Author Topic: Can I use ANSI plastic cover for ISO board?  (Read 5158 times)
Offline FJ_Sanchez
« on: Sun, 30 September 2012, 14:47:25 »
I'm talking about same model keyboards, for example here are the ISO and ANSI version of CM QuickFire Rapid, ISO with browns and ANSI with reds:
For me they are the same, just not sure if something could change. Do you know if is it easy to get top cover for this keyboard?
Thank you!
« Last Edit: Sun, 30 September 2012, 15:17:33 by FJ_Sanchez »
Starting in the mecha path...
Main keyboard: CM Storm Quickfire Rapid MX Brown (ISO layout with Spanish legend)
Other keyboards: KBC Poker MX Red
Offline Cindori
    • My Blog
Re: Can I use ANSI plate for ISO board?
« Reply #1 on: Sun, 30 September 2012, 14:54:26 »
Well I would say ofc not. lots of difference in layout, around enter and left shift. an ANSI plate will only have one switch at left shift where ISO will have two.
Offline SmallFry
« Reply #2 on: Sun, 30 September 2012, 14:57:03 »
I'd have to say not too.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sun, 30 September 2012, 15:02:23 »
While I agree all ISO board should be made to ANSI, it is not really very easy. You would also need to do lot of modification on the pcb which is even more difficult that modify a plate.
What are you wanting to accomplish anyway? Just change the switch type or something? If so you can desolder and resolder and put in whichever case body color... that is not a hard thing.
Offline FJ_Sanchez
« Reply #4 on: Sun, 30 September 2012, 15:17:06 »
Oops.... that's the problem of having english as non native language... I mean top plastic cover...  :p
Offline WhiteFireDragon
    • youtube
Re: Can I use ANSI plastic cover for ISO board?
« Reply #5 on: Sun, 30 September 2012, 15:25:40 »
For the metal plate under the caps, you can't use them interchangeably. But for the plastic cover from the case, they should be identical.
« Reply #6 on: Sun, 30 September 2012, 15:37:27 »
Yes case is easy change. Undo screw, pry open and swap the internals.
Offline FJ_Sanchez
« Reply #7 on: Sun, 30 September 2012, 15:54:27 »
I've found this: http://cmupload.coolermaster-usa.com/safety_emc/Storm/SGK-4000%20series/(SGK-4000-GKCC1-US)%20CE%20Report.pdf
At the end there are some interesting pictures of the inner of the keyboard, I think they should be the same. Do you know if is it easy to get these covers? Custom covers?
« Reply #8 on: Sun, 30 September 2012, 16:10:42 »
If you want something different and more custom like these MKC cases?
Offline FJ_Sanchez
« Reply #9 on: Sun, 30 September 2012, 16:28:30 »
Cool! And those fit in CM QuickFire Rapid?
Thank you for the info!!
EDIT: I've read in the post there are for the Rapid. That's great!
« Last Edit: Sun, 30 September 2012, 16:32:21 by FJ_Sanchez »
Offline FJ_Sanchez
« Reply #10 on: Sun, 30 September 2012, 16:44:02 »
Those acrylic cases look simple enough to make them by myself using laser cutter or CNC for better finishing... I'm even thinking on building my own keyboard from scratch: PCB, switches, firmware, case... Thinking...  :rolleyes:
