Author Topic: MiMiC Cables - Custom Sleeved Cables  (Read 869736 times)
Offline mistakemistake
  • Global Loveinator
Re: MiMiC Cables **Custom Sleeved Cables** 2 Piece has arrived!
« Reply #300 on: Mon, 15 October 2012, 20:53:44 »
Received my cable (first one pictured in the OP), and ... OMAGAD, it is awesome !
Thanks a lot mistakemistake, it's perfect, as I'm gonna have a HHKB really soon, and it is perfectly adapted for it :D
Awesome, I'm glad you like it!  I'd love to see some pics of it with your keyboard :)
Offline Anynoupy
  • French Fries
« Reply #301 on: Mon, 15 October 2012, 23:47:30 »
I'll definitely post some once I got the HHKB :D (And I'll do a couple of them with my Poker before I ship it out today !)
Offline lbwmoo
« Reply #302 on: Tue, 16 October 2012, 01:17:20 »
Perhaps this has been covered, but I didn't see it. The connector for the cables on Filco boards is available for purchase for pennies, sorry don't remember where I read this, but it's a common molex connector. Would it be possible for a custom cable to come in a 2 piece that I saw earlier on this thread, with a short, say 3 inch, part that would come out of the board to the main detach point, and the same short piece terminating in the Filco molex connector? The second, longer piece in the 2 piece configuration would start with the 2nd half of the detach point, and then terminate in a standard USB port? I'll look to see if I can find that molex connector, but a picture of it is shown here at http://imgur.com/a/Yhahf#16  The final result would be a detachable cable Filco without the need to have to add in a jack to the board, should just be disassemble, pop out old cable, pop in short run of new detachable cable and snake thru existing opening, reassemble, connect rest of cable, and plug in. Thoughts anyone?
  • Global Loveinator
« Reply #303 on: Tue, 16 October 2012, 01:25:25 »
Yep, I can get that done for ya. I'll shoot you a PM.
Offline jeroplane
« Reply #304 on: Tue, 16 October 2012, 01:43:09 »
If I'm understanding this correctly, it sounds like a quick and easy detachable cable mod that could be done by people without a need for soldering, stripping wires, sourcing parts, etc? If so, I might want to be in for one too.
My signature hasn't changed since 2012. I should really update it.
Offline WhiteFireDragon
    • youtube
« Reply #305 on: Tue, 16 October 2012, 02:39:03 »
The connector is easily found, but you need to do something about the female pins that go into those connectors. A crimple tool costs about $300. Unless you can source pre-crimpled pins.
Offline emptythecache
  • out.
« Reply #306 on: Tue, 16 October 2012, 08:28:29 »
yeah, we should do a fundraiser for the crimping tool for the filco pcb connector, maybe with a cable/part of a cable as an incentive.
Connector
Terminals
Crimping Tool (Correct according to the terminal's data sheet)
« Last Edit: Tue, 16 October 2012, 08:36:47 by emptythecache »
  • Global Loveinator
« Reply #307 on: Tue, 16 October 2012, 08:33:44 »
I wouldn't mind buying the tool if there was enough interest. :)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #308 on: Tue, 16 October 2012, 08:37:58 »
For low quantities it's not that hard to crimp the connectors manually.  Just be sure to solder after crimping and it'll be solid.  There are even crimp tools at Home Depot that'll get you close enough, then just clean up with some needle nose and solder.
Filco w/ Imsto thick PBT
Offline lbwmoo
« Reply #309 on: Tue, 16 October 2012, 10:42:46 »
After discussing with MM about the mod, I still think it sounds like a good idea, but had no idea what the added cost of that midpoint detachable cable connector was. Hint, it's not inexpensive. However, we are now in talks about making a single cable, sleeved, with usb on one end, and the Filco specific connector on the other. The only work that would possibly be needed for the board itself is to expand the hole with a rasp or file,and a stopper of some kind on the inside, possibly using a zip tie cinched down to act as a stress relief, but it would give it the clean, factory look that I'm going for. What are everyone's thoughts? I'd be down for throwing some cash in for a crimper to get the inner connector attached properly if enough people were interested as well.
« Last Edit: Tue, 16 October 2012, 10:48:02 by lbwmoo »
  • Global Loveinator
« Reply #310 on: Tue, 16 October 2012, 12:08:30 »
^I am working on trying to get better pricing for these connectors. I'll keep you guys posted and won't make this an official buy option just yet. As for those molex connectors, I'll pick some up and give it a shot. I'll try and get some pics up for you guys soon.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #311 on: Tue, 16 October 2012, 17:15:21 »
Great to hear about progress of new cables. I know the 2 piece cable isnt cheap but im bette its worth it ill know soon.
Offline jil_jil32
  • Tokyo Press <3
« Reply #312 on: Wed, 17 October 2012, 04:12:22 »
Waiting for the stainless steel beauty =p~
Offline Anynoupy
  • French Fries
« Reply #313 on: Wed, 17 October 2012, 09:17:28 »
Before it was gone (Poker, IronMan & Graphite), last picture with its brand new MiMiC custom cable :D
Poker with a bunch of stuff, by Anynoupy.
Thanks a lot mistakemistake, it will be perfect for my incoming HHKB !
(And sorry about the crappy picture, bad lighting :-X)
  • Global Loveinator
« Reply #314 on: Wed, 17 October 2012, 19:48:12 »
Update: Cables shipping out tomorrow :)
A few new sleeves came in today. Below is pretty awesome: Chameleon
« Reply #315 on: Wed, 17 October 2012, 19:57:45 »
That Chameleon is pretty sweet looking.
  • Global Loveinator
« Reply #316 on: Wed, 17 October 2012, 20:04:59 »
Group of cables getting ready to go to their new homes!
Offline esoomenona
  • Gnillort?
« Reply #317 on: Wed, 17 October 2012, 20:49:23 »
« Last Edit: Thu, 10 September 2015, 15:01:28 by esoomenona »
Offline Tabulafirmus
« Reply #318 on: Thu, 18 October 2012, 15:29:49 »
When chameleon sleeve will be available?
  • Global Loveinator
« Reply #319 on: Thu, 18 October 2012, 15:32:20 »
Alrighty have it in stock :)
« Reply #320 on: Thu, 18 October 2012, 15:36:09 »
Don't let me drool then, modify your order form!
  • Global Loveinator
« Reply #321 on: Thu, 18 October 2012, 15:41:12 »
Ok, done!
Offline elton5354
« Reply #322 on: Thu, 18 October 2012, 16:49:15 »
Thanks for your quick service! Can't wait to receive mine! Any pictures of mine for me to enjoy before it arrives? Haha
« Reply #323 on: Thu, 18 October 2012, 16:56:11 »
I want my cable too! But I gotta wait for stock. I think I have one of the most expensive single cable orders :D
« Reply #324 on: Thu, 18 October 2012, 17:12:12 »
I have to wait for more parts to stock as well :( I know how you feel aramid armor and 2 piece connectors are not cheap.
« Reply #325 on: Thu, 18 October 2012, 17:14:12 »
I went with the Silver Silica, and didn't get the 2 piece connectors because it would take longer to get my cable :P
« Reply #326 on: Thu, 18 October 2012, 17:24:50 »
I wanted a dash of yellow for my phantoms as I thought it would look good and I couldnt pass up something thats in the same category as kevlar and nomex. Youll have to do a review of the silver silica when you receive it, I wonder if it actually is what the name implies? Yea I switched to the 2 piece because i want a detachabl cable to add to the portability of my phantom.
« Reply #327 on: Thu, 18 October 2012, 17:28:41 »
Yeah for sure I'll do a review on it! It sounds amazing and looks really good as well. I really want to get the 2 piece but it's pretty pricey and I probably won't use it as much as I think I will, so single cable it is!
« Reply #328 on: Thu, 18 October 2012, 18:14:49 »
do you have sleeving that screams "AMERICA, **** YEAH!"?
  • Global Loveinator
« Reply #329 on: Thu, 18 October 2012, 18:16:26 »
There you go! This cable took, FOREVER. Kevlar isn't easy to work with. ..this and aramid. Hope you enjoy :)
Re: Re: MiMiC Cables **Custom Sleeved Cables** 2 Piece has arrived!
« Reply #330 on: Thu, 18 October 2012, 18:19:46 »
yes i think he does.
« Reply #331 on: Thu, 18 October 2012, 18:21:51 »
dont be hating on the aramid ;)
  • Global Loveinator
« Reply #332 on: Thu, 18 October 2012, 18:22:20 »
Is the closest thing I have done so far. I guess I could attach one of those recording boxes to it and make it say that everytime you plug in your USB cable if you'd like. Might make it a little bulkier :O
  • Global Loveinator
« Reply #333 on: Thu, 18 October 2012, 18:22:57 »
haha, your cables took me almost 5 hours alone just to sleeve :) <3
« Reply #334 on: Thu, 18 October 2012, 18:23:24 »
crap thats a nice cable. especially like the shrink wrap.
throw in some stars so they wont think it's french :P
anyway, you're doing an awesome job on your cables!
  • Global Loveinator
« Reply #335 on: Thu, 18 October 2012, 18:23:49 »
Shorty angled chameleon:
Offline esoomenona
  • Gnillort?
« Reply #336 on: Thu, 18 October 2012, 18:24:06 »
« Last Edit: Fri, 11 September 2015, 16:21:48 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #337 on: Thu, 18 October 2012, 18:25:00 »
« Last Edit: Fri, 11 September 2015, 16:17:57 by esoomenona »
  • Global Loveinator
« Reply #338 on: Thu, 18 October 2012, 18:26:02 »
That's a good idea! I'm going to have to do that because I was thinking French about it too. Do they sell white Sharpies?
Dude, I tried the stars. Didn't quite work out. Hah..
Offline esoomenona
  • Gnillort?
« Reply #339 on: Thu, 18 October 2012, 18:27:20 »
« Last Edit: Fri, 11 September 2015, 16:17:06 by esoomenona »
« Reply #340 on: Thu, 18 October 2012, 18:28:50 »
Just when I was about to brag about my baby. Damn.
  • Global Loveinator
« Reply #341 on: Thu, 18 October 2012, 18:31:06 »
D: I didn't know this was an option...
Haha, it's not really. But if you can think it up, I can probably find some way to make it work.
« Reply #342 on: Thu, 18 October 2012, 19:23:37 »
whoa was not expecting that!
you're like a wizard.
do a dog now!
  • Global Loveinator
« Reply #343 on: Thu, 18 October 2012, 19:58:03 »
^ I couldn't do the dog.  :-[ What a waste of heatshrink trying. haha
But, let me know what you guys think of this. I drew this on a con-call last week.. Just playing around for now :)
« Last Edit: Thu, 18 October 2012, 20:00:07 by mistakemistake »
Offline esoomenona
  • Gnillort?
« Reply #344 on: Thu, 18 October 2012, 20:00:48 »
« Last Edit: Fri, 11 September 2015, 16:19:08 by esoomenona »
  • Global Loveinator
« Reply #345 on: Thu, 18 October 2012, 20:01:53 »
haha aw :( I figured cables/snakes?  Not very many people, myself included, like snakes though :/
« Reply #346 on: Thu, 18 October 2012, 20:10:05 »
should use a rattlesnake and have it coiled up or possibly one of those green snakes that coil up on trees in the rain forest.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #347 on: Thu, 18 October 2012, 20:12:44 »
Thanks for letting me know that the cable is finished.
Looking forward to seeing your latest masterpiece.  The sleeves you have currently available are just too good to choose just one.  You should be proud of yourself for providing your skills to everyone here.
Nice one.
« Reply #348 on: Thu, 18 October 2012, 20:30:03 »
i like it!
Offline esoomenona
  • Gnillort?
« Reply #349 on: Thu, 18 October 2012, 20:34:33 »
« Last Edit: Fri, 11 September 2015, 15:42:48 by esoomenona »
