Author Topic: Post your Korean Keyboard ^_^  (Read 13950452 times)
Offline tbc
Re: Post your Korean Keyboard ^_^
« Reply #2000 on: Sun, 22 December 2013, 04:15:06 »
the trik has an accessory USB port?
is that like the only kustom with a usb port?
Offline korrelate
  • iubeo stultum esse libenter
« Reply #2001 on: Sun, 22 December 2013, 12:12:35 »
Happily enough: it actually has two accessory usb ports. No good for charging, I believe but suitable for thumb drives and mice, etc.
Also, I didn't buy it for the ports but yes: I'm pretty certain that it's one of very few, if not the only import to have them.
Topre REALFORCE
Offline aj-kun
« Reply #2002 on: Mon, 23 December 2013, 17:16:08 »
Uptop, KMAC 2 + Ragnarok with mx blacks that are silky smooth, the seller told me that the board had clears but instead it arrived with these. Flash kinda ruined it but the wasd is pink, F1-F4 & F9-F12 is Breen and F5-F8 is Blue
Down below Acrylic Gon with WOB Cherry + WOP mods and Yellow SP space bar - going for that Lakers theme~ KOBE ;_;
Offline Jokrik
« Reply #2003 on: Mon, 23 December 2013, 17:45:36 »
Nice boards you've there,
Just curious why the seller cant differentiate the color black with clear  :))
Offline aj-kun
« Reply #2004 on: Mon, 23 December 2013, 17:47:45 »
Probably just a board he was trying to get rid of. it was dented. But from my typing angle I cant see anything wrong here, also, 62g blacks are the best switches I've had, soooooo Smooth.
Learned how to map the KMAC, added FN+Backspace as Delete :)
Offline Photoelectric
« Reply #2005 on: Mon, 23 December 2013, 17:58:23 »
62g lubed vintage Blacks are indeed amazing.  Welcome to the fan club :D
« Reply #2006 on: Mon, 23 December 2013, 18:22:40 »
Oh man.. One day I will own a KMAC :D nice cases
Offline Jokrik
« Reply #2007 on: Mon, 23 December 2013, 18:37:48 »
can you convert from topre to MX?
I rarely seen people convert to MX, its usually the other way around
« Reply #2008 on: Mon, 23 December 2013, 19:35:49 »
I will always own and favor Topre but I will continue to collect and enjoy different keyboards.
Offline Nojo
« Reply #2009 on: Tue, 24 December 2013, 02:17:41 »
Wow, the KMAC look amazing. Love the black and red combo  :thumb:
Offline aj-kun
« Reply #2010 on: Tue, 24 December 2013, 06:31:28 »
the flash makes the plate stand out, actually has some nicely coloured LED's.
Offline Nojo
« Reply #2011 on: Tue, 24 December 2013, 06:44:04 »
What color are the LEDs? The GON one is pretty cool, how much did you get it for?
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #2012 on: Tue, 24 December 2013, 06:59:26 »
When you've owned some Koreans with perfectly tuned and lubed Clears, Vintage Browns and Blacks then you will know true enlightenment  ;) .
All my Realforces are sitting in boxes in my basement, maybe when I'm bored I may use them again but I don't see that happening anytime soon.
Offline aj-kun
« Reply #2013 on: Tue, 24 December 2013, 09:17:20 »
OJ on ESC Green on F1-F4 & F9-F12, Blue on F%-F8, PINK WASD.
The Gon was around 250 ish.
Offline zenuty
« Reply #2014 on: Fri, 27 December 2013, 04:50:48 »
TwoSome Viky Style keyboard
Im post up my best keyboard in here.
I love Viky style keyboard.
TwoSome is Very Nice Viky Keybord :-*
Because its a made by CNC tech work.
Especially used full acrylic housing and used a special led bar on the bottom side.
Full Acrylic making is very hard work, So TwoSome is more special keyboard.  :thumb:
Yesterday, TwoSome Mini Group Buy Started in korea.
Total G.B Quantity is only limited 12set  :rolleyes:
You can see various pictures a following below link.
http://www.kbdmania.net/xe/market_info/7914169
http://www.kbdmania.net/xe/market_info/7911475
http://jbmod.tistory.com/8
49139-0
49141-1
49143-2
49145-3
49147-4
49149-5
49151-6
49153-7
49155-8
* PS : If you wants more pictures click here
http://geekhack.org/index.php?topic=41402.0
http://www.kbdmania.net/xe/photo/7265112
« Last Edit: Fri, 27 December 2013, 04:57:26 by zenuty »
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline Jokrik
« Reply #2015 on: Fri, 27 December 2013, 05:55:42 »
Dear lord...
how can a keyboard like that exist? its such a masterpiece
what a clack collection you have there Zen, what a very expensive unicorn vomit style display :) in a very good way
« Reply #2016 on: Fri, 27 December 2013, 10:19:19 »
Awesome collection!! Love the pink too!! :)
« Reply #2017 on: Fri, 27 December 2013, 10:23:34 »
WOW
Zenuty, I love when you upload pictures. They're always so incredible, and such rare stuff too.
Offline ideus
  • Björkö.
« Reply #2018 on: Fri, 27 December 2013, 10:46:02 »
TrikX with Dolch and WoRGB (currently experimenting with Panda clears and not so happy about them so far). Still needs a good lube job too:
Just finished this puppy:
Here's part of the reason it took me so long:
What type of panda clears combo or setup you have in the board?
