mint! I'm afraid to use it and wipe it to shine. And a little sad - the seller said that there were several more, but they were sent to the scrap.
Offline ramnes
  • T fou, mec?
« Reply #897 on: Thu, 04 June 2020, 17:22:50 »
Ohhh, a H2099! I love mine. This is one very rare 1800 that you have here, take a great care of it!
Offline Mikhail
« Reply #898 on: Thu, 04 June 2020, 18:20:39 »
How rare do you think the H2099 in black colour?
the seller asks from 50 dollars
Offline pixelpusher
« Reply #899 on: Thu, 04 June 2020, 23:53:52 »
What a beauty!  Seriously though, can we start a go-fund-me to raise money for a PSA begging people to not throw away vintage boards?  Think how many are trashed daily.  :(
« Last Edit: Fri, 05 June 2020, 00:24:25 by pixelpusher »
