Author Topic: Switches close to MX Brown?  (Read 4112 times)
Offline Cindori
    • My Blog
« on: Thu, 27 September 2012, 05:03:19 »
I have tried MX Brown, blue and red, and I definately enjoy MX Brown the most.
What other switches do you think I would like? I think I could enjoy the feeling of browns but a little more stiffness. (not clicky)
Offline perragnar
Re: Switches close to MX Brown?
« Reply #1 on: Thu, 27 September 2012, 05:07:10 »
MX Clears would be the obvious choice. They are exactly like browns only stiffer and more tactile.
Offline Autolyze
« Reply #2 on: Thu, 27 September 2012, 06:18:14 »
Clears are good, but ergo-clears are better!
Offline perragnar
« Reply #3 on: Thu, 27 September 2012, 09:45:39 »
I can imagine that, shame I'm clueless when it comes to soldering stuff. :|
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Thu, 27 September 2012, 09:51:35 »
Get a poker, you can change stems without solding most of the switches. You would only really need to desolder 7 LEDs to access those switches to swap them.
You could also just find any PCB mount board since those you don't have to desolder to change stems as well
Offline MMB
« Reply #5 on: Thu, 27 September 2012, 09:53:27 »
Browns aren't bad if they are lubed. The only real issue is their scratchiness, and that can be removed by using lube.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #6 on: Thu, 27 September 2012, 10:18:13 »
ou can try cherry MX clears or lube MX browns with a MX black springs = PWNAGE!
-Enzo Ferrari
Offline Cindori
    • My Blog
« Reply #7 on: Thu, 27 September 2012, 10:25:21 »
Ergo clears look really nice from this vid.
If I were to buy a filco, what would I need to mod it to ergo clear?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Thu, 27 September 2012, 10:26:04 »
Brown/red/blue springs
Offline Neo.X
« Reply #9 on: Thu, 27 September 2012, 10:26:21 »
Can you provide some links on how to lube a swith? I am interested in it.
Thanks
All those keyboards will be lost in time....
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #10 on: Thu, 27 September 2012, 10:43:27 »
Thanks
Here it is..Enjoy'
http://geekhack.org/index.php?topic=34332.0
-Enzo Ferrari
Offline Cindori
    • My Blog
« Reply #11 on: Thu, 27 September 2012, 10:44:30 »
So is it easier to buy an clear filco (do they exist?) and get springs, or easier to buy a brown filco and get mx clear stems?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #12 on: Thu, 27 September 2012, 10:47:39 »
Clear filco, springs should be pretty easy to get. I've only see one GB for clear stems since I've been here
Offline alaricljs
  • I be WOT'ing all day...
« Reply #13 on: Thu, 27 September 2012, 11:25:47 »
There is no Filco w/ MX Clears.  You'd need to purchase the Filco and Clear stems/switches.
Filco w/ Imsto thick PBT
Offline weenis
« Reply #14 on: Thu, 27 September 2012, 11:45:29 »
If you like the feel of Cherry Browns, you may like Black Alps. I think they're close, but I do prefer Cherry Browns.
You can grab a cheap AT101W, I have one in very good condition that I quite enjoy.
Dell AT101W | Unicomp Spacesaver PC | IBM SpaceSaver Keyboard | IBM Black Label M | KBT Oni Brown | Leopold Otaku Brown | Noppoo Choc Mini Brown | IKBC F104 Brown
« Reply #15 on: Thu, 27 September 2012, 12:02:04 »
Matias Quiet Pro's new ALPS based switches are an amazing feel and I primarily use browns.
Offline polpo
    • http://polpo.org/
« Reply #16 on: Thu, 27 September 2012, 13:00:00 »
I was going to recommend Matias's new dampened tactile switches, but Binge beat me to it.
Matias Mini Quiet Pro / DSI SMK-88 (Cherry Black) / IBM Model M (10 Jul 86) / ThinkPad Travel Keyboard with Ultranav
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Switches close to MX Brown?
« Reply #17 on: Thu, 27 September 2012, 23:35:55 »
i can solder for you if your interested in ergo clears or any other custom switch.
Sice you said youd like brows but stiffer could try putting a black or clear spring with a brown stem.
« Last Edit: Thu, 27 September 2012, 23:38:10 by TheProfosist »
Offline nullstring
« Reply #18 on: Fri, 28 September 2012, 10:35:31 »
I think thats a bad idea.. The stiffer springs will make the already subtle bump even more subtle.
Offline alaricljs
« Reply #19 on: Fri, 28 September 2012, 12:15:46 »
yeah, brown with a stiffer spring is even closer to linear with dirt that I keep hearing my favorite switch insulted as...
« Reply #20 on: Fri, 28 September 2012, 12:17:20 »
Just though it might be an option but i must say once you get used to clears i loved them and rarely bottomed out.