« Reply #2019 on: Fri, 27 December 2013, 11:50:37 »
Haven't seen this posted before! Came across it in a few very old OTD articles. The 356W
Also, the 356C (NOT 356CL) This came before the 356CL from what I can tell, is even rarer, and is the first winkeyless aluminium custom (citation needed)
http://www.otd.kr/bbs/board.php?bo_table=album&wr_id=3932&page=629
http://www.otd.kr/bbs/board.php?bo_table=album&wr_id=3562&page=632
« Last Edit: Fri, 27 December 2013, 11:55:13 by Photekq »
« Reply #2020 on: Fri, 27 December 2013, 12:58:51 »
The wooden case is dreamy <3
The Viky keyboard looks very much like a GON NS 87.  Same type of matte rounded acrylic and internal backlight, as well as switches plate being the top of the case.
Offline jonathanyu
« Reply #2021 on: Fri, 27 December 2013, 20:51:36 »
Zenuty always got all the good stuff  :eek: Are you going to fill the number row with CC too?
Offline Nojo
« Reply #2022 on: Sat, 28 December 2013, 13:35:54 »
I see  ;D
By the way, check your PM
Offline moogle
« Reply #2023 on: Thu, 02 January 2014, 16:21:40 »
« Last Edit: Thu, 02 January 2014, 16:40:26 by moogle »
« Reply #2024 on: Thu, 02 January 2014, 18:47:11 »
^ ****ing sexy
Offline bigx333
« Reply #2025 on: Tue, 07 January 2014, 14:57:06 »
2TU | LZ-GH
« Reply #2026 on: Tue, 07 January 2014, 14:58:02 »
Very nice! Especially the mini :)  :thumb:
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2027 on: Tue, 07 January 2014, 15:06:30 »
That 60% look siiiiiiiiick! I'm so jelaous.
Offline bigx333
« Reply #2028 on: Tue, 07 January 2014, 15:11:18 »
Unfortunately the LZ-GH didn't came with the leds I wanted  :'(, I asked for a color schema and instead got a surprise in mail with a full orange lol, I will fix it when I have some time  :p.
2TU | LZ-GH
« Reply #2029 on: Tue, 07 January 2014, 15:15:16 »
That TKL looks like pure evil, I like it.
Offline evolveS
  • ಠ_ಠ
« Reply #2030 on: Tue, 07 January 2014, 21:48:49 »
"money comes and goes, but doubleshots are forever"
-a petty thief
« Reply #2031 on: Tue, 07 January 2014, 22:55:39 »
« Reply #2032 on: Tue, 07 January 2014, 22:57:11 »
according to his sig, looks like a 2TU.
« Reply #2033 on: Tue, 07 January 2014, 23:01:39 »
Good call, Detective Demik.
« Reply #2034 on: Tue, 07 January 2014, 23:02:11 »
**** Demik to you
also, my kool korean keyboard is still in it's box unassembled because i dont know how to build keyboards and i dont know anybody that will build it for me (that and im lazy to ship it to somebody that does ;_;)
Offline jonathanyu
« Reply #2035 on: Thu, 09 January 2014, 01:12:31 »
« Reply #2036 on: Thu, 09 January 2014, 10:28:23 »
^ T_T
« Reply #2037 on: Thu, 09 January 2014, 15:06:32 »
Nice keycaps!
Olivetti is beautiful!
Offline Sai
« Reply #2038 on: Thu, 09 January 2014, 18:23:54 »
« Reply #2039 on: Thu, 09 January 2014, 18:24:42 »
It's my end game. For now I'm not worried about it, I have another thing I'm looking for.
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #2040 on: Thu, 09 January 2014, 21:43:30 »
What's that end game of yours?
A pink keyboard? :confused:
« Reply #2041 on: Thu, 09 January 2014, 21:44:27 »
Pink 456 GT
Story is that I promised SmallFry that I'd quit GH forever once I got it a while back on IRC. Now I'm kinda obligated to keep that promise, but I personally never break promises anyway.
Offline Shadovved
« Reply #2042 on: Thu, 09 January 2014, 21:45:20 »
Pink 456 GT
Well. You'll realised that that's not gonna be enough :p
Offline evolveS
  • ಠ_ಠ
« Reply #2043 on: Thu, 09 January 2014, 22:37:44 »
Gunmetal gray 2TU with 62g MX clears.
50441-0
More pictures on Kailet's blog.
« Last Edit: Thu, 09 January 2014, 22:43:42 by evolveS »
-a petty thief
« Reply #2044 on: Fri, 10 January 2014, 13:22:22 »
O.O
That's beautiful
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #2045 on: Fri, 10 January 2014, 13:37:05 »
That's basically my dream 60% case. Looks similar to GON's NS GH60.
Offline AKIMbO
  • HHKBro
« Reply #2046 on: Fri, 10 January 2014, 19:01:42 »
My 2 Kingsavers (Blue ALPs & Green ALPs):
| KBD75 (box reds)
« Reply #2047 on: Fri, 10 January 2014, 19:07:14 »
Where did you get the keycaps/switches for those?
« Last Edit: Thu, 18 June 2020, 23:34:41 by Puddsy »
Offline AKIMbO
  • HHKBro
« Reply #2048 on: Fri, 10 January 2014, 19:08:56 »
Where did you get the keycaps/switched for those?
They have to come from a Wang 724 board (PBT dyesubbed caps...awww yeah).
| KBD75 (box reds)
Offline mrdar206
  • Tickle me Pink
« Reply #2049 on: Sat, 11 January 2014, 20:36:31 »
Sunshine on the body  :cool:
