Author Topic: Leading Edge DC-2014 No Response?  (Read 1569 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« on: Mon, 17 September 2012, 17:29:18 »
I've got this DC-2014 and as it's an AT KB I have an adapter from AT to PS/2 so I can use it on my PC for obv reasons, and for some reason it doesn't output any signal. Any ideas?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Leading Edge DC-2014 No Response?
« Reply #1 on: Mon, 17 September 2012, 17:59:03 »
Bore Awards
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Mon, 17 September 2012, 23:15:24 »
So would I need a Teensy to get this to work or what?
TOO BAD FOR YOU
« Reply #3 on: Tue, 18 September 2012, 03:46:34 »
Yes, I suspect using Soarer's XT to USB code will work, though I haven't tried it yet myself, and I believe most of the people who have used it with an IBM XT keyboard.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #4 on: Tue, 18 September 2012, 19:21:19 »
Looks like I'm buying a Teensy when I get paid. I've been dying to try out Alps in a legitimate typing scenario.
TOO BAD FOR YOU
