Author Topic: Knuckle Cracking  (Read 45161 times)
Offline Viz
Re: Knuckle Cracking
« Reply #50 on: Mon, 05 November 2012, 12:57:49 »
Another joint cracker reporting in! :p
Offline Lanx
« Reply #51 on: Mon, 05 November 2012, 19:28:28 »
jackie chan never mentions anything about chi or acupuncture or "cupping", when he had to recover from probably breaking the same bone 4x, and he's in Guiness for most stunts performed. He must have hours of some kind of pain from somewhere in his body, i'm sure of it, but he's never said anything about "eastern medicine"(at least he didn't 15 years ago when i read his biography).
Offline Glenn315
  • Hey
« Reply #52 on: Sun, 11 November 2012, 08:34:01 »
I used to crack my knuckles until I heard that it was bad.
Offline davkol
  •  Post Editing Timeout
« Reply #53 on: Sun, 11 November 2012, 09:07:10 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 15:29:28 by davkol »
Offline Zustiur
« Reply #54 on: Mon, 12 November 2012, 07:46:25 »
Somedays I 'do the right thing' and just stretch, but most days I end up cracking my knuckles. I get similar results either way, unless a joint is giving me particular discomfort.
I'm also a regular chiropractor patient, and have heard the same non-commital 'the cracking isn't the problem, weakening tendons/fingers is the problem' talk. Essentially I think the long term effects are unknown. To test it properly you'd need a lot of people to crack only one hand and not the other for years on end. And even then the evidence would be flawed because people use their left and right hands for different purposes.
Offline NKRO
« Reply #55 on: Fri, 16 November 2012, 11:00:51 »
Isn't there someone that has been doing this for 30+ years? (and reports no difference)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #56 on: Fri, 16 November 2012, 11:03:47 »
I'll let you know in 10...
Filco w/ Imsto thick PBT
« Reply #57 on: Fri, 16 November 2012, 20:41:58 »
I lost track.
Offline gizmo
« Reply #58 on: Fri, 16 November 2012, 21:23:22 »
You can subscribe to a theory all you want, but it does not make it true.  Harmful.  Not good.  I still do it anyways out of nervous habit.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #59 on: Sat, 17 November 2012, 04:03:26 »
Asked a doctor. It has no longterm effects.
SmallFry! <3
« Reply #60 on: Sat, 17 November 2012, 09:04:48 »
The effect is the addiction to doing it.
Offline Lanx
« Reply #61 on: Sat, 17 November 2012, 12:05:06 »
doctor or chiropractor did this guy have MD after his name or a quack chiro? heh.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #62 on: Sat, 17 November 2012, 12:28:42 »
My general MD Doctor. He laughed and said to not worry about it.
SmallFry! <3
Offline Cafiend
« Reply #63 on: Sat, 17 November 2012, 13:26:03 »
Hmmm good subject!
I cut fiberglass with heavy scissors all day. Then come home to a keyboard.
I have more pain at work then when i'm on a kb but I do crack my knuckles atleast twice a day. Mostly w/o realizing that i'm doing it.
The only pain that I get is in my elbow...I guess all of the tendons and nerves have a way of meshing together to target pain in an direct spot.
I don't think I could live without hearing that cracking noise coming out of my back neck or fingers.
Offline phx
« Reply #64 on: Sun, 18 November 2012, 01:53:27 »
sometimes you get this feel that you need to crack one but can't really go through with it, you put more strength into then you finally crack it and end up hurting yourself.
I crack my toes too  :eek:
Offline TheQsanity
  • SmallFry Lovin'
« Reply #65 on: Sun, 18 November 2012, 03:03:10 »
neck, back, toes, fingers, wrists, elbows, knees, ankles,  shoulders, sometimes hips.
SmallFry! <3
