Author Topic: [Shipping] Stainless Steel Poker Plate  (Read 183630 times)
Offline xavierblak
Re: [Taking Orders] Stainless Steel Poker Plate
« Reply #50 on: Tue, 02 October 2012, 13:09:53 »
In for 3.  :D This works out well with the poker group buy that just started.
Offline CKTofu
  • I don't even...
« Reply #51 on: Tue, 02 October 2012, 18:26:08 »
I'm in for one!
Ducky Shine 2 - MX Red with Red LEDs
Offline The_Beast
  • I like wood ಠ_๏
« Reply #52 on: Wed, 03 October 2012, 10:20:21 »
Talked to the postman, see post #1 for update on international shipping
Offline Unicorn_Systems
« Reply #53 on: Wed, 03 October 2012, 11:55:33 »
I'm in for one of these! I'll fill in the form and send it now :)
Offline TDub
« Reply #54 on: Wed, 03 October 2012, 17:28:24 »
I think I only ordered one, can I double my order?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #55 on: Wed, 03 October 2012, 17:33:33 »
Just send me a PM with any order updates, I'll update and then you can confirm via post #2
BTW I did a little area/volume/density model. The plate should weight 160g or 0.35Lbs.
The little notes on the order forms are cute but I'll be printing those exact addresses, so make sure it's exactly how you want it.
« Last Edit: Wed, 03 October 2012, 17:36:04 by The_Beast »
Offline kaiserreich
  • HHKB Elite
« Reply #56 on: Wed, 03 October 2012, 18:28:49 »
Does that includes the padding cost?
I found that padding is really important. A swiss cheese made of steel plate is not really strong, and a lot of reinforcements is required
Offline The_Beast
  • I like wood ಠ_๏
« Reply #57 on: Wed, 03 October 2012, 18:32:29 »
I was going to use a 1/8" hardboard (it's high density fiberboard) as a backer + a layer of bubble wrap.
Like I said that price is tentative but it should be close to that price
Offline huttala
Sv: [Taking Orders] Stainless Steel Poker Plate
« Reply #58 on: Wed, 03 October 2012, 20:19:28 »
I sent an order for two plates. Please confirm that you got it.
Thanks.
Sent from my Samsung Galaxy Note II using Tapatalk.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #59 on: Wed, 03 October 2012, 20:23:06 »
Thanks.
Post #2 has all the people who ordered and the quantity ordered. It updates ~5 minutes, you are on there ^___^
Offline hasu
  • @tmk
« Reply #60 on: Wed, 03 October 2012, 20:44:06 »
I'm in for 3. Thanks.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #61 on: Wed, 03 October 2012, 20:49:44 »
Chance to put together another small board?   hasu grabs it... 3x!  ;)
Filco w/ Imsto thick PBT
Offline The_Beast
  • I like wood ಠ_๏
« Reply #62 on: Wed, 03 October 2012, 23:27:26 »
47 plates in just a few days, very nice guys
I might have to close this one early. I asked my guy when I would have to order these to get them by 11/15, but when I asked, I only thought we would get ~20 orders. With more than double that, he might need more time. I'll keep you guys updated ^___^
Edit: I sent another email to my guy asking about semi-final pricing and lead times. He should get back to me sometime today.
« Last Edit: Thu, 04 October 2012, 01:38:32 by The_Beast »
Offline mm87
« Reply #63 on: Thu, 04 October 2012, 05:11:54 »
Sent order for 2. Cheers :]
Offline tadbitnerdy
« Reply #64 on: Thu, 04 October 2012, 08:21:33 »
Might be a dumb question, but will this plate fit in the stock, plastic Poker case?
-Tad
Offline xJaPx
  • Oh, Herro!
« Reply #65 on: Thu, 04 October 2012, 10:02:51 »
I feel retarded asking, but i have to learn somehow.  What are the advantages/reasons for buying.these?
| Poker MX Red |
Offline The_Beast
  • I like wood ಠ_๏
« Reply #66 on: Thu, 04 October 2012, 10:03:04 »
Not a dumb question, the plate helps support the switch and make the poker feel more solid. It should help eliminate PCB flex while typing
-Tad
That's not a dumb question and yes it will ^__^
Photo of alixinhzai plate (the plate we are all ordering):
Offline tadbitnerdy
« Reply #67 on: Thu, 04 October 2012, 10:04:23 »
Awesome!  And one other question... will it work with the stock stabilizers?
I placed my order.  Waiting for invoice :)
-Tad
Offline The_Beast
  • I like wood ಠ_๏
« Reply #68 on: Thu, 04 October 2012, 10:06:22 »
-Tad
alixinhzai has designed it so that it works with cherry (the stock stabilizer that comes with the poker) and Costar. However since the plate is 1/16 or .0625" Costar may not work since it requires the plate to be .060" in thickness.
Offline tadbitnerdy
« Reply #69 on: Thu, 04 October 2012, 10:07:01 »
Okay cool, looking forward to this!
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #70 on: Thu, 04 October 2012, 10:08:52 »
Dumb question - how does one install the plate?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #71 on: Thu, 04 October 2012, 10:10:58 »
Again, no dumb questions guys, everyone is here to learn ^___^
Anyways, you desolder all the switches, install cherry stabilizers, then install the switches back onto the plate and then resolder on all the switches back onto the PCB.
« Last Edit: Thu, 04 October 2012, 10:25:28 by The_Beast »
  • techkeys.us
    • TechKeys
« Reply #72 on: Thu, 04 October 2012, 10:15:43 »
Ok I'm in for 2
Offline alaricljs
« Reply #73 on: Thu, 04 October 2012, 10:18:37 »
Anyways, you desolder all the switches, install them on the plate and then resolder on all the switches back onto the PCB.
Gotta fix that, because doing it wrong is just too damned much work...
If you are using PCB mount Cherry stabs, install them FIRST.  Then install switches through the plate.
Offline xJaPx
  • Oh, Herro!
Re: Re: [Taking Orders] Stainless Steel Poker Plate
« Reply #74 on: Thu, 04 October 2012, 10:21:14 »
i was under the impression changing switches on a poker requires no soldering?
| Poker MX Red |
Offline The_Beast
  • I like wood ಠ_๏
« Reply #75 on: Thu, 04 October 2012, 10:24:37 »
No, on the stock poker it's easy to change stems and springs because it's PCB mount. Once you make it a plate mount, it's much harder because the plate blocks you from lifting the tabs on the side of the switch (the tabs that keep the switch together).
Thanks, I'll edit my post
Offline balanar
« Reply #76 on: Thu, 04 October 2012, 12:58:06 »
Hmm so all our plates will have the word 'ali' and the logo on them? I think alixinhzai is doing a fantastic job sharing his design with us, just wanted to know if ours will be neutral or 'branded' with his name.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #77 on: Thu, 04 October 2012, 13:21:21 »
Nope, the plate will look exactly like the picture in my first post (no brand or usernames). I was thinking of putting GH someone on the plate, but decided not to since I'm sure not everyone uses GH as much as I do or wants GH on the plate.
« Reply #78 on: Thu, 04 October 2012, 14:05:49 »
Can you hand carve a wizard shark into mine Beast? :p
EDIT: ZOMG POST 500!!!
Offline esoomenona
  • Gnillort?
« Reply #79 on: Thu, 04 October 2012, 14:12:51 »
« Last Edit: Wed, 15 October 2014, 18:51:33 by esoomenona »
Offline turtle
« Reply #80 on: Thu, 04 October 2012, 14:41:04 »
add me to the list for one. Thanks!
« Reply #81 on: Thu, 04 October 2012, 15:05:24 »
Hehehe :D  :p
I didn't put anything in the address field other than my actual address though ;)
Offline WhiteFireDragon
    • youtube
« Reply #82 on: Thu, 04 October 2012, 15:17:21 »
I had no idea there were that many pokers out there. I thought pokers were a niche market, in an already niche market of mechanical keyboards.
Offline wiredPANDA
« Reply #83 on: Thu, 04 October 2012, 15:25:23 »
Think they are still fairly niche, but I know a few Poker owners have more than one.  And it seems they became FOTM when they started to get harder to find.
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
« Reply #84 on: Thu, 04 October 2012, 15:26:11 »
I have one and am in the market for a second. Also need to get my hands on one for a customer who noticed and tried mine when he was in the other day, and asked me to source one for him! It really is a gorgeous little board! :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #85 on: Thu, 04 October 2012, 15:26:18 »
Nope, you have to fill out the order form in the first post to order
I might tentatively be in for a total of three. Still trying to decide.
Just pm me before I close the GB
Offline balanar
« Reply #86 on: Thu, 04 October 2012, 16:18:11 »
Could it be an optional thing though? I would love to have 'GH' or 'geek' on one side and 'hack' on the other if it'll fit.
Offline elton5354
« Reply #87 on: Thu, 04 October 2012, 17:47:15 »
Hi anyone willing to install these for me? :D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #88 on: Thu, 04 October 2012, 18:15:40 »
Unless everyone agreed on it, I think the laser guy would charge for a single piece to do it just on one.
That or one or other plate design wouldn't get as many orders and make it more expensive
« Reply #89 on: Thu, 04 October 2012, 18:53:53 »
Questionnaire filled! Was looking for the "double the F*** yeah!" answer...but I suppose a simple "yes" will suffice!
Offline sth
  • 2 girls 1 cuprubber
« Reply #90 on: Thu, 04 October 2012, 18:54:50 »
mostly kidding about 'dogg breff'
Offline Zwi
  • hi.
« Reply #91 on: Thu, 04 October 2012, 20:13:34 »
Voted yes but its more a yes/don't care
Offline TheQsanity
  • SmallFry Lovin'
« Reply #92 on: Thu, 04 October 2012, 20:20:28 »
To the OP, How are you getting/making these?
I am in a welding class atm and if I get good enough I could essentially make my own correct?
Are you hand-making these and is it possible to?
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
« Reply #93 on: Thu, 04 October 2012, 20:23:11 »
I'm getting them laser cut
I doubt you could do it by hand since the holes are small and have semi-tight tolerance
Offline TheQsanity
  • SmallFry Lovin'
« Reply #94 on: Thu, 04 October 2012, 20:26:03 »
They have one of those at the shop. I just need to learn how to use the machine. How did you get the design for it? and how can I get one of my own?
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
« Reply #95 on: Thu, 04 October 2012, 20:31:56 »
I'll send you the .dwg file later, I'm in the middle of lubing switches ^__^
Offline TheQsanity
  • SmallFry Lovin'
« Reply #96 on: Thu, 04 October 2012, 20:35:10 »
Sick man!
Thanks and Have fun! :D
SmallFry! <3
Offline Acanthophis
« Reply #97 on: Thu, 04 October 2012, 22:13:53 »
My "other" vote on the poll:
I'm not very fond of the name geekhack itself.
But I'm fine with the initials (GH) or some random logo you come up with.
But it won't be a total disaster to have it written somewhere. It's under the keycaps anyway :D
Related question:
Are custom cut-out designs possible?
Own GH screen name for example?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #98 on: Thu, 04 October 2012, 22:25:40 »
Related question:
Send me a plate design and I'll cut it, which could include user names. However I think the laser guy is going to count that as one piece even if all the plates are the same except that one thing
Offline hasu
  • @tmk
« Reply #99 on: Fri, 05 October 2012, 01:01:23 »
No branding is needed on my plates! Plain plate looks great to me.
But I won't cancel my order even if plates are stamped any logo ;)
Thanks a lot for organizing this GB, The_Beast.
