Author Topic: Post your Korean Keyboard ^_^  (Read 13951464 times)
Offline Leewei
Re: Post your Korean Keyboard ^_^
« Reply #850 on: Tue, 29 January 2013, 10:34:00 »
So the current winkeyless option for 1.2 is just like the kmac 2. I thought it would be like the kmac 1. I like the idea behind it and it still looks great! =)
The Kmac 2 doesn't doesn't have legs, it is raised like the kmac mini, and it is hard annodized.
Yup. I was just talking about the block idea for winkeyless option. Thanks though. Good to know =)
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #851 on: Tue, 29 January 2013, 10:57:32 »
Do all kmac 1.2 winkeyless come with blocks? or is yours just special? =D
They all do.  It was the intent of the design to do it this way so users would have the option to be either 84 Winkeyless or 86 Winkey from purchasing a single KMAC.  With the original KMAC 1, to do that, you would need to buy 2 KMAC's to achieve an 86 Winkey because they did not sell PCBs separately.  litster recently did this because he owns both an 84-Winkeyless and 86-Winkey KMAC 1.
At first I thought it might look tacky and was worried the color wouldn't be accurate, but it turned out well and I'm not bothered by the block.
I was weary at first about the blockers, especially since the prototype designs mentioned that they would be gold.  They just looked so tacky.  I'm glad they decided to match the color with the case.  I was also worried that they wouldn't sit flush with the rest of the case but it's a nice fit.
Considering Windows 8 uses a ton of Winkey hotkeys, I might start using it again.  Actually, who am I kidding, Winkeyless is too fresh.
@Dan
Next time, if you desloder and don't get clean diode legs, to the point where they won't pull through the switch holes for removal, simply use a tiny set of cutters and clip the big part off of the diode leg. I know exactly What you are saying. It happened to me Also.
John
Exactly what I did.
Offline SmallFry
« Reply #852 on: Tue, 29 January 2013, 11:19:47 »
Well, I'll have to change my mind notes that you don't mind the keyblocks. Looks nice, as always Dan. :)
Offline MattBuzzy
« Reply #853 on: Tue, 29 January 2013, 11:24:02 »
Wow that is a really nice board, wouldn't mind one myself.
Offline AKIMbO
  • HHKBro
« Reply #854 on: Tue, 29 January 2013, 11:43:19 »
Nice KMAC Dan.  Why'd you get mx switches with diodes?
| KBD75 (box reds)
Offline DanGWanG
  • Higher Standards
« Reply #855 on: Tue, 29 January 2013, 11:50:17 »
Danclopedia
Thank you sir.  I desoldered them off a Cherry board that had them in there =(
Offline SmallFry
« Reply #856 on: Tue, 29 January 2013, 17:13:09 »
I have other info, I wish I could compile it all to a wiki, but I don't even know where to start... Noted in the Dan section of the GHWorld Bok though. :))
Offline inteli722
« Reply #857 on: Tue, 29 January 2013, 20:56:32 »
I wish you could do Control+Escape+(insert key here) for winkey hotkeys...
Waiting for: Phantom Plate
Offline TheProfosist
  • Custom Layouts Only!
« Reply #858 on: Thu, 31 January 2013, 15:37:52 »
Offline SmallFry
« Reply #859 on: Thu, 31 January 2013, 15:48:02 »
Enter as the Shift and no Control key? You must be going crazy Prof!
« Reply #860 on: Thu, 31 January 2013, 15:50:15 »
:( i dont have those keys :( want to hook me up?
Offline SmallFry
« Reply #861 on: Thu, 31 January 2013, 15:51:30 »
I don't have any either. Sorry man.
« Reply #862 on: Thu, 31 January 2013, 15:58:13 »
When did you lose control? :P
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #863 on: Thu, 31 January 2013, 15:59:20 »
Offline SmallFry
« Reply #864 on: Thu, 31 January 2013, 15:59:25 »
When the Control Shifted to an Alternate key. :P
Offline baldgye
  • Will Smith Disciple
« Reply #865 on: Thu, 31 January 2013, 16:11:38 »
I might be able to help you out... I'll have to check though
« Reply #866 on: Thu, 31 January 2013, 17:11:46 »
please check when you have the time, thanks
Offline Tenkey
« Reply #867 on: Fri, 01 February 2013, 13:41:20 »
i got some extras as well if you dont mind paying the shipping ;)
« Reply #868 on: Fri, 01 February 2013, 13:44:29 »
youve got original cherry 1.5x Control and a RShift? if so I definitly dont mind paying
Offline Tenkey
« Reply #869 on: Fri, 01 February 2013, 13:49:46 »
Pretty sure i do, send me a pm
btw how do you only have one control and no proper rshift..
« Reply #870 on: Fri, 01 February 2013, 13:53:27 »
well the set came with a short right shift and idk what happened with the control, and since this came on a different board im not too picky and am just glad that I have what i do.
« Last Edit: Fri, 01 February 2013, 13:56:03 by TheProfosist »
Offline kaiserreich
  • HHKB Elite
« Reply #871 on: Sat, 02 February 2013, 22:32:59 »
Finally, I found a board for the DESKO RGBs.
And oh, It came from there  ;D
« Last Edit: Sat, 02 February 2013, 22:43:00 by kaiserreich »
« Reply #872 on: Sat, 02 February 2013, 22:33:57 »
nice dolch, at that!
