Author Topic: Post your Korean Keyboard ^_^  (Read 13950567 times)
0 Members and 10 Guests are viewing this topic.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Re: Post your Korean Keyboard ^_^
« Reply #200 on: Thu, 25 October 2012, 22:13:29 »
Dat price cheaper than kmac2....
Offline MMB
« Reply #201 on: Thu, 25 October 2012, 22:15:23 »
kmac 2 is the meh.
Offline SmallFry
« Reply #202 on: Thu, 25 October 2012, 22:31:51 »
When did you change your username MagicMeatball? :( I like the old one better. :(
Offline emptythecache
  • out.
« Reply #203 on: Fri, 26 October 2012, 07:30:54 »
What is the deal with the KMAC 2? Based on the half the pictures that have loaded, its just a black case, red plate, and those gold colored blocker things. Doesn't seem super exciting to me. Although the pcb looks to be 1.5/1/1.5/7/1.5/1/1.5 on the bottom row, which I like. Curious If I could use that pcb in my KMAC case.
Offline MMB
« Reply #204 on: Fri, 26 October 2012, 10:39:12 »
KMAC > KMAC 2
Offline ekw808
  • Ekw
« Reply #205 on: Fri, 26 October 2012, 10:41:55 »
So much hate on the kmac 2, it is also hard annodized so the case won't have wear and tear problems hopefully.
[One Keyboard at a time]
Offline MMB
« Reply #206 on: Fri, 26 October 2012, 10:42:49 »
It's just my personal opinion. Some people might like the new design. I personally don't like the adjustable blocks for changing the modifiers. Looks odd.
Offline ekw808
  • Ekw
« Reply #207 on: Fri, 26 October 2012, 10:44:29 »
I like the 1.5,1,1.5 setup alot, I can't stand these moogle kits, and the original kmac didn't offer that option unless I bought both keyboards and swapped the cases.
Offline MMB
« Reply #208 on: Fri, 26 October 2012, 10:49:20 »
That's true. I would only use the 1.5, 1, 1.5 setup to avoid having to use the blocks. Design-wise, the case looks more solid than the original. It was only those blocks that turned me off.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #209 on: Fri, 26 October 2012, 10:53:55 »
Maybe you can have it welded and reanodize it?
-Enzo Ferrari
Offline jcrouse
Re: Re: Post your Korean Keyboard ^_^
« Reply #210 on: Fri, 26 October 2012, 10:55:10 »
Agreed, odd is an understatement mmb. 86 or 87 key will be the most visually appealing. 84 would look "odd".
Offline MMB
« Reply #211 on: Fri, 26 October 2012, 10:55:35 »
Then it would be the KMAC 1 :P
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #212 on: Fri, 26 October 2012, 10:57:13 »
Why do adjustable blocks turn you off, though? Because it isn't as much of a streamlined look? The color? Are they only offered in gold? What material?
I'd imagine you could personalize/customize the blocks (as you would keycaps) in order to make it nice. Perhaps name engraving or some other kind of finish on each one?
Offline MMB
« Reply #213 on: Fri, 26 October 2012, 10:59:26 »
I am more of a minimalist. The blocks seem to break up the streamlined look of the original KMAC. It doesn't sit flush, at least from all of the photos I have seen.
And that brings out the OCD in me.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #214 on: Fri, 26 October 2012, 11:02:39 »
I am all too understanding of OCD. Was just wondering. :D
I bet that thing as it sits will look good with lee's orange dolch set.
Offline MMB
« Reply #215 on: Fri, 26 October 2012, 11:04:52 »
lee seems to already have an amazing case to match his orange dolch set :P
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #216 on: Fri, 26 October 2012, 11:06:50 »
Oh, damn. He needs to put that thing together, get his dolch on it, and post a pic in this thread.
Offline ekw808
  • Ekw
« Reply #217 on: Fri, 26 October 2012, 11:38:20 »
I might want to have mine reannodized to a different color, but it doesnt matter if i use 1.5,1,1.5 setup. It could look good if they were blue or red on a retro or RA set with matching a matching CC.
« Last Edit: Fri, 26 October 2012, 11:39:57 by ekw808 »
Offline m00nshake
« Reply #218 on: Fri, 26 October 2012, 11:44:24 »
Did the Kmac 1 have these wear and tear issues?
Also, what separates the Kmac Le from the Kmac 1? Is it just the two colors on the Le?
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Offline leesofi
  • super lurking
« Reply #219 on: Fri, 26 October 2012, 11:45:01 »
i want to put my orange dolch on case, but i have not mx-clear switch for them now. LOL.
Offline ekw808
  • Ekw
« Reply #220 on: Fri, 26 October 2012, 11:53:08 »
Some people have experienced the annodizing on the kmac wearing off especially where the board gets touched alot...no homo.
Offline MMB
« Reply #221 on: Fri, 26 October 2012, 11:54:06 »
I touch my case a lot...
Offline m00nshake
« Reply #222 on: Fri, 26 October 2012, 11:56:08 »
ha!
  • out.
« Reply #223 on: Fri, 26 October 2012, 12:42:43 »
i didnt realize the wear and tear complaints about the kmac. maybe i'll get mine re-done when i have money to throw away again.
Offline Tenkey
« Reply #224 on: Fri, 26 October 2012, 16:44:15 »
why is there a winkey and winkeyless version if they have this block thats adjustable :confused:
Offline SmallFry
« Reply #225 on: Fri, 26 October 2012, 16:59:55 »
The plate is different for the two.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #226 on: Fri, 26 October 2012, 22:23:26 »
I'd touch my case a lot, too if it cost that much.  I expect to have SSK babies in 9 months...
Offline LifeZ
  • LifeZone
« Reply #227 on: Sat, 27 October 2012, 10:36:56 »
Hi. I'm LZ
LZ SE #1  ;D
Metalgray Color
With Daysub, MBC RGB, Darth Vader
« Last Edit: Sat, 27 October 2012, 10:48:21 by LifeZ »
LZ Limited
Offline ekw808
  • Ekw
« Reply #228 on: Sat, 27 October 2012, 11:00:04 »
Very nice SE
Offline jcrouse
« Reply #229 on: Sat, 27 October 2012, 11:08:36 »
Contracts on being number 1.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #230 on: Sat, 27 October 2012, 12:57:30 »
He created it. He should keep #1. :P
That thing is sparkly!
Offline jil_jil32
  • Tokyo Press <3
« Reply #231 on: Sat, 27 October 2012, 13:03:54 »
Like a TANK! 0.0 Btw, I like the Silver version most! <3
« Reply #232 on: Sat, 27 October 2012, 13:22:07 »
Wow.
Offline phetto
  • HHKB JP
« Reply #233 on: Sat, 27 October 2012, 14:34:45 »
give lz plz
Offline Kellybear
  • (づ。◕‿‿◕。)づ
« Reply #234 on: Sun, 28 October 2012, 14:13:43 »
SORRY FOR POTATO PICS.
KMAC that I received recently. Also the Poker alum case I purchased from Sherry.
My kitty was curious. :]
Yes, I realize that photos of this board were already posted in here, but who cares. LOOK AT MY KITTY ISN'T SHE CUTE.
« Last Edit: Sun, 28 October 2012, 14:16:15 by Kellybear »
Offline ekw808
  • Ekw
« Reply #235 on: Sun, 28 October 2012, 14:41:07 »
Thats a nice looking Kmac, congrats. Now to be an official member, you must indicate on your sig that you have a Korean keyboard, to invoke jealousy.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #236 on: Sun, 28 October 2012, 15:16:46 »
On mans, I kinda want that poker case
« Reply #237 on: Sun, 28 October 2012, 15:44:06 »
that kmac looks familiar
Offline MMB
« Reply #238 on: Sun, 28 October 2012, 16:16:08 »
It belonged to George Bush.
« Reply #239 on: Sun, 28 October 2012, 16:18:39 »
Offline MMB
« Reply #240 on: Sun, 28 October 2012, 16:23:47 »
Dubbya!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #241 on: Thu, 01 November 2012, 21:44:24 »
absyrd will like these pics ^_^
-Enzo Ferrari
Offline Rinsaku
  • lorem ipsum
« Reply #242 on: Thu, 01 November 2012, 22:01:46 »
That silver case is so sparkly!!! I want Shineys!
Current Boards : Apple m0116 (Salmon Alps), B.Face (Mx Clears), Filco Tkl (Mx Blues), HHKB Pro JP (Topre), Jd45 (78g Zealios), KBParadise v60 (Gateron Yellows), KBParadise v60 (Matias Quiet Click), Kbt Pure (Kailh Bronze), Leopold FC660M (Mx Browns), Minidox (Mod-H), Pok3r (62g Zealios)
« Reply #243 on: Thu, 01 November 2012, 22:30:44 »
Shiny indeed.  Would look better with a Patriots jersey but whatevs :p
Offline TheProfosist
  • Custom Layouts Only!
« Reply #244 on: Thu, 01 November 2012, 23:23:07 »
Here is mine so far (just got it today)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #245 on: Thu, 01 November 2012, 23:31:14 »
Nice get TheProfosist! I got the same one in the mail ;D Need someone to help build it though
« Reply #246 on: Thu, 01 November 2012, 23:32:51 »
lol should have said something sooner im building one for m00shke I can do yours as well if you want.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #247 on: Thu, 01 November 2012, 23:42:12 »
That would be awesome actually o.o
PM sent  :cool:
« Reply #248 on: Thu, 01 November 2012, 23:49:59 »
PM sent  :cool:
sounds good
pm received
Offline reaper
« Reply #249 on: Fri, 02 November 2012, 00:14:57 »
« Last Edit: Fri, 02 November 2012, 00:52:01 by reaper »
Din Eli