« Reply #873 on: Sat, 02 February 2013, 22:48:09 »
That gangnam style
Offline okooko
  • afk.
« Reply #874 on: Sat, 02 February 2013, 23:03:34 »
That gangnam style
Gangnam, higher resale value mate.
signed by psy?
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #875 on: Sat, 02 February 2013, 23:04:34 »
That gangnam style
signed by psy?
Didnt know Psy was into keyboards  :p
Offline okooko
  • afk.
« Reply #876 on: Sat, 02 February 2013, 23:08:52 »
That gangnam style
signed by psy?
he wears Louboutins, man got style. he must have a computer hence he must have a baller keyboard for said computer.
it only makes sense
Offline Shadovved
« Reply #877 on: Sat, 02 February 2013, 23:10:25 »
Dont think he uses a keyboard, he will have someone type everything for him :p
Offline baldgye
« Reply #878 on: Sun, 03 February 2013, 01:38:04 »
It's actually a really rich part of Seoul, which means the person who sent it to you is an even bigger baller than psy
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #879 on: Sun, 03 February 2013, 14:37:45 »
Well considering the song was about the Gangnam district, that's to be expected. :)
Offline DrugER
  • JACKASS@KBDmania
    • JACKASS76@WORDPRESS.COM
« Reply #880 on: Sun, 03 February 2013, 22:21:02 »
A.K.A. TWO SOME HOUSING
1. CNC machined acrylic housing
2. biki style
3. LED bar mounted
4. FULL LED PCB(selectable ps/2 or usb)
5. It was created only four.
RED-LINE.KR
Offline ekw808
  • Ekw
« Reply #881 on: Sun, 03 February 2013, 22:22:45 »
Wow nice keyboard, I really like the look of half case design.
[One Keyboard at a time]
Offline akuJIWA
  • Lock 'N Load!
« Reply #882 on: Sun, 03 February 2013, 22:22:51 »
2. biki style
3. LED bar mounted
Looks like K60, still awesome!
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #883 on: Sun, 03 February 2013, 22:36:08 »
2. biki style
3. LED bar mounted
It does look like a k60, just a little bit..
-Enzo Ferrari
Offline okooko
  • afk.
« Reply #884 on: Sun, 03 February 2013, 22:45:57 »
straight out from gangnaM?
Offline rurushu
« Reply #885 on: Mon, 04 February 2013, 08:52:50 »
2. biki style
3. LED bar mounted
looks nice, the acrylic shell... it has the metallic finish that gives it a metallic shell-like feel....
btw, with such half shell design, wouldn't it be more prone to damage? the switches are exposed....
« Reply #886 on: Mon, 04 February 2013, 13:12:19 »
What whould you do to damage it in the first place?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #887 on: Mon, 04 February 2013, 14:19:23 »
DrugER that thing is amazing!
Offline DrugER
  • JACKASS@KBDmania
« Reply #888 on: Mon, 04 February 2013, 19:58:46 »
2. biki style
3. LED bar mounted
the switches are exposed but no problem yet and easy to clean :)
RED-LINE.KR
Offline rurushu
« Reply #889 on: Tue, 05 February 2013, 00:04:14 »
I mean, accidents, they can happen, not saying to damage them on purpose, example like accidentally dropped something on them etc...
2. biki style
3. LED bar mounted
i see... yea, agreed that it is easy to clean  :D
« Reply #890 on: Tue, 05 February 2013, 03:24:24 »
What you didnt hear about the invisible barrier insurance plan you can get for korean custom?
Offline rurushu
« Reply #891 on: Tue, 05 February 2013, 06:28:02 »
 :eek: :eek: :eek: wha? i seriously didn't know about that!!!
Offline jcrouse
« Reply #892 on: Wed, 06 February 2013, 20:22:47 »
More Korean luvin, in the form of a KMAC 1.4 (KMAC 2) outfitted with GMK doubleshots. Sorry for the potato pic, again.
13234-0
13236-1
Enjoy,
John
« Last Edit: Sat, 09 February 2013, 10:19:47 by jcrouse »
Offline reaper
« Reply #893 on: Wed, 06 February 2013, 20:30:03 »
Nice.  Which keycaps are those?  imsto's?
Din Eli
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #894 on: Wed, 06 February 2013, 20:35:37 »
Whoa GMK came out with some sets already? Love me some windowed keys! Nice one John
« Reply #895 on: Wed, 06 February 2013, 21:30:08 »
*Drool*
Couldn't wait to assemble it eh?
Offline rurushu
« Reply #896 on: Wed, 06 February 2013, 21:37:34 »
Enjoy,
John
Oh.... so the KMAC 2 does support for full 87 key layouts.... many people were concerned about that ^^'''
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #897 on: Wed, 06 February 2013, 22:16:52 »
The concern is if Sherryton is able to get those since the pics he showed were only 84 and 86. If you look at WhiteFireDragon's pics you'll see the plates are 87 plate as well.
Offline rurushu
« Reply #898 on: Wed, 06 February 2013, 23:17:06 »
oh i see... thanks for clearing that up!
Offline el2k
« Reply #899 on: Thu, 07 February 2013, 12:24:51 »
"Ctrl" "Ins" "Del" "Print"
GMK >.<
sc00pz for life
